Gateway 42" plasma TV; model #P420142V5. No picture; green power light comes on, relay clicks for power-up, then clicks again. Picture never appears. Bad power module, picture module, etc? Thanks, Alex alex.jelepis@grubb-ellis.com
  • ajtarga Jul 12, 2008
    Thank you.
    Still reviewing solutions for my Gateway 42" Plasma TV; power clicks "on" then "off" again quickly; no video/audio.
    Main power board and "bulb" were suggestions.
    Thanks.
    AJTARGA
  • 4,889 Answers
May be it just some bad fuses on the power board. Look for burnt ceramic fuses and see if you can find any. Also look for bad solder joints or burnt capacitors. IF none of these work then its time to get a multimeter and check the voltages across various components on the powerboard and comparing them with the values in the service manual suggested by Darklord.
Hope this helps,
Sai.
Posted on Jul 12, 2008
    Genius:
  • 1,011 Answers
Sir,
Shop Mode is an automatic picture setting intended for retailers todemonstrate functions to customers. Shop Mode returns the picturesetting to Dynamic Mode within thirty minutes, thereby saving theretailer from having to manually reset the TV.
If you have a 2007 Samsung TV (HPT series, FPT series, LNTseries, HLT series, or TXT series) and your picture setting keepsreturning to the Dynamic mode, it probably means that your TV is set toShop Mode.
To check if your TV is in Shop Mode, press Info on your remote. If the picture mode says "Shop Mode", do the following:
  • Press either the Up Volume or Down Volume control on the TV. The Volume bar will be displayed.
  • Press and hold Menu on the TV until "Dynamic Mode" is displayed (about 7 seconds).
  • Press Info on your remote and confirm picture mode says "Picture Mode: Dynamic".
Shop mode can be enabled/disabled from the Setup Plug & Play menu and also from the service menu.
Thanks
Good luck
Don't forget to rate the solution
    Genius:
  • 1,447 Answers
Hi-
Replace the bulb- seems you have a busted bulb on your TV.
Thanks for using Fixya
  • 2,427 Answers
Its a Main Board problem thats causing the safty to trip, If you have eletronic skills here is the service manual and schemetics
http://www.sharefx.com/index.asp?tab=tab5
if you do not have experience in this field
WARNING THIS CONTAIN HIGH VOLTAGES WHICH CAN KILL YOU
take it to a certified technician
I
  • 1 more comment
  • Rishi Roshan Ali Jul 12, 2008
    Dont forget to vote or rate the expert who helped you, or if you need further information please ask
    I doubth the back light will trip the safty,, Besides it will go on and off before it actually goes..
    The backlight controlls the screen to allow you to see the picture on the screen ,, it wouldnt cut the audio and surely wouldnt trip the safty as there shouldnt be any sensor of feed back from ut
  • 813 Answers
It depends where the line is centered most, to the right or left of the center, there are buffer boards that control the vertical video, on the bottom part of the unit if you take the back off and look at the bottom part of the set you will see these address boards, they are usually about 2 inches wide and could be labeled J or K, if the unit is High Definition then you could have these buffer boards on the top part of the unit also
  • 19,396 Answers
Do you gate flash light blinking, if yes, how many times?
  • Ginko
    Ginko Jul 12, 2008
    You should get light flashing a certain number of times, to diagnose the problem.
    If the tv shut down immediately without returning the flashing code, then it is probably the power unit faulty (short overvoltage, burnt comp[onent etc.) causing the safety switch to turn off tv immediately.
    The tv should be tested thoroughly to find out the fault.
I have a 2002 42 inch Plasma made by Gateway I can power up but tv clicks back off without ever showing a picture-the green power light remains on but no sound no pic-I used to be able to unplug and p
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to plasma screen are given with illustrations. You can get an idea about the fault to an extent. It is not easy to include all here by this window.
Dec 04, 2014 | Gateway GTW-P42M303 42 in. Plasma...
Gateway 42in plasma p420142v5
try check its settings, maybe its not configured properly..if you have remote control on it, locate the menu button then go to picture settings or video settings then adjust the contrast, brightness, and the color of course to your desired level..
Jan 24, 2008 | Gateway GTW-P42M303 42 in. Plasma...
BUSH 42" plasma no picture or sound?
You have a power supply problem, replace the Module.
What you ear is a click relay No juice to activate the relay
Some cups may be dried.
Nov 01, 2012 | Bush Furniture Bush My Space Rhea 42 in....
2006 42" plasma has blank
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Apr 23, 2011 | Philips 42PF9630A 42 in. Plasma Television
The first thing to check would be swolen ccapacitors on the power board. replace them if so.
Oct 31, 2009 | Televison & Video
Samsung PDP Module S42AX-YB01; no picture, sound ok
If you go to www.encompassparts.com and click on guest log in and do a part number search with the numbers you have listed, except use LJ41-02761A, and it will give you the cost and such.
Sep 07, 2009 | Gateway GTW-P42M303 42 in. Plasma...
Plasma Hyundai 42'' TV ,NO SOUND OR PICTURE
most times then not it's the capacitors on your power board that blew there for not supplying the tv with enough power if you open it up and check the capacitors it should be leaking some kind of liquid or the tops have bubbled up. its an easy fix cost>>2 dollars each
May 21, 2009 | Televison & Video
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Televison & Video Logo
149 people viewed this question
Top Televison & Video Experts
Electro Med Services...
