Question about Garmin Nuvi 660 GPS Receiver
SHUTDOWN My Garmin 660 after going thru the initial start up of "loading map" it will just SHUTDOWN. I have tried to clear the data in the diagnostic menu as recomendated by Garmin support to no avail. At the start, the trouble is it will just stay in the loading map stage. Then later it begin to shutdown.
Posted on Jul 15, 2008
My garmin turns on but freezes when loading maps. I tryed to reset but did nothing.sometimes it will stay froze and sometimes it will turn itself off.serial #12p238176
Clear all ur installed apps/data/music/pictures first. Turn the unit off and then on. while on, reset it again. turn it on again and now connect it ur PC to load additional maps and see if it helps.
thanks
Aug 11, 2010 | Garmin Nuvi 660 GPS Receiver
How to install map to garmin nuvi 205w
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Just so you know:
Sorry, no free maps. I know I've tried. You either live with the old map or buy the latest version.
I bought the life time maps updates and I'm glad I did.
I've updated my maps at least 6 times.
New maps are about $70.
Life time maps are about $99 (when I bought mine)
BUT FIRST make SURE you have the latest software in YOUR computer and in YOUR Garmin before you load any maps.
You can get that FREE at Garmin here:
Normal 0 false false false MicrosoftInternetExplorer4 To download the latest unit software visit Garmin website: www.garmin.com/webupdater
After installing WebUpdater once from the Garmin website, perform all future software updates from your computer. Simply connect your compatible Garmin device to your computer, then run WebUpdater from your computer's "Start Menu" by selecting "Start", "Programs", "Garmin", and finally "WebUpdater"
REMEMBER: It takes hours to do a complete a map update.
Unless you bought the Lifetime maps you may have to pay for current maps.
Does this help? Let us know. Thanks.
Dec 12, 2009 | Garmin Nuvi 660 GPS Receiver
My Garmin shuts off in the loading maps screen every time we try to turn it on. It will flash the Garmin logo when it gets turned on, go to the loading maps stage and then just shut off. Any ideas?
first I would try to load the current firmware from garmins website. if that doesnt work then try a master reset by holding the bottom right corner of the screen, holding that and turning it on. it will however erase all user data.
Aug 12, 2009 | Garmin Nuvi 660 GPS Receiver
Add Europe sd card to Garmin 660
No. When you plug in the SD card, the Nuvi will load the map from your SD card. Once you get to the main menu, select the wrench symbol, then the map symbol and then "map info". You should see both the US and Europe map. Make sure the Europe map is checked. You can uncheck the US map. This is how you switch between maps. The reason why you have to have the extra map on the SD card is because the Nuvi can only have one map on it's internal drive, one at a time.
However, backing up your US map is a good idea.
Good luck,
- Jim
Nov 21, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 660 lost map data
Hi Bruce. The same thing happened to me . I called customer support
1-800-800-1020 and they were able to link ino my computer, go through it and into my GPS. Hopefully this will work for you!!!
Tom
Aug 08, 2008 | Garmin Nuvi 660 GPS Receiver
Trouble with garmin 660 GPS
Jul 14, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Street Pilot 7200 will not load maps
I had the same problem on my StreetPilot 7200 after many edits of many routes. Suspect a scratchpad memory heap getting used up or fragmented had to hold the power button in for 15 seconds or until a message that says press yes to clear all data appears then quickly press yes before unit shuts down
This corrected the problem until the next time the heap gets fragmented but loss of all waypoints is the downside
Jan 11, 2008 | GPS
Garmin 660
Have you updated the software since you purchased the unit? If not, go to Garmin's site, download WebUpdater and check to see if there is an update to the unit's software. If so, download this and see if it helps. If not, try downloading the same version of the software again. This might help also.
Jan 01, 2008 | Garmin Nuvi 660 GPS Receiver
Nuvi 660 MapSource
Henry,
You cannot replace American maps with European maps.  Garmin does this in order to protect the European retailers.  The European SD card eliminates the need to load the maps into the 660, however, if you need to use the card slot to store extra data such as MP3s then you might be better off buying the 670.
Oct 28, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
233 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
