Question about LG WD-12126RD Front Load Washer / Dryer
Lg wd-12331ad As with first guy on this thread, I've got a wd-12331ad. The machine is a condenser washer-dryer, with all-digital controls. I have the same issues (though drying performance is Ok for me): I have no Idea how to set the machine to "Just Dry". Meaning you can't put the washing back in the machine to dry if it starts to rain. Please help me! Also, the machine switches itself off when it's pause (e.g. pause while removing something to cure an uneven load or remove something while drying) This means you can't resume the program you were using, without starting from scratch! Any ideas?? I sent a message (2 weeks ago) on the LG support site, but the haven't got back to me... Thanks in advance. Will
  • 1 more comment
  • willdebeast Jul 12, 2008
    Some magic happened today!
    I got the thing (wd-12331ad) to dry without having to run a wash first!
    Also, I seemed to get it to do a spin only run...
    The way to get it to dry :
    (for a set time - I've not managed to get any of the auto-dry settings to work)
    from machine being off:
    > press the power button.
    > press the "Dry" button 'til "Time" lights up
    >>> press "Dry" again to get the desired duration
    > press the spin button 'til the spin speed shows blank/ the RPM light goes out.
    > press "Start/Pause"
    It will then dry for the number of minutes specified!
    Not perfect, I know but that's serious progress from where I was before; having to re-run a wash cycle to get it to dry anything...
    Something to note:
    - The machine worryingly sounds like it's starting to fill with water when you start the "Just Dry" program which scared me at first. BUT it stops after a second or so (I think it's just cleaning out the detergent tray so it doesn't bake any leftover powder)
    For "spin only" from machine being off:
    >>> if you press "Start/Pause" now you get a 13 minute 1200 spin cycle
    >>> press the spin button again and then "Start/Pause", it seems to drain itself for 1 minute
    >>> pressing spin repeatedly, cycles through the spin speeds.
    Things I don't know:
    - I don't know if you can combine spin and heat.
    - I don't know whether the auto-dry programs are available
    - I don't know what other programs are available from the "Dry"/"Spin" buttons
    ...So if anyone does any experimenting, please let us know the results, you never know, we might end up with a half way useful set of instructions! I'm starting to think the machine's not half as bad as it seems when following the manual alone.
    Hope that helps.
    Will
  • Anonymous Aug 29, 2008
    Wish I had never bought this dud. Too fancy with no results.
  • hgajardo May 19, 2009
    I just want the machine to dry after washing. I still don't know if the automatic cycle has drying cycle incorporated or not, but my clothes are still wet after it finishes, so I always need more drying and I'd love the machine to do that by itself. Thanks!
SOURCE: lg wd-3243rhd front load washer and dryer combo "le" error message
This web site has a copy of manual. I found it by searching in Google for: lg wd-3243rhd manual
The manual gives LE as meaning there is a motor overload, which may well mean a faulty sensor.
Note that the manual warns against putting stuff of the top of the machine because this can cause overheating.
Note also that CoolTech sounds experienced. I just read manuals.
Posted on May 30, 2008
SOURCE: LG Washing Machine All-in-One
> press "Start/Pause"
Something to note:
Hope that helps.
Will
Posted on Jul 12, 2008
MNTECH
  • 1543 Answers
SOURCE: Dryer will not Dry!
A conventional dryer uses 240 volts to heat air, which passes through the tumbling laundry, picking up moisture, which is then vented to the building's exterior.
Your dryer uses 120 volts to warm air, which picks up moisture from the tumbling clothes, which then passes through a vent pipe in the back right corner of the dryer where a cold water spray causes the moisture to condense, run to the drain, and then is pumped out of the washer/dryer combo. There is no exterior vent to the outside of the building. Drying with your dryer will take at least twice as long as with a standard dryer. You can wash large loads, but can only dry small loads, and the clothes will not be as dry when dryer is finished as they will be with a standard dryer.
All that said, to make sure your dryer is performing as well as it can, you might like to take the back cover off and check the elbow at the very left bottom corner (when viewed from behind) to make sure nothing is obstructing the flow of water under the tub to the drain.
Posted on Aug 21, 2009
SOURCE: LG Senseclean washer dryer combo won't dry
The problem is likely due to lint build up in the condensing unit. I found a solution here:
http://www.motusconnect.com/blog/2009/1/5/lg-washer-dryer-drama-%E2%80%93-diy-fix
I also had a softball size ball of wet, packed lint in the condensing unit. I found that the unit can be cleaned without tools or dis-assembly by:
  1. draining the water.
