Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Power issue Unit will power up for about 10 seconds, green light is lit on power button, but the screen is completely black. After 10 seconds it shuts down, and will not power up again for about 5 mins.
  • 4 more comments
  • jbrown28 Jul 13, 2008
    Mine started doing the same thing this morning. Anyone have any ideas?
  • ceomus Jul 13, 2008
    im not getting any power on my d52w20 any suggestions
  • goldenskyz Jul 15, 2008
    Same problem! When the power button is pressed there is a click (relay maybe?) and the LED will come on for about ten seconds and then shuts off. Pressing the button again yields same results with or without unplugging/replugging first. Superficial investigation seems to indicate my TV is effed up (and most likely a power supply issue.) Good luck!
  • bigred777 Jul 20, 2008
    MY TV POWERS UP AND CUTE RIGHT OFF NO PICTURE NO SOUND SCREEN IS BLACK
  • mjo814 Jul 21, 2008
    I took it in for repairs, and the tech found multiple loose solder connections. $140.00
    I took it in or repairs, and the tech said there were multiple loose solder connections. The repair was 150. I picked it up took it home, and it's doing the same thing. The staff at this repair shop are very professional, and I think the problem will be resolved after I take it back.
Same thing, comes and goes; there are times that it would not come back on for 10-15 minutes... any ideas
Posted on Jul 21, 2008
I have a Nabi that all of the sudden even if the green light is on saying its charged the screen stays black
Sounds like you have a good charger/cable, so try resetting the Nabi that's giving you trouble. Hold the power switch down for 10-20 seconds to reset the unit.
I have a couple of NABI-2 tablets and they both react differently to the charging cables; I often have to shut the NABI off completely to charge them. Also, getting the charging cable to connect can be challenging - I will plug the cable in and out several times waiting 10 seconds or so to see if the green LED will go red.
Dec 31, 2014 | Nabi 2
DSC-HX5, Lens is Stuck in Zoom out mode. Turn On works but screen stays black. Automatically turns off after 10-20 seconds.
Since there is nothing you can do to fix this at home you have 2 choices, replace the camera or send it back to the manufacturer for exchange (very expensive)
Jul 27, 2017 | Sony Cyber-Shot DSCHX5 Digital Camera
We were playing a game and the tv screen went black then we ejected the game and the wii console will not shut off and now it wont play a game or nothind then we tried to unhook it and the light stayed...
Power light is green or orange - TV screen is blank
    If the power light is green or orange and your screen remains blank, follow these steps.
    1. Completely power down your system by pressing the power button for 10 seconds. If that doesn't work, unplug the AC Adapter from the Wii for a moment, then plug it back in.
    2. Make sure your Wii console has the most current Wii system menu. Download the latest update (how to), and then test your Wii console to determine if the problem has been resolved.
    If you continue to experience this issue, there is a problem with the Wii console and it will need to be repaired.
Jan 27, 2011 | Nintendo Wii Console
Panasonic PTL500U LCD HiDef projector. Unit occasionally powered up briefly, lamp lit, then shut down, standby LED flashed orange/red. Sometimes lamp lit and sometimes not. Technician diagnosed bad ballast...
If you take the back off you might find a couple of bulged electrolytic caps on the power supply board that need change, or just buy a new power supply at www.partstore.com
Dec 22, 2010 | Televison & Video
I have a Graco baby monitor, it started making a noise for the last 2 days, could it be a battery problem (even with power connected)? The monitor is about 1.5 years old.
Annoying! happens to us too frequently, but this works. We ended up buying a new one and returning our broken one after owning for three months From Manual:) 5. Turn on the Nursery Unit using the On/Off switch on the side. The green power light should come on. 6. Within a few seconds, the Parent Unit will lock on to the Nursery Unit and the top four (4) green LEDs will shut off. A second later, you will hear a series of beeps and the connection LED should change from red to green. Your monitor is now ready for use. 7. If the top four (4) LEDs do not shut off, power off the Parent Unit and the Nursery Unit and repeat steps 4 and 5 above. 8. If the connection LED on the Parent Unit does not change from red to green and the unit begins to beep, press the channel "ch" button on the Nursery Unit. Within a few seconds, the Parent Unit should lock in on the Nursery Unit and the connection LED should change from red to green. You may hear an audible beep during this process. 9. If the Parent Unit is still unable to lock in on the Nursery Unit (connection LED will be red and the unit will beep), power down both the Parent Unit and the Nursery Unit. Wait for 10 seconds then hold the volume down button on the Parent Unit while pressing the On/Off switch. When the unit powers up, you will hear a single beep and all of the soundlights will illuminate. Release the volume down switch and within 2 seconds you will hear two beeps and all of the Sound Light LEDs will stay lit and the bottom LED will be red. 10. Repeat steps 5
Oct 12, 2010 | Graco Baby Care
I have a jl 500/1 . The distribution block is lit showing 12v plus. no green power light on the amp? I disconnected pwr and ground and reconnected. the green light came on for 10 seconds and shut off. all...
The amplifier will not power on unless/until it recieves the turn-on signal from the head unit.
It seems the issue is with the head unit in this case.
Check the fuses and verify constant and switched power with a multimeter.
Once the Head unit powers on - the amplifier should also.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 18, 2010 | Jl Audio 500/1 Car Audio Amplifier
Acer extensa 4420 won't start
I had problems getting an Acer Extensa 4420 to boot or to enter bios. It would never complete the post. After taking it apart, changing the CMOS battery and making several other adjustments I read that a faulty DVD would cause the problem. I removed the DVD and it went right into Windows VISTA. So I put the DVD back in and had the same problems over again. The issue is a faulty DVD and has nothing to do with the motherboard, or the CMOS battery, or any of those other complex issues. It is simply a faulty DVD that refused to allow POST to proceed.
Jul 08, 2009 | Dell Inspiron 6000 Notebook
Green Screen, No Sound, Shuts off after 10 seconds
Almost certainly the green picture tube is shorted. This is a very expensive repair; probably not worth doing.
Apr 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Doesn't boot up
try it pluged in without the battery, does it turn on?
when it shuts down, does the power light stay on? or is it just no display?
Jan 04, 2008 | Dell Latitude D600 Notebook
Magellan 2200T won't completely boot up
Reset unit, and then turn off, but hold power button for at least 10 seconds, then power back on, and when ever you turn off unit, hold power button for 10 seconds, had the same problem with mine, this solved it, it seems that just turning off the unit till screen shuts down puts it in a sleep mode. Hope this solves your problem.
Dec 18, 2007 | Magellan RoadMate 2200T GPS Receiver
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
67 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
