Question about Dell E173FP 17" LCD Monitor
Monitor Flashes On and Off
My Dell Monitor flashes on and off. To explain in greater detail, the screen is completely black and about every second, it flashes on for a mili-second. Any suggestions / solutions?
Thanks
Tom
  • Anonymous Jul 15, 2008
    When I press the on button the image comes on for a second then it goes black, I turn it off and on again, the image comes on for a second and then it goes black again.
    Thanks
  • 1,031 Answers
If may be that the inverter board at the back of the screen may be bad and needs replacement
Posted on Jul 12, 2008
Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
Jul 27, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Today I noticed that when turning on computer, after 1-2 mins the screen goe black and I cant see anything. I noticed in the past month that occasionaly I get lightening flashes in the background. this...
To determine if the LCD screen is faulty ot the video card, connect an external monitor to the laptop's video port. Power up the external monitor first and the boot up the laptop. The video image should automatically switch to the external monitor. If you don't get flashes on the monitor then the video card is OK and the fault lies with the LCD screen. Flashes coud be caused by a faulty inverter or a faulty CCFL lamp. A fault is usually easier to diagnose when it is not intermitten.
Jun 08, 2009 | Dell Inspiron 6000 Notebook
Monitor E172FP only fashes on then turns black.
its a bad solder/heat problem with the power board you need to repalce eaither the board or parts on the board the parts on the board are:
Q743 - FU9024N
Q741 - FU9024N
Q759 - 2SC5707
Q739 - 2SC5707
Q760 - 2SC5707
Q740 - 2SC5707
and part PF751 the black fuse - 3A 125V
i don't promise that this will fix it but its worth a shot
Apr 10, 2009 | Dell E173FPb 17" TFT LCD Monitor
My dell 1905FP power button flashes green and will not turn off, the screen is black.
This is a common indication of a failure in the power supply. There are parts called capacitors that are used in the filter section of the power supply, when they go out the power supply can't properly turn on so you get no picture and a flashing power light. Here is a picture of the power supply board with the problem filter capacitors circled in yellow and below the picture in a link to a repair guide with details dis-assemble and repair instruction along with parts list for the Dell 1905FP and 1907FP models.
http://www.ccl-la.com/blog/index.php/repairing-a-dell-1905fp-1907fp-lcd-monitor/
Mar 25, 2009 | Dell UltraSharp 1905FP LCD Monitor
Flashing on and off
Is the monitor a LCD monitor and does it uses a power adapter?
If this is the case then it could be the power adapter that is faulty or if it is underpowered and the thermal overload cuts in then it switches off and when it cools it switches back on again.
Check the monitors power specs and the adapter should match the power requirements of the monitor or greater (ie. the voltage should be the same but the current rating should be the same or greater).
Feb 10, 2009 | Dell Inspiron E1505 Notebook
Display flashes DELL logo on power up and then goes black.
Try pressing Fn + Monitor. It sounds like you have it set to pipe video out to an external monitor.
Hope this helps.
Dec 12, 2008 | Dell Inspiron 6000 Notebook
Dell E151FPp LCD Monitor
Next time you reset, check both the monitor settings and your BIOS settings for wake up
Feb 24, 2008 | Gateway FPD2275W LCD Monitor
Monitor flashes on and off!
Sounds like you have a bad connection from your monitor to your computer. First check and make sure the connection between them is tight. Does your computer boot up and run though? If your computer is not booting up the monitor will default back to the flashing green power light
Nov 29, 2007 | Dell E173FP 17" LCD Monitor
Dell E173FP 17" LCD Monitor Logo
445 people viewed this question
Alun Cox
