Question about LG Flatron Ez T710BH 17" CRT Monitor
Samsung crt monitor
Blinking display
  • Anonymous Jul 12, 2008
    when i turned on my monitor the display starts to blink
  • LG Master
  • 19,396 Answers
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, faulty convergence, fault on alignment circuits, flyback problem , or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
Posted on Apr 22, 2009
Power on problem
sounds like your monitor has bad capacitors. When a monitor begins to overheat the capacitors may begin to burst or leak which will not do its job to hold electrical current sufficiently and cause the display to become blank.
Mar 28, 2014 | SAMTRON 55V 15" CRT Monitor
Led bilinking
green LED blinking but no display, when disconect VGA cable from CPU than monitor displays cable disconected. CPU vedio card is ok
Jan 08, 2011 | Samsung 793S 17" CRT Monitor
Whenever i start PC my 17" CRT monitor led blinks very fast and gives clicking sound but nothing displys . the blinking slower gradualy and after 25 minutes it displays menu. why it is take so long...
You can test it with another PC, if problem is the same, it might due to faulty components inside the CRT board. You have to justify whether to fix it or get a new LCD which is very cheap now.
Jan 03, 2011 | Samsung Computers & Internet
Samsung 56V, difficult to switch on the monitor
check the capacitors inside the monitor, as they may be broken, and they start screen up, just change em and it should kickstart fine
Sep 19, 2009 | SAMTRON 55V 15" CRT Monitor
On right side of my monitor 2 ,3 verticla lines or blinking.
That sounds more like a graphic card problem than a monitor one. try conecting your pc to a different monitor and see if the problem persist.
Good luck
Mar 03, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
HCL 17" monitor display problem
Hi there ,
It seems that you have a vertical section problem ,It might be possible some capacitor might have gone wrong
Jan 24, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
I have a compaq 15" monitor which has no display.
1.poewr LED blinking or not.if in case LED blinks one time. problem in LOT .Cheak horzontal Transistor also.
1a) power out put voltages
2.drypoints in neck board.
3.cheak display cable.
Dec 19, 2008 | SAMTRON 55V 15" CRT Monitor
Green light continously blinking in samsung sync master 753s
1. cpu problem. why because of there is no signal output from cpu to monitor. the led blinking means there is no vertical, horizontal signals from cpu to monitor.
2. your monitor connected to another system.
3. neck board dry points.
4. cheak the display cable. 13&14 pins are horizontal, vertical signals.1, 2, 3 pins , R G B , 6 ,7, 8 pins R G B ground ( coaxiler cable used , meshed wire is ground )
Oct 13, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Samsung crt monitor
Check power section for proper power supply. check main capacitor or change it .if this problem not solve then check horizantan output transistor(this is placed near eht on hit sink big in size)
Jul 12, 2008 | SAMTRON 55V 15" CRT Monitor
LG Flatron Ez T710BH 17" CRT Monitor Logo
241 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
