Question about HP Pavilion dv6000z Notebook
Have no audio device driver - HP Pavilion dv6000z Notebook
    Champion:
  • 258 Answers
Helen what type of PC you have? Is sound onboard or soundcard?
if soundcard then the driver come with it on otherhand onboard then you must have MOTHERBOARD CD DRIVERS
Posted on Jul 12, 2008
Audio output device
Hi.
The audio output device in your computer is the audio adapter board (or circuit). This is the device that produces sounds and send them to the speakers.
If you get a message telling you that there is no Audio Output Device detected, or that the Audio Device is not working, that usually means that there is a problem with the audio driver.
In that case the problem is often fixed downloading and reinstalling the drivers for your audio device. If there is a problem with the audio output device, go to the computer manufacturer website (e.g. Dell, HP, Sony etc.) and download the audio drivers for your specific model. When download is complete install the drivers and restart the computer.
Regards.
Ginko
Jul 20, 2011 | Microsoft Windows Vista Home Premium with...
Dont have audio device
Check device manager if the Audio device is detected.
Check Audio device has mark like this ! - i suggest uninstall / reinstall the audio device driver. download the driver from dellsupport.com drivers and download page.
If the audio device has ? mark it means that computer not able to recognize the audio hardware. if you are using audio onboard replace motherboard. if the audio has expansion card reseat the card then try again. if all fails then try a different audio card if passed then the audio card is faulty. if all fails using a different audio card it means the motherboard slot is faulty. replace mobo.
May 27, 2011 | Computers & Internet
When i am installingconxtant audio driver it is telling media device not found and not installing
Typically, if you are getting a "device not found" error upon trying to install an audio device driver, there are a number of issues that could be going on at one time.
First: You may have the wrong device driver or version of the device driver for the device intended for. Check the hardware version number and verify on the website of the hardware device (the audio card if it is an independent audio card that is what you are referring to) what is the latest revision of the driver. Download the driver and install it.
Second: If your device is an external audio card, make sure it's fully inserted into the PCMIA slot (seriel port if being used). If so, then accomplish the following procedure: Power down your PC. Remove the Audio Card and reboot PC. Allow PC to recognize no audio card, then shut down PC and reinstall Audio Card. Reboot PC and install with new Audio Driver
One of the two steps above should rectify the problem. If it doesn't, then the last resort is to assume the Audio card is faulty if it's an external Audio card.
If you have an internal Audio card, then there can be a faulty portion on the sound portion of the motherbood, which then would require the entire motherboard to be replaced. But before you result to this, be sure you have the newest Audio driver for the Audio Codec and installed correctly.
Please keep in mind, Conexant is an OEM supported Audio Codec and you need to refer to the maker of the PC itself for driver support. I.E. it may be a Conexant Audio chipset installed in a HP PC. So, be sure you go the manufacturer website such as "HP" for the audio driver support.
Hope this helps,
Jun 26, 2010 | Computers & Internet
No audio output device is installed
Your audio driver may be missing or corrupt. Go to the device manager and look under the audio devices. If it doesn't list your audio device or has exclamation mark (!) next to your audio driver, then you're missing the driver.
If you see your audio device listed, then either your driver files are corrupt or your audio device is damaged.
In either case, go to Toshiba homepage, search for the audio device driver related to your laptop's model. Download it and install to see if that corrects the problem. If it doesn't correct your problem, it's possible your Southbridge chip may be defective, in which case, not much you can do.
Jun 10, 2010 | Toshiba Computers & Internet
No audio device
The "No Audio Device Error" message is usually displayed by your computer when it does not detect any properly working audio device attached to it. You will not hear any sound from your computer when this message appears. Only the internal speaker of the computer can provide you bleeping sounds.
When this message appears on your screen, you will need to first check your computer's BIOS and ensure that the audio is set to "auto" mode. You should also check if you have installed the correct drivers needed by the audio device attached to your computer in order for it to work properly.
Audio Device Drivers The most frequent cause of this problem is an incorrect audio device driver that has been installed by the user. In order to double check if your driver matches your device, refer to the user's manual that came with it to look for its type and specifications. The audio device driver for an onboard device should be provided along with the chipset drivers in the CD that accompanies the motherboard.
Use the Device Manager You can use the device manager to ascertain if the audio device drivers are installed properly. To go to the device manager, right click on the My Computer icon, then click Properties, click on the Hardware tab and then Device Manager. If any device is marked with a yellow question mark, it is an indication that the required drivers are missing. It should be instantly clear if the audio device is truant.
Loose Connections on the Motherboard You can open your computer and directly look at the information written on the audio device itself. While doing this, make it a point to check all connections by ensuring that everything is properly plugged in its correct place. Sometimes, this error is also caused by loose connections and a sound card that has been improperly attached to the PC.
You can download the latest updated drivers from the manufacturer's website, either from your own computer or another. If you have used another computer, you can use a data storage device to bring the drivers to your machine and execute the software installer from there. Ensure that the driver you have downloaded is compatible with the operating system installed on your machine.
