Question about Bosch Dishwashers
Dishwasher was transported not upright got error in programme functions. How can we fix this.
2 Suggested Answers
Daniel S
  • 4323 Answers
SOURCE: E3 error code on Candy
Hi
E3 error code in your Candy is a temperature error, which means that the unit is not reaching its desired temperature level. However, as the unit will heat water then it means that the heating element located on the left is fine. The next thing that should be checked is the temperature sensor (thermostat/thermister), as that might not be responding, this part is located at the bottom & can be located beneath the door. Hope this helps...please post back with its model no. for further assistance.
Daniel
Posted on Dec 08, 2010
Zanussi dishwasher ZDF601M 1 in 3 red light comes on and programme doesn't work through
26269906-aipk5px1bmfkdpsmrgevaqwn-3-0.jpg "3 in 1" function
This appliance is equipped with the "3 in 1" function, that
allows the use of the "3 in 1" combi detergent tablets.
This function can be selected with all washing programmes.
With the selection of this function the inflow of rinse aid and
salt from each respective supply container is automatically
deactivated and also the indicator lights for salt and rinse aid
are deactivated.
Select the "3 in 1" function before the set of a washing
programme.
Once this option is selected (indicator light illuminated) it will
remain active also for the following washing programmes.
With the use of the "3 in 1" function, the cycle durations may
change. In this case, in the digital display, the indication of the
running time of the programme is automatically updated.
NOTE: Once the programme is running, the "3 in 1" function
can NO longer be changed. If you want to exclude the "3 in 1"
function you have to cancel the programme setting (see
chapter "Starting a washing programme" - "Cancel a washing
programme in progress") and then deactivate the "3 in 1"
function.
In this case you have to set a washing programme (and
options) again.
Activation/deactivation of the "3 in 1" function
(The dishwasher must be switched off)
1. Press the On/Off button. The On/Off indicator light
illuminates (setting mode).If a programme button indicator light is on, this means that a washing programme is set. The programme must be cancelled: press simultaneously function buttons 2 and 3
for about 2 seconds. All the indicator lights will turn off (except for the On/Off indicator light and eventually salt and rinse aid indicator lights) indicating that the set programme has been cancelled and the machine is now in setting mode.
2. Press simultaneously function buttons 2 and 3, until the
indicator lights of function buttons 1, 2, 3 and 4 start
flashing.
3. Press function button 4, the indicator lights of function
buttons 1, 2 and 3 turn off while the indicator light of function
button 4 goes on flashing.
4. Press function button 4 again, the "3 in 1" indicator light
illuminates, indicating that the "3 in 1" function is active.
To deactivate the function press function button 4 again, the
indicator light turns off.
5. To memorise the operation, switch off the dishwasher by
pressing the On/Off button or wait about 60 seconds after
which the dishwasher will automatically return to setting
mode.
Dado
Aug 29, 2016 | Zanussi Dishwashers
How do we put it through a test mode?
Here you go, both answers :>)
Bosch Dishwasher Troubleshooting Your Bosch dishwasher can run a test cycle which will quickly go through each stage of a wash programme in order to find out at what point a fault is occurring. It will only give you a general idea of where the problem lies but is a useful first step in diagnosing the issue.
The steps to start the test cycle vary depending on what model you have but the basic method is similar across the range. It might be that your dishwasher doesn't have the same button labelling as described in the steps below. In that case try holding down the buttons which have similar names. After a little trial and error you'll find the right combination.
  • Make sure the dishwasher is switched off.
  • Press and hold the Power Scrub Plus and Regular Wash buttons.
  • Turn on the dishwasher, then release the two buttons.
  • The light above each of these buttons should flash.
  • Start the test cycle by pressing the Power Scrub Plus and Regular Wash buttons again.
  • The test programme will begin and an error code will be displayed at the end of the cycle if a fault has been detected.
You can find a list of Bosch dishwasher error codes and their definitions here.
Error Codes are also here;
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/dishwasher-fault-codes/3058-bosch-sms-series-dishwasher-fault-codes.html
Sep 30, 2015 | Bosch Dishwashers
HOW TO FIX LE ERROR CODE ON SAMSUNG DISHWASHER DMR78AHS
An LE error code on your dishwasher stands for "LEaking."
There is, what I call, a drip pan on the bottom that the water is dripping into. Remove your dishwasher and take off the lower the side panels to get a look inside the drip pan. If you have water in there, try to find out where it's coming from.
If there are no signs of water, tip the dishwasher over on its side and remove the plastic panel on the bottom of the dishwasher. Once removed, you can disconnect the connector to the leak sensor (it's mounted upside-down, with 4 wires coming out of it. If I remember right, the wires are blue and red).
Flip the dishwasher back upright and plug it in and see if your LE error code pops back on. If it pops back on, then you have a bad board. If it doesn't, then you either have a leak, or the "fangs" on the leak detector are shorting out, somehow.
Oct 29, 2014 | Samsung Dishwashers
My Beko DW686 Dishwasher displays ER1 Error Code, there are no error codes in the manual, can you help?
reset error code 01. pulled dishwasher out removed kick plate tipped at 45 deg angle and found no leaks or water. turn6ff59c77-7c20-45c4-ac2a-e3c9e6fd4c14.gif breaker off and back on after 20 minutes still doesn't clear.
see tje diagram attached. God bless you
May 25, 2013 | Dishwashers
Why is fridge/freezer not performinf properly. Its in the garage but does not sem to be running properly
You might check the level on it; some types of compressors refuse to function if tilted a few degrees.
I assume you have checked the outlet you are using and have power available? If the outlet is dead, there may be a GFI (ground fault interrupter) that has tripped.
If was recently transported and not upright, this can require a couple of days to settle itself again.
Dec 23, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Cycle seems never-ending
on the ECO 50 cycle dish washer will not stop. have had to switch it off, when try to restart it automatically goes back to the ECO 50 programme. Can you please help. The Serial No. is ADP 2440 WH.
Nov 24, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Indesit dishwasher DI 450 stops after 10 mins
my disher washer dls 535 starts programme then lights 2 and 3 start flashing and does not work
Nov 19, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Programme won't finish and dirty water doesn't drain out ...
If you have a warranty on the dishwasher, I would call them to fix it>
Jul 06, 2017 | Belling 24 in. IDW603 Built-in Dishwasher
HELP WITH NON FUNCTIONING DISHWASHER
similar problems here, repair man says its fine but the salt light was on so i added salt and works ok now. Some dishwashers don't function properly without the salt and rinse aid, even though you're pills may have then included, you still have to add them seperately, dumb but necessary at times.
Feb 27, 2008 | Dishwashers
Dishwashers Logo
60 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
