Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Kenmore side by side 596.76522500
The unit both freezer and refrigator shut down totally - the only thing that works are the lights.
VANMAN69
  • 23 Answers
SOURCE: freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Posted on Jun 29, 2007
SolutionGuy
  • 331 Answers
SOURCE: Kenmore Elite refrigator side by side Model # 10655602400
Boomdog, the problem with your fridge is the temperature control board (where you adjust temps at in the fridge section). I serviced one of these just this week for the same problem! It's working fine now. They'll need to bring a control board with them to finish this job. The part number for it is #8201659. Be glad you won't have to fork over the cash to buy it, the retail cost is ~$165.00. Unfortunately, all of my vendors tell me this board is a factory backorder item. Maybe Sears will have it, maybe not. Also, after the repair is complete, please connect your computer controlled appliance up to a quality surge suppression/arrestor device. We highly recommend this one... http://catalog.belkin.com/IWCatProductPage.process?Product_Id=124911
Posted on Aug 11, 2007
SOURCE: side-by-side kenmore coldspot is warm
I would unplug ref. clean the condenser coil, install a 3n1 start relay on the compressor.
Posted on Nov 05, 2008
jumptrout51
  • 3361 Answers
SOURCE: kenmore refrigerator will not shut down,,0 deg. freezer 39 refrig
Replace the defrost heater and thermostat in the freezer compartment.
Posted on May 23, 2009
  • 9 Answers
SOURCE: side by side, freezer hot, refrig. hot
PURCHASE Troubleshoot refrigerators video at https://www.applianceuniversity.com/store/products/Secrets-of-T%7B47%7DS-Refrigerators-%231009.html
Posted on May 25, 2009
My Kenmore Elite refrig./freezer (2 doors refrig on top, 1 pull out drawer freezer on bottom) is not working correctly. The front panel where the temps are set, light, etc. now has flashing lights that...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 11, 2010 | Kenmore Refrigerators
Kenmore refrig/freezer. freezer side is cold,
Check your condenser coil (should be below the refrig.). If dirty, you can clean it with a condenser brush from Home Depot or Lowe's. Turn the appliance off while cleaning. Be careful not to damage the refrigerant tubing (copper). If this doesn't solve the problem, then there may be an issue with the defrost thermostat, defrost heater(s) or the main temperature control assembly.
Contact an appliance service company.
Feb 17, 2010 | Kenmore Refrigerators
I have a Kenmore side by side refrig (no ice maker) Freezer works fine. The refrigerator side is not cooling. I have cleaned out the vent between the freezer and the refrigerator section by defrosting the...
Check to make sure the evap fan is running.
IF so, then let unit defrost, then turn back on, check for air comming thru top of refrig vent, if air moving ok, then let run for a few days and see if refrig warms again, if so then check for frost build up on back wall of inside freezer, if so, you have a defrost problem. With a defrost problem, defrost heater may be bad, defrost timer/electronic control may be defective. Either way, in most cases it is a defrost problem unless you don't have air moving and fan is running in this case you have a damper door problem inside air duct in refrig.
Sep 30, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator is not getting cold
Unplug it and let the freezer thaw for a day - there is likely ice buildup between the freezer and refrigertor side - which is not letting cold air get to the refrigerator side. Remove all food from the freezer and the refrigerator, and let the freezer totally defrost (allow 24 hours with the doors open) then plug it in and you should see a noticable difference. If that does not work, the fan could be bad. There are two fans, one in the back of the fridge down low on the outside, and one in the freezer behind a back panel on the inside down about half way. Try the defrosting first which should be the solution, and the easiest fix.
Aug 15, 2009 | Kenmore 53642 / 53644 Side by Side...
Refrig/freezer not cooling/freezing
your gonna have to let thr fridge defrost buy shutting it down because it soundsm like you have either a build up of ice it the vents in the back of the frezzer unit also check to see if you can hear the fan working in the frezzer if not that would be you main problem
Jul 26, 2009 | Freezers
10 year old refrig cools only if freezer temperature is on maxium
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 18, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Water collects on shelves in refrig.
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Nov 26, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Freezer works, refrig does not cool
hi they only thing that could cause this problem is dirty coils at the back.clean all the coils at the back. thanks the appliance doc.
Oct 17, 2008 | Kenmore 50522 / 50524 Side by Side...
Kenmore top freezer unit-refrig not cooling past 50degrees
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 03, 2007 | Kenmore 64802 Top Freezer Refrigerator
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
43 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
