Question about Canon PIXMA MP600 all-In-One InkJet Printer
Error messages: U150 + Ink tank errors have occured
Hi I have two error messages. 1st on the display screen of my canon IP 6700D which says - U 150 The following ink tank cannot be recognised. 2nd on computer screen running xp - Ink tank errors have occured. Open the printer cover & replace the ink tanks on which ink lamps are off. Cancel printing. ( 5 tank lights off 1 light on solid - should all be blinking) This situation has occurred by my refilling the original ink tanks with quality ink designed for my brand and model of printer. Had disabled ink level indicator as requested by drivers. Have only refilled 3 times on 1 tank and once on other 5 tanks. The problem is the drivers and chips on the canon tanks. Does any one know a way around the drivers and chips to stop these error messages? I spoke to canon support and they say error messages nothing to do with drivers or chips (yeah right). machine faulty but grey area as to canon repairing under warranty. How do ya like that eh????? Their advice - buy our ink! Get U150 error message reporting ink tank cannot be recognized. Tank is essentially full and have used nothing but Canon OEM ink tanks. Removing and reinserting the tank has allowed me to print on 2 out of 10 trys. I intend to replace the tank and complain to Cannon. Canon PIXMA MP610 All-In-One InkJet Printer
  • 6 more comments
  • Anonymous Jul 14, 2008
    Canon PIXMA All-in-one inkjet printer....error message ink tank errors!!! Mostly occuring on the yellow ink #8Y cartridge. And yes I am using canon ink!!!! I remove it and put it back in and it works for a couple of prints without an error and then it starts again. Help please!
  • bahark Jul 14, 2008
    I also have the same problem for the Magenta. "The following ink tank can not be recognized." When I open the top to check if the red light is on, it is not. But, if I take the cartridge out and insert again the red light comes back. I then close the top and the error message comes back. The printer is new, hardly used.
  • Neo_21 Jul 15, 2008
    I have the same problem with the magenta inkt.. .
    The cartrigde is still full.. .
    Can some help please?
  • scote168 Jul 16, 2008
    U043 error message appears, replaced chip onto new cartridge (first time transferred this chip to a different make of ink) have used this brand of ink
    for maybe 6 months and always been fine. Have put two new yellow cartridges in just in case first was faulty but exactly same message comes up. very frustrating as I had tried for weeks to resolve mp6400 message finally got it going and whole new set of inks put in except the yellow as
    it was not empty and now I am stuck again. can't do anything about guarantee as haven't used canon inks.
  • Anonymous Aug 02, 2008
    same trouble, onen solution : ink chip resetter...but it's not that  I want....I want a software solution...
  • Anonymous Aug 21, 2008
    same problem here, any advise would be appriciated
  • Anonymous Nov 08, 2008
    I have a Canon MP600 and am having the same
    "Ink tank errors have occured" .. almost always on the yellow
  • Anonymous Dec 13, 2008
    Yes I have same problem. Sometimes it says your black ink tank 5pgbk is not recognised and other times it tells me I have two black ink tanks, which suprise suprise!!! is correct! but it willnot print. Canon told me to replace the print head, I did at the cost of £40 even though the printer, a pixma mp800 was under a year old, canon would not replace it for me. Even after all that I still get the same messages. I replaced the tanks with three new canon tanks but it make no difference. I find their support very poor. jbl.
Reset Canon MP600 to the Factory Setting
  1. Press the HOME button.
  2. Use the Easy-Scroll Wheel or the right/left arrow to select Settings, and then press OK button.
  3. Use the Easy-Scroll Wheel or the right/left arrow to select Device settings, then press the OK button.
  4. Use the Easy-Scroll Wheel (B) or the up/down arrow to select Reset settings, then press the OK button.
  5. Use the Easy-Scroll wheel or the up/down arrow to select Yes on the confirmation screen and then press OK.
  6. Press the HOME button to return to the HOME menu.
Posted on Sep 12, 2009
Hi, I refilled cartridge CLI-526M fromCanon Prixma MG5250 and I have the error U130. How can I resolve the error to reprint? Thanks.
FAQ: An Error Message Is Displayed on the LCD
If an error message is displayed on the LCD, take the corresponding action described below.