Is Your Audio Device Defective? If problems with your audio device still persist, you can opt to test the audio device on a different machine just to see if it's in good working condition. If it still doesn't work on a different machine, you have a defective audio device. You will need to get it replaced if it is under warranty or purchase a brand new one. Remember that you should buy the audio device that is compatible with your motherboard. In addition, don't forget to ask for the updated software drivers of the audio device
May 18, 2010 | Computers & Internet
No audio device driver for vista 54
Try to check the windows audio services in windows service, and make automatic, then try to check if not working then go to device manager and uninstall audio drivers and restart the computer and give some to to automatically install the driver then audi will work in case not working then refresh the driver from device manager and try to download and reinstall the windows audio driver then windows audio will work fine.
Mar 19, 2010 | Compaq Presario V2630US Notebook
Audio device erased
You have to reinstall your audio driver. Answers to your questions: 1. You can locate it in your Device Manager. Locate and expand Sound,video and game controllers. 2. You don't have to delete legacy drivers because reinstalling your audio driver will update it. Right click your audio software the one you found in the Device Manager and update it. It will find your installation cd of your system drivers. Else, manually install the audio driver.
*Drop me a comment if you still have questions. Your vote will be highly appreciated. Hope this helps you.
Feb 13, 2009 | Microsoft Windows XP Professional for PC
Modem device on high definition Audio Bus for acer aspire 3680
These are the same thing , they will both disappear when you install the audio driver
http://support.acer-euro.com/drivers/notebook/as_3680.html
Click under Windows XP Drivers And Utilities And click Audio Driver
Always check the manufacturers site for your drivers!
Jan 24, 2009 | Acer Aspire 3680 Laptop
My sound
Problem C-Media AC97 Audio device no open?
Dec 06, 2008 | HP Compaq Presario SR2150NX PC Desktop
Sound card
Guide to troubleshooting Windows audio and sound problems
>>> Troubleshooting Overview
> Summary of steps that follow
  • Read the "Things to know before you start" section to understand some basics
  • At any point, consider a System Restore especially if your device suddenly disappeared or a driver problem just started occurring
  • Find your audio device(s) in Device Manager
    • If not found, check if onboard audio is disabled in BIOS
    • If found and it has a yellow icon, there's a driver error. Try reinstalling the driver
    • If found but it doesn't appear with a yellow icon, the device driver is working properly
      ==> Check if the device is using a generic driver from Microsoft or using a hardware specific audio driver (you want the hardware specific driver)
      ==> Next, look at the "Automated FixIt Tools and Other Help Guides" section. Try running the Microsoft Automated FixIt tool. If that doesn't help, you can try reinstalling the driver, checking your default playback device is set correctly and/or start looking through the other Help Guides for more help and tips
  • Also, see the "Notes and Tips" section towards bottom of this post for more debugging hints
> If you'd like more help with your specific problem
You need to create your own new topic / thread along with a problem description (see HERE)
  • Include info about: your computer make/model, Windows OS version and of course a problem description. ALSO, if you have an addon sound card include its make/model as well
  • Create your new topic in either the Audio and Video or Device Drivers forum - whichever one you think is suitable to your problem
> Only general comments, general questions, clarifications and corrections, etc. should be posted as replies to this guide
> Windows doesn't need a sound card or audio drivers to generate simple beep tones
Don't assume your audio "worked for a moment" just because you heard beeps (e.g like error beeps)
> Integrated Audio vs. Addon Sound
  • "Integrated" audio is the audio device that comes built into the computer's motherboard. Integrated audio may also be called "onboard" audio.
  • "Addon" sound is an audio device not on the motherboard. For example, if you add a sound card for your machine, it's addon sound. Addon sound may also be called "offboard" sound
> AC'97 vs. High Definition Audio
AC'97 was the first audio standard for computer sound (It was created by Intel in 1997). AC97 audio was superceded by High Definition Audio (also called HD audio) in 2004. It often helps to know whether your audio device is AC97 or HD Audio
  • All newer soundcards/audio devices are HD Audio. (I'd guess all audio/sound cards built since at least 2007)
  • Look at the audio device name in Device Manager
    ==> Names for HD Audio devices always include words like HD or High Definition within the name. Examples
    • Computer 1 on the left: Computer 1 has two audio devices (fyi: Computer 1 happens to have two sound cards: It has both integrated audio plus an add-on sound card). Look at the device names. You can tell from the names that both devices are HD Audio
    • Computer 2 on the right: Computer 2 only has one audio device. Look at its device name. You can tell from its name it's not HD Audio therefore you know it must be AC97)
> Generic vs. Hardware Specific Drivers
Microsoft provides generic audio drivers in Vista and Windows 7. If Windows can't find a hardware specific driver for audio, it may load its own generic driver. The Microsoft generic driver usually doesn't provide fully functional sound (and, often, microphones won't work with the Windows generic driver)
To see which driver an audio device is using
Open Device Manager, rt click the audio device, select Properties
..> If there's no Driver tab or the Driver tab shows Unknown, no audio driver is installed
..> If the Driver tab shows Microsoft, the audio device is using the generic driver
>>> Troubleshooting: First steps
> System Restore
At any point, consider a System Restore especially if your device suddenly disappeared or a driver problem just started occurring. System Restore will inform you if the restore attempt was successful or not. System Restore doesn't affect your personal folders and data
==> How to Restore a Windows XP system to a previous State using System Restore
==> Using Windows 7 or Vista System Restore
> Verify your audio device is detected
Check Device Manager. Can you find your audio device(s) listed? Does it appear with any special icons?