  2. laying the washer on it's back.
  3. removing the hose clamp on the rubber bellows that connects the drum to the condensing unit (right hand side of machine).
  4. digging the lint wads out with your fingers and a small screwdriver.
Happy drying!
Posted on Feb 01, 2010
SOURCE: L.G DIRECT DRIVE 7 WASHER / DRYER U.E ERROR CODE
My machine is doing just the same! It is about the same age as yours. I cannot believe this is it working properly, but the manufacurers are no help.
I am seriously thinking of getting rid of it, and would be loathe to touch an LG again.
Linda
Posted on Oct 08, 2010
Washing machine
I see a little confusion here...there is LG WD-1280FHD which is the MODEL number, WD= washer-dryer, LG=Life's (not so) Good. The "F" is for Front Load... HD for dryer Heated Dryer. The numbers correlate to date and assembly plant location. IDK this other number your showing is a Part Number
Mar 15, 2014 | LG WD-1280FHD Front Load Washer
Where is the lint collector on LG 7.5g model WD 1049C Front Loader washing machine.
The combo washer/dryer doesn't have a lint collector. Air is circulated through a condensate tube and is washed down during each drying cycle.
Jun 16, 2011 | Washing Machines
Hi, hope you can help, I have a 4 kg LG Washer / Dyer (model WD - 1433RD). It is displaying "CL" on the readout. Have lost the manual so wondering if this is a simple fix or not?
CL means that the child lock feature is active and the control panel buttons will not respond. For the LG WD1433RD, press and hold the Rinse+ and Pre-Wash buttons together for about 3 seconds to toggle the lock off. For the LG WD14311RD, press and hold Option and Rinse for about 3 seconds. On both washers, there is a small icon between the two buttons needed to toggle the child lock feature on and off. (It's a small face above a padlock.)
The manual as a Djvu file for the LG WD14311RD is available here: http://www.lg.com/uk/support/product/support-product-profile.jsp?customerModelCode=WD-14311RD&initialTab=warranty&targetPage=support-product-profile .
The manual for the WD1433RD is available as a PDF here: http://www.manualsonline.com/ex/thread/view/idThread/80183 .
I hope this helps.
Apr 06, 2011 | LG WD14311RD Front Load Washer / Dryer
"CL" appearing on my LG
CL is for control lock /look at panal closly should be botton or bottons you press and hold to release the control panal...Good luck
Feb 01, 2011 | Washing Machines
Washing machine LG Direct drive 7, 3.5kg WD 12331AD It has CL sign on it i cannot operate the machine how can i clear that nad get the machine to work?
CL means control lock should be a button or bottons on your machine that you press and HOLD to unlock the control panal...so the childern don't mess with your washer....Good luck
Feb 01, 2011 | LG Washing Machines
Water will not enter the machine on the cold water setting on my lg priviledge washer dryer combo model wd-3243rhd.i here a humming noise but know water.
I have a similar problem with my LG WD-3245RHD. I had a repairman come out to look at it and he said I needed a new circuit/control board. I have not been able to locate this replacement part to date. RepairClinic.com has one listed, but it is not in stock.
Nov 03, 2010 | LG WD-3243RHD Front Load Washer / Dryer
Lg washer dryer wd12126rd what does ve symbol flashing mean.
Actually it is UE error.It means UNBALANCE error where either the machine is not LEVEL or wash inside is on one side.
Check.
ALPER
Cyprus
Aug 05, 2010 | LG WD-12126RD Front Load Washer / Dryer
I have an LG washer dryer (model 12126rd) and it has just cme up with either UE or VE on the frint LCD panel. What does ths mean? Thanks!!!
UE means imbalance error. Cause : The load is to small, the appliance is tilted, laundry is gathered to one side, non distributed things are put into the drum.
Resolution: Move the washing around inside the washing machine to create a more even distribution of weight
Oct 25, 2009 | LG WD-12126RD Front Load Washer / Dryer
My wahser displays CL - it won't wash anymore
It normally on the LG means your washer is protected by the Child lock function.
it either takes the option and the temp button at the same time for 3 seconds or You'll see a smiley face between the wash and rinse buttons. Press the rinse and wash buttons for a few seconds at the same time and the child lock (hence smiley face) will switch off - Not to familiar with this model but this should work.
please rate me.
Apr 19, 2008 | Washing Machines
> press "Start/Pause"
Something to note:
Hope that helps.
Will
Jan 03, 2008 | LG WD-12126RD Front Load Washer / Dryer
LG WD-12126RD Front Load Washer / Dryer Logo
552 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
