Question about Kenmore Oasis HE 27062 Top Load Washer
Kenmore Washer , Model 11027062600 , top loader
I am getting error code "DL" how cna i reset it, if posible
Thanks
    Guru:
  • 462 Answers
A Drain Limit, I suspect. I see these codes but haven't been able to find a legend or anyone that can confirm what it is. Does the tub sit with water in it and it doesn't drain?
Try turning it off and back on. If that dosnt do it try unplugging the machine and back in then on.
Is the Drain line kinked? Does the motor turn and run?
If this helps you please rate me accordingly if not please post back as to what DL is if you find out. THANK you.
Posted on Apr 01, 2009
Kenmore elite model # 110.45088400. We set a cycle, washer starts beeping and reads F then blinks to DL. We hit pause to clear then try to restart while it makes clicking sounds and it continues to read...
'DL' stands for Door Lock error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 24, 2011 | Kenmore Elite 45986 Front Load Washer
Hello, I have a Kenmore Elite Oasis washer model
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!!!!!!!!!
Jun 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Balance is off, how do I dissassemble the agitator on the Kenmore Oasis HE model # 11027062600
See the following Whirlpool Cabrio Service manual. The Oasis is basically the same machine.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Apr 18, 2010 | Kenmore Oasis HE 27062 Top Load Washer
Door will not stay locked keeps displaying dl error
Mar 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Lid lock will not lock.Getting "dl" error.
Oct 25, 2009 | Kenmore Oasis HE 27082 Top Load Washer
I have a Kenmore Elite Washer model 48051. I am
i think the dl code is clogged water pump,tip it back and you can remove the water pump cover and check it-mike
Jul 17, 2009 | Kenmore Washing Machines
The error "dl" continually comes up and we cannot finish a load of laundry
Jul 01, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Code f dl
If you already replaced the latch, and still get fdl, then the problem is wiring harness to timer board or timer board connections, check them out.
Apr 11, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Oasis has error code dl
The dL error code is a door lock error. The control board will attempt 6 times to lock the door before displaying the F dL error code. This is an indication that either the door lock is malfunctioning or the control board is not responding to the door locking circuit. Be sure the door is securely closed before attempting to start the washer. Open the door & check for clothing or something that may be stuck in the door boot area. If the door is securely closed & you still have the error code I would recommend having the door lock assembly replaced.
Good Luck and Please rate
Jan 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
DL flashes over and over
unplug machine for 2 minutes this will reset the computer if problem continues look behind bottom front cover and there is a tech sheet that will tell you what the f code is the DL code is bad door lock assembly. it could be the main control (mother board throwing you these codes) Ive seen this happen before
Dec 14, 2007 | Kenmore Elite 45986 Front Load Washer
Open Questions:
See all Kenmore Oasis HE 27062 Top Load Washer Questions
Kenmore Oasis HE 27062 Top Load Washer Logo
202 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