Device Manager icons
==> Yellow icons with a black exclamation point indicate a driver problem
==> A "down arrow" indicates a disabled device in Vista and Windows 7
==> XP uses a yellow icon with a red X for disabled devices
To check Device Status
==> Rt click the device, select Properties. Check Device Status on the General tab. Is Device Status = "This device is working properly"? Or is there an error code number?
==> If Device Manager says it's "Working properly" yet you still have sound problems, suggest you next see the "Automated FixIt Tools and Other Help Guides" section below. Run the Microsoft Fixit tool for Sound. If that still doesn't work, try a reinstall and look through the other help guides listed below. Also check your default Playback device setting (see "Notes and Tips" below)
When looking for your audio devices in Device Manager
  • First, look for your audio devices under Sound, video and game controllers
  • Next, see if you have an Other devices category. If the category exists, check each it lists
    When Windows can't identify a device, it gets lised under under "Other devices". "Other devices" are also called "unidentified devices" "Other devices" often appear with generic names. Example
    ==> On left: "Multimedia Audio controller" is a generic name for an unidentified AC97 audio device
    ==> On right: "Audio Device on High Definition Bus" is a generic name for an unidentified HD Audio device
  • If you can't find your audio device listed in Device Manager, reboot and look a second time. If you still can't find it
    ==> Note if you're still running XP SP2 you need this MS KB installed for HD Audio support. (XP SP3 and all versions of Vista and Windows 7 already include HD Audio support.)
    ==> Check if your audio is disabled in BIOS. Look for a BIOS setting named something like Onboard Audio orIntegrated Audio
    • If you find it, it should be set to ON or ENABLED or something similar
    • Not all BIOS provide this setting. Tho also be sure to search through all the BIOS menus to look for it
    • For more about how to enter BIOS menu setup see HERE. You can also check your system/motherboard provider's Support site for their documentation
> Reinstall the audio driver
Different methods of reinstalling are listed below. If the first two don't help, find the driver on the vendor site, download and install it yourself. If the driver installation seems problematic or the old driver installation seems to interfere, check if you have the option to first uninstall the current driver installation yourself from Add/Remove Programs
  1. Reinstall using Device Manager
    > Rt click the device, select Uninstall. Reboot. Windows should redetect and reinstall the device on startup
  2. Let Windows search for an updated driver
    > Rt click the device, select Update Driver. Follow the prompts. Allow Windows to search the internet for an updated driver
  3. Check if the audio driver is listed in Add/Remove Programs. If it's listed, uninstall it
    For XP, look in Ctl Pnl->Add/Remove Programs. For Vista and Win7, Ctl Pnl->Progams and Features
    Here's why: Some audio driver installers create an Add/Remove Program entry for the driver. (It's entirely up to the vendor and how they chose to write their driver so you may or may not find an Add/Remove entry)
    • When you uninstall using Device Manager, driver software is uninstalled but it's not deleted UNLESS Device Manager specifically offers you a delete option. This is also why Windows can reinstall a device on reboot when driver software is uninstalled (but not deleted)
    • "In theory" a new or updated driver should uninstall and delete old driver files itself when it runs but this isn't always the case. It never hurts (and sometimes helps!) to run the Add/Program uninstaller yourself if you find one
  1. Find an updated driver manually
    > Create a System Restore point before trying to install the new driver
    > Check vendor sites for their Support or Download link. Do an internet search or look at the topic HERE for links to many vendor sites
    • If you bought a complete PC system (e.g. from Dell, HP, Sony, ASUS), check the PC system provider first
    • If you bought an addon sound card, check the addon sound card provider
    • If you bought your own motherboard, check the motherboard provider
    • Check the audio chip provider on your soundcard. When looking for drivers based on the audio chipset note
      ==> Audio providers (like Realtek and IDT Soundmax) often provide both the audio chipset and the driver. While general chip makers (like Intel, SiS, and Via) usually provide just the chips. They rely on (and will point you to) someone else's driver that works with their audio chips (such as drivers from Realtek or IDT Soundmax)
  2. Find an updated driver using DriverEasy
    > "If it ain't broke, don't fix it". Only install DriverEasy's audio driver updates
    ==> DriverEasy returns every driver update it finds including "beta" (pre-release versions). Newer is not always better. Only update the driver if the device isn't working
good luck
Jan 13, 2008 | Acer AOpen AW 37 Sound Card
HP Pavilion dv6000z Notebook Logo
65 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
