Question about XFX GeForce 6200 Graphic Card
GeForce 6200 Well, my AGP GeForce 6200 makes texture problems with some games although i have the latest nvidia drivers and other specs that match graphics cards and the games requirements? How should i fix the texture bug?
  • Anonymous Mar 24, 2014
    do not work graphic card nvidia geforce 8800 gts oc
And how shuld i do that?
Posted on Jul 12, 2008
    Problem Solver:
  • 6 Answers
My recommend for that is format your pc.... insert first your agp then format the drive......
  • ohayo_02 Jul 13, 2008
    my recommend to you is go to www.microsoft.com/support for more details.... because i have only a few knowledge to format a pc...
    or ask some other wiz here in fixya.... thanks :)
Setup dual-boot disks, one loads VGA instead of GeForce 6200
You should enter Bios setup when restarting and check that it says AGP or PCI for video display. You can then go to Start then Run and type in msconfig. Go through the list for the startup menu and make sure that NVIDIA is displayed with a checkmark.
When you installed the new driver, also make sure that you disabled the default VGA driver too. You may have to check that out. If both are running there will be conflict. Any questions, please don't hesitate.
Nov 18, 2007 | XFX GeForce 6200 Graphic Card
I have windows 7 Operating system installed on Intel Original D865GBF motherboard. The processor is 3.2GHZ. Ram is 2 GB dual channel (!GB x 2). I have added a graphic card PNY Ge Force NVidia 6200 AGP. The...
sounds like yo had the same Probles that I had with my 5200 geforce The install did not go well. what was happening was the direct x was binding to the old mother board graphics system and not the new card . to make it rebind just change the refresh rate in the nvidia icon in your task bar . disable the display adapter from device manager for the motherboard graphics .put the card in the slot change the montior cord boot up check you direct x by typing in run dxdiag and test directx to be sure it is runing with your card you can also see that fron the about nvidia you must have the driver for the card installed to do all this.. hope I helped
Feb 27, 2010 | Nvidia GeForce 6200 AGP Graphic Card
Can anyone please tell me if my video card is a capture card? Nvidia Geforce 6200 thanks joe
Tech Specs CineFX 3.0 Shading Architecture
  • Vertex Shaders
    • Support for Microsoft DirectX 9.0 Vertex Shader 3.0
    • Displacement mapping
    • Geometry instancing
    • Infinite length vertex programs
  • Pixel Shaders
    • Support for DirectX 9.0 Pixel Shader 3.0
    • Full pixel branching support
    • Support for Multiple Render Targets (MRTs)
    • Infinite length pixel programs
  • Next-Generation Texture Engine
    • Up to 16 textures per rendering pass
    • Support for 16-bit floating point format and 32-bit floating point format
    • Support for non-power of two textures
    • Support for sRGB texture format for gamma textures
    • DirectX and S3TC texture compression
    • Full 128-bit studio-quality floating point precision through the entire rendering pipeline with native hardware support for 32bpp, 64bpp, and 128bpp rendering modes
64-Bit Texture Filtering and Blending
  • Full floating point support throughout entire pipeline
  • Floating point filtering improves the quality of images in motion
  • Floating point texturing drives new levels of clarity and image detail
  • Floating point frame buffer blending gives detail to special effects like motion blur and explosions
Intellisample 3.0 Technology
  • Advanced 16x anisotropic filtering
  • Blistering-fast antialiasing and compression performance
  • New rotated-grid antialiasing removes jagged edges for incredible edge quality
  • Support for advanced lossless compression algorithms for color, texture, and z-data at even higher resolutions and frame rates
  • Fast z-clear
  • High-resolution compression technology (HCT) increases performance at higher resolutions through advances in compression technology
UltraShadow II Technology
  • Designed to enhance the performance of shadow-intensive games, like id Software's Doom 3
TurboCache Technology
  • Shares the capacity and bandwidth of dedicated video memory and dynamically available system memory for optimal system performance.
