Question about Asrock K7VT2 Motherboard
Trouble shooting of motherboard
When on pc, the computer is working in a little time and after it becomes to off mode
    President:
  • 2,351 Answers
Hi thayal, systems shut down because of over heating. This is normal so nothing burns up. Try opening the case & clean the CPU fan. Remove any & all dust from the fan blades. Use a clean non used paint brush to help loosen any dust build up. Than blow the entire system out with canned air. Blow out the power supply as well. When finished put the case back together & see if the system shuts down.
Luck!
Mike
Posted on Jul 12, 2008
What Could Cause My Computer To Shut Down For No Reason?
What brand of pc is this? Download a diagnostic program to test internal functions. Sounds like maybe a motherboard or power supply issue.
Jul 28, 2014 | Dell Inspiron 530s Desktop Computer
No picture when computer on,can hear sound,that's it.
perfect example of why All-in-one PC ****. There is little you can to to trouble-shoot. You COULD get another VGA (blue-connector,) monitor and plug it into the back...see if it works. If it does, then there is a problem within the monitor itself and you can only take it to a repair shop....or keep using the other monitor lol
If it does NOT work, then there is a problem with the Graphics processor on the motherboard and you cannot fix that w/o replacing the motherboard.
Aug 22, 2012 | MSI Wind Top AE2010 AIO All-IN-ONE Desktop...
Voltage from the Power jack is not powering up the computer or charging the batteries
Sadly FIXYA has no idea if or where you will find either of these requests . keep searching thru Google
Dec 23, 2017 | Gateway DA0MA2MB6D8 6000 and M360 Series...
I have alot of problems with my desk top
hi good day
if you have knowledge in computer trouble shooting you can easily fix the problem since mostly component in pc are almost card you can replaced any time. no need more tools just simply know the trouble of the desk top you can fix it .
Aug 28, 2011 | Acer Computers & Internet
My laptop display turns pink in color. It becomes normal on its own sometimes. I connected to an external display and it is perfectly fine.
Two possibilities:
* malfunctioning video-adapter inside your computer;
* some of the "data" wires between the motherboard and the display are only working "intermittently".
If the latter, take the computer to a qualified technician, for disassembly and trouble-shooting and repair.
Sep 17, 2010 | HP Pavilion dv2000t Notebook
My computer turns on and once it boots it turns off
It could be many things.
You must trouble shoot.
Try starting it in safe mode.
If it starts, then system restore it.
With such little info, there is no telling what the problem is.
I had that problem when I over clocked my pc.
If u can not get it to stay on,
reset the bios to a default.
Hope this helps u.
Mar 15, 2010 | Acer Aspire One Netbook 8.9" Notebook
My lan is not working
I see this issue frequently with on-board LAN cards. Do not waste your time trying to trouble shoot this. A lot of times the on-board LAN card burns up. If you have reinstalled the driver and it is still not working. Why trouble yourself. Go purchase a PCI NIC open the desktop and put it in. Then go into your BIOS and disable your on-board lan. Good luck.
KingPin Computers
Jan 06, 2010 | ASUS A8V-VM Motherboard
Shooting/playback mode switch
in the end it was my memory card which suddenly went faulty.after formatting it, (see above added comment) it worked for some pictures then i switched to playback and this time it said memory card error and shut down. well if it would have said this in the first place would have saved a lot of trouble i almost threw the thing away.(the camera) so i puts a new card inside and its working like new, all the playback i can handle. goes to show its not always as bad as it looks with a little patience.....merci
Feb 27, 2008 | Canon PowerShot A520 Digital Camera
Compaq presario 158793-001 motherboard
Hey Mike
Go back and check the fine cabling that connects LED indicaters to motherborad. There's got to be a small cable you forgot to plug into the board to feed back poer state. Take your time and check everything twice.
Dec 12, 2007 | HP (158800-001) for Compaq Presario 1246,...
Screen becomes jumbled when computer base is handled
It could possibly be the video card, I don't know that much about how hardware is laid out in that model, whether it is an built in card or a connected one so I cannot give you any trouble shooting tips. Do you still have tech support available with Gateway?
Sep 09, 2006 | Gateway 450SX4 Notebook
Asrock K7VT2 Motherboard Logo
71 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
