My laptop will not play dvds
Hi my toshibia laptop will not play this dvd called the ten commantments it is a 2 disk set, when i place the dvd in the drive which is D drive it has only one drive, it will not open toplay on any players i have on this laptop
windows tell me it can not read this dvd, it says it is not formated, but it dose play on my orther p.c i have, could someone tell me why.
  • 408 Answers
The eyeon the drive may need cleaning with a little alcohol and a q-tip or the drive may be defective.Usually it just needs cleaning.
Posted on Jul 31, 2009
My toshibia satelite laptop show that it cant find any hard disk drives and to run a manufactured diagnostics ???? What do i do.
You must obtain the recovery disc set and reload the operating system. If that fails the hard drive may be faulty or the mother board.
May 18, 2017 | Hard Computers & Internet
How to replace compaq evo cd/dvd disk drive
hi.
open yr desktop cassing then u will see yr cd/dvd rom. then find for button to remove cd/dvd rom then pull tht tht boten and pull up yr cd rom.
new cd rom you must set jumper setting to slave then connect all cd rom cable. on yr system ten see yr cd rom will auto place in my computer.
regards
Feb 21, 2011 | Compaq Evo D510 PC Desktop
I have a dell inspiron 1318. whenever i turn the laptop on, there is a black screen with a "read disk error has occured" message...it keeps bringing me back to the same screen...what should i do?
Disk read error is indicative of a hard disk drive failure. If under warranty, call Dell for a replacement drive. If not you can buy drives at places like Newegg.com or EBay
Sep 20, 2010 | Dell Inspiron 1318 Notebook
Cant play movies from my toshibia laptop
Hi:
There are several reasons why a movie won't play, so I will run a few suggestions by you:
Hopefully ;you have a DVD drive or a DVD RW drive ?
If you insert a DVD or CD into the drive, your computer should recognize that a disk is inserted. If not the drive might be bad
You must have some sort of Software installed to make movies play, such as WinDVD, or PowerDVD
Oct 29, 2009 | Toshiba Satellite A15-S157 Notebook
Dvd plays initially and then stops
It could be the drivers for CD/DVD.
The best way to troubleshoot this is right click on computer, select manage. A new window will pop up, in that list select device manager.
Look in the list for CD/DVD drives and click on the + sign next to it, when the tree opens right click on the CD/DVD drive and select uninstall, then restart the PC.
This method will hard reset the system and force windows to load the default drivers for the CD/DVD upon restart. Hopefully this should resolve your problem.
If not please post back.
Good luck
Jun 15, 2009 | HP Pavilion DV2740SE Laptop
DELL laptop does not read blank DVDs
the combo drive you listed above is a cd-rw/ DVD-ROM....meaning that it will play and burn cd, cd-r, and cd-rw disks. the dvd rom will only be able to play dvd-rom and dvd-r disks providing they are in the proper format. check that the disk in question is not a dvd-rw or (+2) disk. the drive will not recognize that a disk is in the drive if the disk isnt compatable. try a dvd movie, if that works then a dvd-r, if that works then try a dvd-rw +1. if the last option doesnt work then you will have to stick with the dvd-rom and dvd-r, or purchase a dvd-rw drive to install.
GOOD LUCK AND DONT FORGET TO RATE MY POST!! :D
Mar 18, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
I purchased a new Zenith Tv and have hooked up my dvd player which is about four years old (Toshiba). The connections are all right but when I put in any disk (I have tried many) it registers no disk so...
try to use player on old tv again does it still work 4 yrs old dvd player is to old for new days dvs on new tv u def wann upgrade to 108p upscaling player samsung makes with hdmi cable to new tv flat screen or reg coneection will look 10 times better also older toshibia cant play read new dvds its terrible
Oct 07, 2008 | Televison & Video
Trying to change region to 2 but it has locked me out is there a code i need
you can only change ur region codes a few times then ur drive becomes locked to the last reset.then youll need to reflash ur drive with firmware.theres a program u can get(free)called any dvd which gets around region codes.
I personally would reflash firmware.this sets drive to "0" which is all regions.
simple precedure.locate firmware,download it,write it to a cd,insert cd which then reflashes auto.remove cd.
Mar 26, 2008 | HP Pavilion dv4000 Notebook
Problems with cyberlink power dvd player in laptop
hi dear
it ofen happen at some time........drive doesnt play dvd when u use duplicate or pirated dvd disk.........
1 st use a good quality disk of dvd ,,,,,,,,,,,,,,,,,,,,
if problem remail same then imidately contact ur dealer(shop) & replase u r dvd drive............
some time it also happen due to problem in dvd drive.......
dont forget to tell me u r problem solved or not
best regards & best of luck..
Oct 23, 2007 | CyberLink SW- DVD Software Power DVD...
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
