Sharper Image Ionic Breeze GP SI720 Air Purifier
Problem for Sharper Image Ionic Breeze GP SI720 Air Purifier
Quadra - only red light goes on.
By bppopkin on Jul 12, 2008
Our ionic breeze Quadra electrostatic air purifier is broken. We cleaned the filter as always, and turned the housing up-side-down to remove any sediment. When we plug it in the electrical outlet, the cleaning indicator red light goes on. What to do? We live in Washington, DC. Thanks.
Same Problem
Nov 13, 2008
-   i have same problem.. there is also a burning smell -   Guest
Oct 21, 2008
-   I have the same problem, did yours ever work again?
Linda-   lr54
Solution #1
posted on Jun 16, 2009
Not Rated)
fireman_j
Rank: Guru
Rating: 90%, 52 votes
In addition to cleaning the plates on the cartridge, also turn the unit upside down then right side up a few times. There are 2 small wires inside the housing, and each has a ceramic ball on it that cleans the wire when the unit is inverted. Also, look through the vents to make sure the wires are not broken. If they are intact, they run in a straight line, almost the entire length of the unit.
If this does not help or the wire is broken, contact The Sharper Image. I believe this unit has a 5 year warranty. When mine failed, they exchanged it for free, even without a receipt.
Was this helpful?
Yes
No
Popular Solutions for Sharper Image Ionic Breeze GP
Questions and Unsolved Problems for Sharper Image Ionic Breeze GP
Do you recommend Sharper Image Ionic Breeze GP SI720 Air Purifier?
Answer
Answer
I need to get a replacement part - the two inside wires (coils) for model s1737 Quadra Ionic Breeze... (More)
Answer
One of the tabs at the bottom of the part that slides into the housing broke. Where can I get... (More)
Answer
one of the 2 wires in my ionic breeze broke after i had cleaned the blades and was trying to... (More)
Answer
while cleaning i lost the two conductors. Where can i find new ones?
Describe your Air Purifiers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Purifier Experts
Top Air Conditioner Repairmen
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
