Remote control for sky
The code for a toshiba 36zp46p to set up the sky remote so that it works the tv as well.
Thanks david
  • dmwhard Jul 14, 2008
    Thankyou guys I shall try the codes out, thanks again
    Scholar:
  • 133 Answers
I own a One-for-All universal remote (model URC-4220), and my booklet says the setup code for a Toshiba TV is one of the following numbers: 0060, 0154, 0156, 1265, 0695, 0845,1145,1045.
Hope these numbers help you out. Please take a moment to rate this info, by using the rating system below. Thanks.
Posted on Jul 13, 2008
  • Pileated Joe Jul 14, 2008
    Another website which specializes in sky codes says one of the following numbers is a setup code: 0156, 536, 063, 271, 098, 117, 232, 530, 581, 130, 473, 088, 182, 064.
Program toshiba remote RC_3910 to sky remote need code
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Mar 04, 2014 | Televison & Video
Sky remote code for my bush lc-46gl12f tv I've tryd all of sky's codes and no luck please help
try this...press TV on your sky remote now hold select and red button until it flashes tvice,now enter this code....1430...after u enter that code it should blink twice again,now press standby,if it turns your TV off,press select to save these settings, it will also control your TV volume...Let me know if this helps
Feb 09, 2013 | Televison & Video
Hi, what is the sky remote code for Toshiba TV model 32BV500B? Thanks.
I've found two codes that work fine on a revision 8 Sky remote control and a revision 8r remote:
0056 (LG/Goldstar)
981 (General reset)
Both codes enable volume, channel selection and power on/off.
Nov 11, 2010 | Toshiba Televison & Video
Unabel to use sky control for sound
You have to programme the correct code for your TV into the Sky remote.
You can get these via "Sky Active" (if your box is connected to a phone line) or from the Sky website, or google search: "Sky remote codes".
However your sky remote wont necessarily control more recent televisions unless you have a REV8 remote control. You can check this by taking the battery cover off your remote and looking at the sticker inside. If it says RC1600/00 you're probably not going to be able to control your TV. REV4 and REV6 are more likely to work - but not guaranteed. If it says REV8, then you are probably not using the correct code or you're not programming the remote correctly.
If you have REV8, the correct code for your TV (according to Sky) is: 0678 or 1678 or 0254
Sky remote code finder page is here: http://sky.uebv.com/
Sky guide to finding your remote code and programming remotes is here:
http://www.sky.com/helpcentre/tv/sky-remote-control/program-your-sky-remote-control-to-work-with-your-tv/
Please rate my solution if you find this helpful. Thanks.
Oct 13, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Batteries changed sky + remote now does not work - TV Toshiba. Do I need a code to align my remote to my tv again?
Yes, very often after removing the batteries to replace them in a sky handset, you do need to re-code the hand set to your type of TV. Refer to your user guide for the code number for your type & model of TV.
Jul 22, 2009 | Sky ARF E- Belt CP Collective Pitch...
Sky remote code fo LCD LE40A456 TV
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Samsung Code: 0060
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Jan 26, 2009 | Samsung HP-R5072 50 in. Plasma HDTV
Sky remote control code for LG tv
Can you provide me with a set up code for my Sky remote control to work my LG LCD tv model no. 32LG3000?
Many thanks
Jan 09, 2009 | Televison & Video
My sky remote wont control the volume on my tv
Hi Re Easytouch 42" HD TV - look for Hisense - I took a guess and LCD3204 EU code 376 - remote works but buttons don't tally up - getting there slowly!
Just bought a madeforyou 4:1 remote that is programmed on my PC.
Ok - not proper solution yet but nearly there!
Dec 19, 2008 | Televison & Video
Mirai TV remote control set up code
does anyone know the codes for a mirai tv for a universal remote
May 07, 2008 | Jensen TS2750J TV
Sky remote code for lg 37lc46
for sky plus remote ver 8 the code four number is 0206
the three number code is 206
Nov 16, 2007 | Televison & Video
Televison & Video Logo
186 people viewed this question
Top Televison & Video Experts
