Question about Zanussi ZWF1440 Front Load Washer
E 60 ERROR
MY ZANUSSI WASHING MACHINE HAS A E 60 ERROR MESSAGE DISPAYED WHEN SWITCHED ON.
SOME SUGGESTIONS ARE THE N.T.C SENSER ..... WHAT IS A N.T.C SENSOR AND HOW CAN I GET RID OFF MY ERROR
THANKS
GLEN
    Scholar:
  • 97 Answers
Hiya
this code maybe down to the heater or something heater related on the pcb. i would replace the heater first as this is quite a common fault with zanussi from what i've found, and is not a very expensive part.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Posted on Aug 05, 2008
Zanussi ZWD 1271 W - Error 33 (E33) machine drains after approx. 6 minutes of cycle - skips from 'wash' to 'drain' in the progress bar. Replaced with a new variable thermostat - hasn't worked! Help!
E33 - Inconsistency between level on electronic
pressure switch and level on anti-boiling pressure
switch 1(fault persists for at least 60 sec.).
  • Pressure switch defective
  • Electrical current leak between heating element and ground; Heating element; Wiring defective;
  • Main board defective.
  • Water circuit;
When is this fault occurs than will be performed emergency drain procedure, cycle stops with door unlocked.
Dado
Sep 24, 2015 | Zanussi Washing Machines
I have a zanussi 6hg 1200 rpm it's flashing error code E 60 what does it mean
Family error code E60 is visible to customers and (could be E61,E62,E66,E68 and E69 only visible in service mode) means problem with heating phase.
Possible failures : heating element faulty, NTC sensor faulty, PCB faulty, wiring.
Dado
Mar 24, 2015 | Zanussi Washing Machines
Eh0 error message during operation
need manual or need to know if washer starts and when it stops as this can identifie the problem
Aug 12, 2012 | Zanussi Washing Machines
ERROR CODE E 60 washing machine zanussi ZWG1100M
This can be due to error in the control board. Shut down and remove plug and when switched on press down the start/stop button. If the error does not clear this can be a fault in the motor drive within the control panel board.
Remove the panel and check the connections to the motor, check the motor and the capacitor to the motor or if the motor is jammed.
Jul 03, 2012 | Zanussi Washing Machines
Error message E50 shows when the machine is switch on.
Zanussi washing machines can sometimes display error code E50. As John Lewis washing machines are currently also made by Zanussi some John Lewis washing machines can also display error E50.
Unfortunately this is not a "proper" error code and is not listed in error code lists. It's part of the motor fault error code group and is apparently displayed to customers but when an engineer enters a special diagnostic display the "proper" error code will be displayed giving more information.
However, there are usually only two error codes beginning with E5 which are E51 and E52, which are "motor power triac short circuited" and "no signal from the motor tachometric generator" respectively.
So if you have E50 displayed on a Zanussi or John Lewis washing machine it looks like a problem with the motor. However, the E51 "motor power triac short circuited" could be a fault on one of the PC boards as triacs are usually on printed circuit boards. This could have blown due to a short circuit somewhere else (like the motor for example) - I would advise that an engineer is required if you can't see anything obvious with the motor.
Jan 09, 2011 | Zanussi ZWF1430W Front Load Washer
The door closes but the cycle won't start and an 'F4' ('door not closed') error message appears. Could it be a sensor problem? Can I fix it myself? Thanks for any suggestions.
Hi.
The problem is fixed replacing the door lock switch. In some less common case the defective part can be the wiring harness to door lock, or a defective electronic control.
regards.
G.
Oct 01, 2010 | Zanussi FJS1225W Front Load Washer
Error E20
zanussi error E20 suggests a pump/draining problem. remove pump/filter and clean it all out. its located at the end of the drain hose at the bottom of machine. power off. it might need replacement.
Nov 01, 2009 | Zanussi ZWF1430W Front Load Washer
Error 54 comes up when you switch it on
all error 50 messages relate to the motor.
Feb 13, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Jan 24, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi ZWF1440 Front Load Washer Logo
233 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