PureVideo Technology
  • Adaptable programmable video processor
  • MPEG video encode and decode
  • High-definition MPEG-2 hardware acceleration
  • High-quality video scaling and filtering
  • DVD and HDTV-ready MPEG-2 decoding up to 1920x1080i resolutions
  • Dual integrated 400 MHz RAMDACs for display resolutions up to and including 2048 × 1536 at 85Hz
  • Display gamma correction
  • Microsoft® Video Mixing Renderer (VMR) supports multiple video windows with full video quality and features in each window
Advanced Display Functionality
  • Dual integrated 400MHz RAMDACs for display resolutions up to and including 2048x1536 at 85hz
  • Dual DVO ports for interfacing to external TMDS transmitters and external TV encoders
  • Full NVIDIA® nView™ multi-display technology capability
Advanced Engineering
  • Designed for PCI Express x16
  • Support for AGP 8X including Fast Writes and sideband addressing
  • Designed for high-speed GDDR3 memory
  • Advanced thermal management and thermal monitoring
NVIDIA® Digital Vibrance Control™ (DVC) 3.0
  • DVC color controls
  • DVC image sharpening controls
Operating Systems
  • Windows XP
  • Windows ME
  • Windows 2000
  • Windows 9X
  • Macintosh OS, including OS X
  • Linux
API Support
  • Complete DirectX support, including the latest version of Microsoft DirectX 9.0 Shader Model 3.0
  • Full OpenGL support, including OpenGL 2.0
GeForce 6 Series GPUs Features Comparison:
Feature GeForce 6800
Models
shim.gif GeForce 6600
Models
shim.gif GeForce 6200
Models
w/Turbocache
shim.gif Microsoft® DirectX® 9.0 SM 3.0 SM 3.0 SM 3.0 SM 3.0 Graphics Bus Technology AGP 8X/PCI Express AGP 8X/PCI Express AGP 8X/PCI Express PCI Express NVIDIA® Intellisample™ Technology 3.0 3.0 3.01 3.01 NVIDIA® SLI™ Technology X2 X2 n/a n/a NVIDIA® PureVideo™ Technology X3 X3 X3 X3 NVIDIA® TurboCache™ Technology n/a n/a n/a X4 64-bit Texture Filtering and Bending X X n/a n/a Effective Memory Interface 256-bit 128-bit 128-bit 128/64-bit Memory GDDR35 and DDR GDDR35 and DDR DDR DDR Process 0.13 micron 0.11 micron 0.11 micron 0.11 micron RAMDACs 400 MHz 400 MHz 400 MHz 400 MHz
1. GeForce 6200 models do not include compression technology.
2. NVIDIA SLI: Available on SLI-certified versions of GeForce 6800 Ultra, 6800 GT, 6800 GS, 6800, 6800 XT, 6800 LE, 6600 GT, 6600, and 6600 LE PCI Express GPUs only.
3. Features may vary by product. Some features may require additional software.
4. Available on select GeForce 6200 models only.
5. GDDR3 - GeForce 6800 Ultra, 6800 GT, 6800 GS, and 6600 GT only.
Nov 20, 2009 | Nvidia GeForce 6200 AGP Graphic Card
I recently bought a Nvidia GeForce 6200 256Mb AGP card to replace a 5200 card so my daughter can run her school assistance programs. its my old computer and I never had any problems with the old card...
Sounds like a Driver Conflict.
Still have the old 5200 drivers in there?
Did you install the drivers for the 6200, BEFORE you physically put the graphics card in? (Not shouting)
Let's say you did remove the 5200 drivers, before you installed the 6200 graphics card.
BUT,
If you physically install the 6200 graphics card, BEFORE you have installed the drivers, Windows 'sees' a new device, and hurries up to match one of it's generic drivers.
(Windows has thousands of drivers!)
Now you come along, and install THE drivers for the 6200. Windows has a drivers conflict.