The following ink may have run out. Replacing the ink tank is recommended. U041 Print head is not installed.Install the print head.U051 / The type of print head is incorrect.Install the correct print head.U052 Some ink tanks are not installed in place. U072 / More than one ink tank of the following color is installed. U071 The remaining level of the following ink cannot be correctly detected. Replace the ink tank. U130 The following ink tank cannot be recognized. U043 U140 U150 The following ink has run out. Replace the ink tank. U163 There are no photos in memory card Contact the support center or service center for ink absorber replacement. Press OK to continue printing Ink absorber full. Service required Timeout error has occurred The device may be incompatible. Remove the device and check the manual supplied with the connected device An unsupported USB hub is connected. Remove the hub. B200Printer error has occurred. See the manual **** Printer error has occurred. Turn off power then back on again. If problem persists, see the manual
Jul 06, 2011 | Canon MG5250 Printer
Getting the u150 error message too....
Hi ...
Error U150 normally comes in due to the ink tank ... Follow the below steps and I am sure you will be able to resolve this problem ...
I'll also tell you how you can find out what the problem is just by looking at the flashing ligh ...
Replacing An Ink Tank Use the following procedure to replace empty ink tanks or when an ink tank error appears.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
    NOTE: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  3. Open the inner cover.
  4. Press the ink tank's tab (1), then remove it from the slot (2).
  5. Unpack the ink tank and pull the orange tape off completely in the direction of the arrow and remove the film.
    Note: Tear the orange tape carefully along the dotted line. If the orange tape remains, printing problems may occur.
    <4> Tape is completely removed.
    <5> Tape remains. Remove the orange protective cap located on the bottom of the ink tank by twisting as shown in the diagram.
    Caution: Do not touch the ink tank contact <6>. Doing so may cause printing problems. Do not squeeze the side of ink tanks as this may cause the ink to leak out. Do not reattach the protective cap once you have removed it.
  6. Insert ink tanks into the print head.
    Note: Press the mark <PUSH> on the ink tank firmly until you hear a click.
  7. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note: Click for Ink Tank Lamp indications.
  8. Close the inner cover and the scanning unit (printer cover).
    Caution: When closing the scanning unit (printer cover), be careful not to jam fingers.
    ote: The next printing begins, the print head cleaning will begin automatically.
You can check the status of each ink tank according to the way its lamp flashes.
  • On: The printer is ready to print.
  • Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
  • Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
  • Off: An error has occurred and the printer is not ready to print.
Please vote if this helps ... Cheers :)
Jul 26, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP530 printer repeatedly getting LCD Error Message: "CHECK INK U071 5Bk". I have removed, reinstalled, reseated the 5Bk and all other ink tanks multiple times. Usually when this...
I have Canon M560 printer installed 8 months ago. I replaced the CLI 221 Magenta and CLI221 Cyan ink cartridges, won't work and got this message Error 1411. Tried repeatedly to reinstall the ink cartridges and still have this message coming back. Any solution you could offer? I would appreciate it. Thank you.
Nov 06, 2008 | Office Equipment & Supplies
Canon IP6600D Error Message U150
you need to reset the chip on the ink cartridge.......................
Aug 22, 2008 | Canon Pixma iP6600D InkJet Photo Printer
U150 error message
There was plenty of ink left in my Cyan tank but just replacing it with a new Canon CLI-8C one, as suggested by techguru005, did the job. I suppose that the chip must have been faulty?
Let's see how long this one lasts!
Thanks, techguru005, it's fixed for now.
Jun 16, 2008 | Canon PIXMA MP810 All-In-One InkJet...
How do I resolve Error U150 on Canon MP810?
have had a MP810 about 3 months. Recently I've been getting a U150 error message. My C tank is not lighting up and being recognised. When I open up and replace the tank the light comes on. Initially this allowed me to carry on printing but now I have a constant error message even after replacing the tank.
Is there a permanent solution to this annoying problem?
I would be grateful for any assistance.
May 29, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Feb 21, 2008 | Canon Pixma MP500 All-In-One InkJet...
Error code: U150 The following ink tank cannon be recognized (Cyan)
U150 ink error fixed!
I too was getting the error for unrecognized ink cartridge. Then the little green circ board fell out of the end of the ink cartridge and it hit me that maybe if I put in the little green circ board from the old ink cartridge of the same color, then maybe the ink cartridge would be recognized. It worked! So don't throw out an ink cartridge that still has ink just because of that error and hold onto your empty cartridges in case you need the little green/gold circ boards.
This works!
Dec 26, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
905 people viewed this question
old marine
old marine
