Question about Motorola Mobility H700 Wireless Headset
No indicator light
I just received my H700 went to charge it for the first time but there indicator light doesnt work. I let it charge for 2 hours but still nothing. Is it defective? Appreciate any assistance. Thank you
  • lovettsa Mar 02, 2009
    only have green indicator light when charging. When I unplug from charger and flip open there are no indicator lights. Please help...
NEED PASSKEY 0000 WILL NOT WORK?
Posted on Jul 14, 2008
Just received a brand new, in original packaging, ...
Your headset should enter the pairing mode just by opening its boom. If it has never been paired before, it will be in pairing mode right away. Otherwise, make sure that the bluetooth radio of all devices preivously paired with it, are turned off (or, at least, out of reach). As soon as its boom is opened, and it can't find any paired device active, it will enter the pairing mode. Once your headset is in pairing mode, make the bluetooth application of your phone search for new devices. After a while the H700 should appear on the phone screen. Select it and make the application connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). The pairing process should be done only one. All subsequent connections between any two previously paired devices should be done automatically, provided that their bluetooth radios are on and with each other's reach.
Hope you are able to sort your problems out.
Regards, Carlos
May 19, 2010 | Motorola Mobility H700 Wireless Headset
H700 Motorola BT earpeice, no indicator lights aside from a green
Same thing happened to me. I call the support center and if you bought it from a 3rd party, it is probably a software problem. See if you can get a new one or buy it elsewhere.
Headset not charging
Sometimes it takes longer than two hours. Leave it plugged in overnight if you can. The indicator light should go off after fully charging.
Aug 14, 2009 | Motorola Mobility H500 Wireless Headset
Motorola H700 not connecting to nokia 6300
The factory code is 0000
Is there an error?
Enasure you are doing the pairing correctly
PUT HEADSET IN PAIRING MODE
1. Ensure the headset is turned off (indicator light not blinking and headset boom is closed)
2. Press and hold the Call button. After about 4 or 5 seconds, the indicator ight becomes steadily lit in magenta
3. Release the Call button and immediately open the headset boom. The indicator light remains lit in magenta.
If the indicator light is flashing in blue or not steadily lit when opening the headset boom, repeat steps 1 through 3
Jul 03, 2008 | Motorola Mobility H700 Wireless Headset
H700 / Samsung Blade: WILL pair. Won't Connect!
boom is closed)
light becomes steadily lit in magenta
The
Jun 15, 2008 | Motorola Mobility H700 Wireless Headset
Purple light
The purple (majenta) light usually means it is in pairing mode. Is it possible that the button is stuck pressed in??
2. Press and hold the Call button. After about 4 or 5 seconds, the indicator light becomes steadily lit in magenta
Jun 09, 2008 | Motorola Mobility H700 Wireless Headset
H700 will not charge
Replace the ac adapter (charger) with a new one
Jan 02, 2008 | Motorola Mobility H700 Wireless Headset
Connection problem
noavatar_s.png By nonexpert_s.gif Guest
Rank: Not rated
Rating: 0%, 0 votes
First, turn on your bluetooth on your phone.
Flip the boom mic on your H700 and hold down the call button for 5 seconds.
The indicator light should be purple. That means it is in pairing mode.
Then using your phone, attempt to connect to your H700.
It'll ask for a passkey. The default passkey is 0000.
Nov 08, 2007 | Motorola Mobility H700 Wireless Headset
My motorola H700 keeps staying red when charging
Wait, how long have you waited for it to charge? It's supposed to stay red until over 80% charge, then switch to yellow. When it is fully charged, it goes to green. When you mean it stays red when plugged in, have you waited the 2 hours?
Jul 10, 2007 | Motorola Mobility H700 Wireless Headset
Very poor battery life
Just another made in Chine "Amero" peace of shitt
Mar 22, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
204 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
