Question about JBL Spyro Computer Speakers
JBL spot series speaker not working.
I have the JBL Spot series speakers and recently my left speaker is not working. Anyone seen this before?
I know this is old but just incase anyone has the same problem. Its proabably the connection from back panel to the internal amp (Inside the sub enclosure). The ribbon cable has the + for the left speaker right at the edge with quite a bit of tension. Over time and with the vibrations from the sub this will bend/pull out slightly and needs to be pushed back on and some hot glue put around the connection to hold it in place.
Thats how I fixed mine anyway.
Posted on Feb 22, 2010
  • 3 more comments
  • John Doe Dec 18, 2011
    How did you open the enclosure?
    i unscrewed everything but its a nightmare to prod open!
    Hi!
    How did you manage to open the subwoofer.
    I unscrewed the screws and tried pulling and its not working.. :(
  • app_3rp1212
    app_3rp1212 Mar 11, 2012
    Had the same problem. When you unscrewed the bottom silver circle, it'll appear to be non removable but really its doable. Twist it around a bit pull it around the edges to remove it from the subwoofer. Then if you look close there will be 5 more screws, bigger then the ones before. They're not easy to get to and you'll probably damage inner silver circle just getting to it. Once those are out you can easily remove the top. The fix Maureen_mcgu mentioned worked for me too. Good luck!
  • app_3rp1212
  • MK Leung
    MK Leung Jan 05, 2014
    Thanks to you all! I can pull out the base silver bottom. However, I discovered that the foam surround of the speaker has cracked! Some pieces did fall out, rendering no bass. Is it replacable? Thanks.
    New Friend:
  • 12 Answers
The base stand in JBL Spot which is like spyro is removable. Its attached on three sides with sort of plugs which can be removed and put back. If you start with that then you can unscrew all rings all the way up and open the amp without damaging any ring.
Posted on Aug 24, 2013
  • Akshay Gehi
    Akshay Gehi Dec 28, 2013
    Did you try pulling out the bottom stand? You need to pull that out and then you can find your way up through the rings.
    New Friend:
I removed the 5 screws already but still can not open the subwoofer. Do you have any video or photos on how to complete this process?
Posted on Dec 28, 2013
  • Akshay Gehi
    New Friend:
This page was very helpful. Yes just pull the base. It'll come out.
Posted on Mar 15, 2015
I HAVE a JBL 180 SUBWOOFER and the soundlevel control has some flat spots where there is no sound so I believe the potentiometer needs to be replaced, So I unscrewed all screws holding the electronics box...
Is that really necessary? In most installations that pot is a set-and-forget control. Find a sweet spot and live with it. I've always gone into a speaker by removing the driver.
Apr 14, 2011 | JBL Venue SUB10 Subwoofer
Jbl platinium speakers wont work
On windows it seems you don't have the sound card drivers installed.
Get dell drivers from http://support.dell.com/support/downloads/index.aspx
May 22, 2009 | HP JBL Platinum Computer Speakers
JBL Creature 2.1 Left Speaker not working
Hiya
Too late to resolve the original poster's worries, I can assume, but I arrived here when searching on account of the same problem and resolved it. This is going to sound implausibly condescending, I'm afraid (and excuse th elack of technical terminology!)...
I couldn't get my left speaker to work exactly as above, but then looked carefully at the shape of the respective cables leading to the sub. You have to fit the triangle shape of the lead into the triangular shape of the hole. The speaker CAN be connected what *feels* like correctly, but is in fact connected incorrectly (ie, not all the way in).
This is more a problem with the left speaker than the right since it's a triangle and the right is a square, and can be a little fiddly.
Anyone else experiencing the same problem should probably take a quick moment just to check this isn't it! :)
Mar 05, 2009 | JBL Creature 2.1 Computer Speakers
Needed watts and voltage of JbL 5000 series platium speakers
If you have one already, just check the wattage on the power supply.
Feb 28, 2009 | HP JBL Platinum Computer Speakers
No Sound From Speakers
If you have another set of speakers or even headphones plug them into the laptop to check that the sound card is working.
Robert
Aug 26, 2008 | Audio Players & Recorders
Only right speaker working
disconnect all the cables and fix it again,then check the speaker sounds bychecking the sound settings in control pannel.
Aug 03, 2008 | HP JBL Platinum Computer Speakers
Sound Problems on my Dell
It should be having onboard sound card, check from Bio's setup whether the Audio is ON. also check in control panel sound and media devices and check the volume maybe it's very very low or on mute. Also try with other speakers
Feb 28, 2008 | HP JBL Platinum Computer Speakers
JBL Spyro Computer Speakers Logo
3,599 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