Windows: "Which drivers do I use? These, or THESE?"
Makes for a garbled graphics display as you've described.
If the above is true, start over.
Go to Add/Remove Programs, and Remove the Nvidia software. All of it that has Nvidia next to it.
(THIS, is provided of course, that the computer HAS Integrated Graphics, and does not just use a graphics card. You will be plugging the monitor, into the VGA port in the I/O area, on the back of the computer temporarily, if this is true, and this computer has Integrated Graphics)
(Start>Control Panel>Add/Remove Programs) If there is more than one Nvidia program listed, Do No restart the computer each time you remove one. Do Not restart. Read on)
After all Nvidia software has been removed, close Add/Remove Programs, close Control Panel, and return to the desktop screen.
Shut the computer down normally. (Start>Turn Off Computer>Shut Down)
Unplug the computer from power.
Press the Power On button in, and hold it in. Hold it in for a count of 5 seconds. (Count, 1001,..1002,..1003,..1004,..1005) Let go of the Power On button. Do this procedure Two more times.
What you are doing is clearing any CMOS Error Codes, and resetting BIOS back to the factory default settings.
Open the case. TOUCH the metal frame of the case to relieve your body of Static electricity. Remove the 6200 card. Plug the monitor into the back of the computer into the VGA port. Leave the case open, you'll be going back in there.
Plug the computer into power. WAIT 1 minute, then turn it on. After Windows has fully loaded, install the GeForce 6200 drivers from that CD disk. Do Not restart.
Shut down normally.
Unplug from power. Touch that metal frame again. Install the GeForce 6200 card. Close the case. Plug the monitor into the GeForce 6200. (You did plug the monitor into the 6200 the first time, right, and not the VGA port?)
Plug the computer back into power. WAIT 1 minute. Turn the computer on. Go to Start>Nvidia>Nvidia control panel, and set the settings.
Aug 15, 2009 | Nvidia GeForce 6200 AGP Graphic Card
Bad 3 grapics Geforce 6200 AGP
Download your graphics driver from nvidia the Geforce 6 series, select for the kind of operating system you use. http://www.nvidia.com/Download/index.aspx?lang=en-us
Apr 27, 2009 | Nvidia GeForce 6200 AGP Graphic Card
Very bad graphics Sharp angles whle palying a game whats wrong?
you will need a better gxf card, preferably something better than AGP cards. But since thats what your pc has try getting a 7000 series card. ex 7300gs
Apr 20, 2009 | XFX GeForce 6200 Graphic Card
Nvidia 6200 agp will not play games on s video
What Monitor settings are u using? Try higher frequency & if its a 17" monitor use 1024 x768 setting(resolution) and frequency 75-80 Hz. Also check the nVidia website for driver update for this model. I recently saw that there is a new driver in this category!!!!........sodeep
Mar 24, 2009 | Nvidia GeForce 6200 AGP Graphic Card
Game graphical error
Wierd, I had this problem once, updating my driver simply fixed it. Do this: 1) Remove all nvidia products and drivers from your computer. 2) Reboot computer of course. 3) Go to Nvidi'as website and download the correct latest driver for your graphics card. 4) Reboot again. 5) Go test the game.
Feb 24, 2007 | XFX GeForce 6200 Graphic Card
Game textures problem
Try uninstalling the driver and all nvidia products, download the latest driver from nvidia's website. If that doesnt work, then your motherboard is the problem. Older AGP motherboards tend to have problems witht eh geforce 6200/6600 series cards, I recommend updating those drivers and seeing what the deal is.
Jan 21, 2007 | XFX GeForce 6200 Graphic Card
XFX GeForce 6200 Graphic Card Logo
338 people viewed this question
Top XFX Computers & Internet Experts
David
David
Alun Cox
KG John Justin
KG John Justin
Are you a XFX Computer and Internet Expert? Answer questions, earn points and help others
