I have a Samsung HLR5667W TV. My lamp light went on so I purchased a new lamp. Did not fix problem. So I pulled the chasis out and found that the color wheel had shattered. So I replaced that. Turned on and although it solved the vibration, hum, and this high pitched squeel, the light still did not come on. So that leaves the ballast. The system seems to cycle with the clicking noise. Is there any way test the old ballast? What other problems might exist and how do I test for them?
    Scholar:
  • 62 Answers
I changed my shattered color wheel and ballast which fixed the problem you just described
Posted on Oct 25, 2009
When I replaved samsung hls6767w lamp with hosing with new lamp with hosing I noticed burning smell.I assumed it is new lamp buring smell. After 15 mnts when smell did not go I removed power and when...
Most of the time the female end of the connector comes right of a part called the ballast. Ballast's are replacable. Is the aluminum melted? I am not sure where to purchase the ballast. The female connectors is ussally atached to frame with screws or sometimes clips
May 27, 2011 | Samsung HL-S6767W DLP TV
HL-R5667W Picture just went blank, no sound. turn on tv the timer,lamp and stand by/temp light all flash. replaced lamp still same issue heard intermittent whirling fan rubbing sound before it went bad
Sounds that tv got color wheel problem that will be replaced.
If you are handy with electronics stuff repair then replace color wheel in light engine of tv to solve its issue.
Sep 13, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
The Tv will turn on and work for 5 min then shuts down
3 lights on front flashing indicates lamp quit. Could be lamp or ballast.
Apr 10, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Samsung hlr5667w TV made a popping noise then the picture started
Most likely. You should remove the lamp door, pull out the lamp, and inspect it. Look into the center of the lamp, does it look dark or swollen? Does it look chalky on only one side? Did it burst? If so, you definitely need a new lamp. I hope this helps.
Mar 16, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Shadow appeared on my DLP TV after replacing the lamp
this is a light tunnel failure this component will have to be replaced and is a part of the light engine
Feb 14, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Samsung hlr5667w that won't turn on. Good lamp and ballast
Any light blink on the front. Whats the voltage to the ballast from the power supply. Common problem on these sets are bad lamp door switch. Try shorting the switch. Color wheel also is problematic but usually will be noisy and cause shut down. Check power board for swollen capacitors. Hope this helps
Nov 03, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
My Samsung HLR5667W DLP won't come on. Lamp lite blinking
Feel better now?
Tried a new lamp or is it now very old and damaged the main board?
Sep 20, 2017 | Samsung HLR5667W 56" Rear Projection HDTV
No picture, no sound on my Samsung 56" Projection TV
You probably need to replace the lamp. It's about $150, and if you buy it with the housing, it's a really easy fix, just unscrew and pull out the old one, and pop the new one in. Go here:
www.dlplampexpress.com
Jul 30, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
Black screen with a Blinking lamp in the front
Hi..if your lamp is on but no picture, then your lamp is good. Your problem is the DMD board (digital mirror display board) is bad. This is very common with Samsung DLP.
Mar 27, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
Televison & Video Logo
125 people viewed this question
Top Televison & Video Experts
