Question about Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher was leaking; now gets "stuck" 3 minutes after starting
Our Bosch dishwasher is 6-10 years old or maybe even as old as 15 yrs(was in the house when we bought it 4 yrs ago). Over the past year, it has occ. leaked water from the bottom or sometimes has gotten stuck in the drying cycle. Over the last week, it was leaking huge amounts of water everytime we used it. Now it gets stuck about 3 minutes after we start it -- it never really gets going, the water never gets going. We've checked the fine filter and rinsed out the spray arms and this did not help. We are wondering if it is worth fixing or if these problems are major and we should purchase a new dishwasher. Thanks!
  • 833 Answers
You're describing a number of issues related to old age and maintenance. First, you've likely got a mechanical timer that is getting stuck. If the price of replacement is outside your budget for an old warhorse....
Second, in come cases, the timer takes care of water level...in most, however, there is a float or aeneroid level sensor. If it is a float...it may be clogged/jammed with detergent or debris. Located in the wash tub near the front. Clean it up. If it is an aeneroid, it has a tube going from the tub to the lower part which hooks into a 3 inch or so flat sided round item with two wires coming out. With the power off, test it by blowing and sucking on the tube. Blowing into it should open the switched leads ...sucking should hold a 'vacuum'. The pressure of water opens and closes this switch to determine water level.
Posted on Jul 18, 2008
I currently own a BOSCH Dishwasher approx 2.5 years old. It just runs for 3 minutes then stops and starts again - red LED light by Tap icon flashing
Hi, that sounds like you have a fault in the water inlet valve. Best get checked or replace the water inlet valve.
Mar 27, 2016 | Bosch Dishwashers
My Bosch dishwasher is not draining water and thus leaking on the floor. It is 7 yrs old but only has been used for 3 yrs as I was away. It was run weekly in my absence. Any ideas?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 07, 2010 | Dishwashers
My bosch dishwasher started to leak. Why? It is about 8 yrs. old.
it depends on the location of the leak.check the seal, check to make sure the unit is draining,check to make sure the drain hose doesnt have a pin hole in it.
Mar 11, 2010 | Bosch SHU9915UC Dishwasher
3 yrs old model; worked fine then no lights on front panel
i hate to tell you this, but more than likely the circuit board behind that light has gone bad. It is a costly fix at several hundred dollars, and this isn't the first one i've heard that has done this...
Mar 13, 2009 | Bosch Evolution 300 SHE43M0 Built-in...
Bosch Dishwasher SHU43C02UC
Unplug from mains for 5-10mins. Are you having any power difficultys? sometimes this can crash the controller.
if none of the above possible that its the controller
Jan 03, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU43
Sounds like the control module is out -- cost about $100 (I am on my third). I got a "lifetime" warranty when buying my second one. If you are handy, you can replace it yourself. You can call Bosch to confirm this (I did). It mounts inside the door. Mine is a BOSCH 5316.
The draining problem may mean a clogged drain hose -- you have to check it all the way back to either the main drain or the garbage disposal (if you have one). This may be what forced off the impeller wheel.
Nov 15, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
170 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
