Question about Pioneer HTD-510 System
TV sound just quit.
I had this system for 9 years and all of a sudden the TV AUX wont work. Has this been a common problem? Any solutions?
  • 3 Answers
Try plugging the tv input into the AUX input.
Posted on Mar 12, 2009
Plasma tv repair
Samsung 50 inch plasma wont turn on - YouTube
? 0:59
https://www.youtube.com/watch?v=Uo-SazF_G9Y
Jan 9, 2014 - Uploaded by 8Jallin
Samsung 50 inch plasma wont turn on ... samsung plasma tvnot working, wouldn't turn on, FIXED, repair, diy - Duration: 14:56. by Matthew ...
Plasma TV Repair Tutorial - Common Symptoms ... - YouTube
? 7:13
https://www.youtube.com/watch?v=gnkyAGyI7GA
Oct 9, 2013 - Uploaded by ShopJimmy.com
Plasma TV Repair Tutorial - Common Symptoms & Solutions - How to Fix .... Samsung 50" Lcd tv model#Lf501EM6f Im not sure if its plasma or ...
WHAT Plasma TV BOARD CAUSES NO PICTURE REVIEW ...
? 4:10
https://www.youtube.com/watch?v=DC_75FfrR9w
Nov 8, 2012 - Uploaded by Tampatec
WHAT COMMON PART / TV Board IS BAD ON SAMSUNG Plasma ... a gamble. it the cost of repair is over 300 just buy a new 50 inch tv for 600.
Samsung 50" Tv Power Supply Boar...$34.00eBaySAMSUNG UN60EH6002FXZA...$23.00TV Parts Guy42% price dropSamsung 50" Pn50c550 Pn50c45...$18.99eBay
Dec 21, 2015 | Samsung PN60F5500 60-Inch 1080p 600Hz 3D...
Philips home theater suddenly doesn't produce sounds
Sounds like the main amplifier section circuit inside the system is damaged. Contact any service technician, or the authorized service center for Philips.
Jul 13, 2015 | Philips Audio Players & Recorders
What would cause my speakers to just quit. I had them running through my receiver.
there could be a problem with the audio inputs on your receiver but just in case try switchin the speacker wire if that dose not work then try switching the input cables from the aux in to the tape or cd input jax if that dont work then the problem is in your curciut board and is probly ruined what can cause this problem is there are to many speackers hooked up and the receiver got to hot or the positive wire and the negative wire brobly gat crossed some where and shorted out your receiver input jax try the solutions i recamended and hope for the best i hope it works for you good luck
Sep 19, 2014 | Audio Players & Recorders
Why did my sound just quit?
Try turning off the device then unplug it then hold the power button in for 10 seconds then plug it in and restart it as a possibility
May 30, 2014 | Haier LEC24B1380 24 inch LED HDTV/DVD...
How to get system to play the sound from regular television.
Well this is a very common solution. Evry system has an AUX output and Every TV has the AUX input. All you have to do is connect the AUX output of the surround system to the AUX input that is found in your TV. Most tv's have this AUX input on its front or you might also find it on the rear of the TV.
Sep 12, 2010 | Philips HTS-3565 Theater System
2002 saturn l100 A/C wont work
ok ac system has a pressure switch that stops the compressor when freon is too low. they actually say it is ok for mobile a/c systems to lose a half pound a year. most a/c systems run on under 2 pounds of freon. so after 3 or 4 years some systems will just quit working. you are at 8 to 9 years so i would recommend you find an independant shop that will top off your a/c and see if it works again. this should not cost more that 50 to 75 bucks. If you were here that is what i would charge. I am in columbus ohio just to let you know. hope this helps and thanks for using fixya
May 06, 2010 | 2002 Saturn L-Series
My jvc tv doesnt make any sound
this problum solution is 3 type .
[1] Repaer tv sound section replace sound ic and canacting spaer
[2] Use extra amplifer or home theater system{AUX mode} canact with tv. A/Voutput pin .
[3] if you are use setup box or chenal convater then canact A/v Out{ L -R ] to AUX input . home theater or extra Amplifer system
selact any one option and enjoye....
Oct 30, 2009 | Televison & Video
No sound thru surround sound system in TV Mode
You need to connect your TV to the AUX connection in the back of your HT system. Then set your HT system on AUX 1 and wait about 5 seconds for the TV sound to come through. If it does not work on AUX 1, you may have to try on AUX 2 or AUX 3 settings on your HT system. Make sure the A/V cable you use is good and in working order and is a good quality cable.
Hope that helps, Gary
Jan 30, 2009 | Samsung HTZ-510 Theater System
Can't play AUX inputs through Panasonic surround sound
Check the TV audio output setting. There may be 3 settings for audio output. Fixed/variable/none. Try all of the settings, and see if you get your audio back. If not, try a different cable between the TV and DVD player. I suspect this is a red/white RCA audio cable.
Dec 12, 2007 | Audio Players & Recorders
Pioneer HTD-510 System Logo
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
