Question about Miele Dishwashers
Miele dishwasher g2220 sci showing error F84 What does this indicate and is there a solution
5 Suggested Answers
SOURCE: Miele GS2220 Sci error message F84
Call Miele they will send a copy of the instructions booklet, I did and I got one
Posted on Apr 23, 2008
Krazytech
  • 725 Answers
SOURCE: i have a miele g2220
the clogged circulation pump (error code F14)
Posted on Jun 16, 2008
  • 70 Answers
SOURCE: f84 error on miele dishwasher G2534SCI
Hi
On that model to save water and energy water is sent to bottom and middle spray arms alternately. This is done via a shutter in the circulation motor. F84 mean this shutter is jammed,Most likely with debris,But is possible motor is faulty
The motor will have to be removed be sure
Posted on Feb 01, 2011
SOURCE: F84 Error code Miele
Hi, I have a problem when you turn on dishwasher MIELE G1730SCI after a minutefault F84 is displayed, what could this mean?
Posted on May 13, 2011
F84 error on miele dishwascher miele g2530 sci
There is a slide valve in the machine that directs the water to the upper and lower arms. The valve can become plugged or the signal to it can become lost. The machine is not an easy one to repair and you can do more harm than good if you don't know what you are doing. To give you an idea, you have to remove the machine and turn it upside down to work on it.
Apr 18, 2015 | Miele Dishwashers
Miele Fault Code F84
Slide Shutter Positioning Fault
Miele Fault Codes
If a F84 is displayed (Slide shutter positioning fault)
The electronic board is unable to read the position of the slide shutter through the position switch. This fault is displayed when attempts to position the slide shutter have failed. See F63 (Slide shutter fault) for troubleshooting steps.
Miele G1000 Technical Information Page 219
Occasionally our Miele Dishwasher pops up with a F84 error mid-cycle and stops. I've checked filters, discharge pipes, etc.
An post in the Whirlpool archives had links which suggested the fault was to due to an internal "slide shutter valve".
http://appliancehelponline.com/miele.html
So you can read your self a link to the post; whrl.pl/RbrkDJ
I finally found a small object lodged in the ball-check-valve on the discharge of the water pump. Once removed all has been ok.
To access the check valve, remove the screen at the bottom of the unit. under the screen to the left of the water well is the cover of the pump. It has two small plastic "leaves". grasp, squeeze together, and push to the right, towards the centre of the water well. You will have removed the pump discharge and within it are rubber seals and a stainless steel ball. You can peel out the black rubber seal remove gunk and refit. Take care not to damage the seal and to replace it fully.
http://forums.whirlpool.net.au/archive/2140916
Dec 06, 2017 | Dishwashers
Miele G2220 sci ( no code showing) bottom arm not spinning not sure if it's spraying water though, any thoughts
Try running vinegar through the cycle hard water will keep water from getting through. Just try;
Jul 11, 2014 | Dishwashers
F84 error on miele dishwasher G2534SCI
Hi
Jan 14, 2011 | Miele Premier-Plus Built-in Dishwasher
I have a MIELE with a " F84 " falt code please help Thanks Phil
Hi
Aug 04, 2010 | Miele G848I Dishwasher
What meens the problem F84 for miele dishwaser?
Hi
Jun 10, 2010 | Miele Premier-Plus Built-in Dishwasher
Miele dishwasher stopped, F84 flashing please help. Maureen
In most cases this means the circ pump is faulty - suggest calling a Miele service rep
Sep 02, 2009 | Miele Dishwashers
This problem arises because the water inside the washer cannot get out.
Firstly......Make sure the salt cover if screwed on tightly (if you have one).
Then remove the filter(s) from bottom of the washer and clean.
Remove the drain pump cover and remove the one way valve (a ball bearing in a housing) and clean. Take note of rubber cover direction before pulling it out to clean.
Make sure the impeller (visible after you remove drain pump cover) is clean and spins ok. It will have a little resistance as you spin with your finger.
Make sure all is cleaned properly and it will all work fine again after replacing it all back in.
Jul 27, 2008 | Miele Premier-Plus Built-in Dishwasher
Nov 18, 2007 | Miele Premier-Plus Built-in Dishwasher
Dishwashers Logo
104 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
