Cars & Trucks Logo
Posted on Jan 10, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vic-tron--In your response to "guest
Jeremy W.
Level 3:
Top Expert:
  • Chevrolet Master 5,332 Answers
  • Posted on Jan 10, 2011
Jeremy W.
Chevrolet Master
Level 3:
Top Expert:
Answers
5332
Questions
0
Helped
2057907
Points
17799
The banks refer to what side of the engine the sensor is on. Bank 1 is always the same side of the engine as the number one cylinder. Bank 2 is always the other side of the engine. Sensor refers to upstream or downstream. Sensor 1 is always before the cat sensor 2 is always after the cat.
in your case bank 2 would be the opposite side of the engine as the number one cylinder.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
How to replace o2 sensor located in bank 2 sensor 2 on Toyota Venza 2010
The oxygen sensor itself requires simple hand tools to remove. They do make a special socket to get them off if you want to buy one. On Toyota, bank 2 is the bank on the front of the engine, and sensor 2 is oxygen sensor after the catalytic converter. Sensor 1 is located before the catalytic converter, usually in the exhaust manifold.
1helpful
How many o2 sensors does a 2002 GMC Envoy have please?
Welcome. Two O2 sensors. One in the exhaust manifold and another after the cat.
Feb 9, 2010
How many O2 sensors are there?
trailvoy.com
https://www.trailvoy.com > ... > Exhaust Mods
How Many O2 Sensors Are on This Vehicle?
2CarPros
https://www.2carpros.com > ... > Location
Dec 27, 2021 - Hello, this vehicle has two oxygen sensors, the rear one is behind the Catalytic Converter. Below is a picture of its location to the right side .
Hello I have a GMC Acadia 2010 with a bad Bank 2 sensor 1 o2 sensor. Where is this located and is there a certain part# for this sensor?
Bank 1 is the bank with cylinder #1, Bank 2 is the other side of the engine. Sensor 1 is the UPSTREAM sensor located in front of the catalytic converter
Oxygen sensor location
2helpful
Where is the 02 Oxygen Sensor before the cadalic converter on a 2006 Hyundai Santa Fe
Usually these are located on the exhaust manifold or just below the exhaust manifold and you should be able to see it in the engine bay. On V6 engines there will be one sensor on each of the 2 exhaust banks.
You will probably need to remove the engine cover to see the sensors on your exhaust.
If someone told you to replace these because you got a particular fault code I would be wary. A decent scan tool and basic diagnostics can show if the 02 sensor is working or not. Some faults often blamed on an 02 sensor are not due to faulty sensors.
2answers
Where is the heated o2 sensor (bank 2, sensor 1) on a 2010 chevy traverse located?
I would say it is the sensor screwed into the exhaust manifold on the passenger side of the engine. (I will guess that that side of the engine is Bank 2)
1helpful
8/2009 computer programming failed, threw a rod and I replaced the engine in my 2001 Nissan Pathfinder. No failsafe mode apparently. I replaced both front O2 sensors and installed a new computer and had...
P0134 and P0154-o2 circuit not actively detected-bank 1 and 2, side 1
Nissan TSB Reference # NTB02-015 (in canada). Might be a similar TSB in the US-also this;
It does sound like it is an electrical problem, possibly in a harness (damaged) or the ECM had major issues that a reflash could not overcome.
4helpful
2answers
Code p0133 on 2004 deawoo matiz please is it the oxy sensor and if so front or rear one thank you
O2 Sensor Circuit Slow Response Bank 1 Sensor 1
this is the sensor that is located in the exhaust just off the engine and before the cat converter, so it is the front sensor.
4helpful
2answers
Code: P0133 - O2 Sensor Circuit Slow Response Bank 1 Sensor 1
is this a 4 or 6 cylinder?
if a 4 cylinder it will only have 2 o2 sensors
V6 will have 4 o2 senors which the sensor will be the right side of the engine first sensor.
1st sensor on exhaust, I recommend if you change one change all, as this will make the computer when it rechecks the system you have all clean/fast responding sensors.
if you have a slow response it means the sensor is dirty and not reading well, which is usually caused by minor misfires that the engine computer dismisses, so a tune up would be recommended too.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
