Question about AOC CT720G 17" CRT Monitor
Problem in my aoc monitor
My 21 ins. aoc monitor always display the osd even if i don't push the buttong for color setting and all the settings
  • Anonymous Jan 01, 2009
    the same described
  • 25 Answers
Pls replace control button 4no
Posted on Dec 12, 2008
My problem is how to open OSD LOKED OF AOC E 2237Fwh 21 inch LCD monitor
MY AOC LED 2237FWH SHOW OSD KOCKED SO HOW TO OPEN THIS? PLS SAY ME
Sep 29, 2012 | AOC e2237Fwh 21 inch LCD Monitor
AOC monitor says OSD locked
OSD means on-screen display. As you make adjustments, they are displayed on the screen. You may have to press the OSD button to unlock it.
Sep 06, 2012 | AOC V22 22" Monitor
RESET DELL MONITOR E1709WC
Instructions
    • 1 Push the "Menu" button on the front or side of your Dell monitor. The button's icon resembles a miniature monitor. This will open the main monitor setting menu. Push the button again to exit the main menu and open the OSD menu.
    • 2 Push the "Down Arrow" button on the monitor to scroll through the OSD menu. Stop at "Factory Reset." Push the "Menu" button to open the factory reset menu.
    • 3 Push the "Down Arrow" button to select "Position Settings Only" to reset the monitor's horizontal and vertical screen settings. Press the "Menu" button to activate the setting changes.
    • 4 Push the "Down Arrow" button to select "Color Settings Only" to reset the monitor's red, blue and green color settings. Press the "Menu" button to activate the setting changes.
    • 5 Push the "Down Arrow" button to select "All Settings" to restore the monitor to its original factory settings. Press the "Menu" button to activate the setting changes.
    • 6 Push the "Up Arrow" button to select "Exit" to leave the monitor reset menu. Press the "Menu" button to exit the OSD menu. Push the "Menu" button again to exit the main settings menu.
Aug 02, 2012 | Dell Computers & Internet
Osd main controler lockd
Hi there.
OSD Lockout or On Screen Display Lockout message is that irritating on-screen message that sometimes pops up when you switch on your monitor. This completely locks all monitor settings.
This problem has most likely happened to everybody at some stage or another. Everything has worked fine until now you turn on your monitor and have a message glaring you in the face displaying something about "OSD Lockout". This doesn't allow you to change any of your monitors settings, including the setting intended to turn off this message. While this problem mainly happens on HP monitors from my looking around I know that others have encountered it on other brands as well. The fixes I provide below should work on those monitors too so don't fear if your monitor isn't an HP model.
The HP Fixes
FIX 1
Plug in the monitor and power it up. Hold down the monitor's Power button until you get a message saying "OSD Unlocked". If the problem persists after OSD is unlocked then unplug the monitor from the wall, wait a few seconds (just to be sure I'd give it anything around 20-30 seconds) and then try again.
FIX 2
Instead of holding down the Power button, turn on the monitor and hold down the Menu button for 10-20 seconds. This should unlock the OSD.
FIX 3
Turn off the monitor, press down the Menu button and then turn on the monitor. Wait 10-20 seconds. This should unlock the OSD.
FIX 4
The Menu button may be stuck in a pressed in position. To get it "unstuck" you'll usually need to open up the monitor. If your not a seasoned veteran at opening up electronics (and knowing where all the screws go back into) then this could be tricky unless you know what you're doing. Unfortunately there are too many models of monitors for me to give a step by step instruction guide for you. If you have warranty this is where you should use it, I suggest you contact the manufacturer.
The AOC Fixes
FIX 1
Turn off the monitor, hold menu and power button together for 10 seconds then turn back on.
Currently these are the most commeon fixes.
~ Slasher_X
Sep 28, 2011 | Philips 190B6CB/27 19" LCD
How do I reduce the brightness of my AOC monitor?
If you are using windows XP :
1.Right click on desktop
2.Properties
3.Settings
4.Advanced
Windows 7:
1.Open Display Color Calibration by clicking the Start button , and then clicking Control Panel. In the search box, type calibrate display, and then click Calibrate display color. If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
2.In Display Color Calibration, click Next to continue
Aug 01, 2011 | AOC Monitor
My monitor is of AOC " e2043Fsk " . When I try
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Jan 03, 2011 | ASUS Computers & Internet
How do I make screen adjustments - brightness, contrast, etc.?
Press the OSD (On Screen Display) button, to display the OSD menu. Use the LEFT/RIGHT and UP/DOWN buttons to cycle through the various settings. Press the OSD button to "select" one of the settings to be changed. Use the LEFT/RIGHT and UP/DOWN buttons to alter the setting. Press the OSD button to "accept" the new setting.
Oct 23, 2010 | AOC Monitor
AOC monitor 2436vh does not fill the screen using the HDMI connector. There is a 1 inch black border around the window. Controls to stretch the display are locked out (not accessible) when using that...
The "Best Solution" fixes a problem that is unrelated to the original poster. anononline19's solution is to fix the entire OSD being locked (displays OSD Locked when the menu button is pressed).
Original poster's problem can be fixed by changing your graphics card's "overscan" settings.
Overscan on ATI cards:
http://nigelt.wordpress.com/2009/09/21/overscan-options-in-catalyst-9-9-on-windows-7/
Overscan on nVidia cards is currently not supported.
Oct 16, 2010 | AOC Computers & Internet
Color issues: Monitor cannot display proper colors
So are you saying "all of a sudden" as in instantly it happened. Something might of knocked it or it might be broken.
Apr 25, 2009 | Soyo DYLM24D6 LCD Monitor
AOC CT720G 17" CRT Monitor Logo
299 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
