Question about Imation (01946) External Floppy Drive
Imation superdisk drive
Looking for a winxp driver for imation superdisk moedl no. SD-USB-M2
am running Vistss home premium servc pack 1 but the xp driver will run under vista hope you can help thanks
JM
Imation super disk SD-USB-M2.Solution to run under Vista service pack 1.Works for me
boot up your puter then plug in the imation super disk into your puter's usb port then into your power sulpply socket.Then if you have a reset button on your puter Press it
the puter then shuts down and resets itself when the screen appears it asks "Start up normally" Press enter.The drive is recognised and works.Its a bit of a ball ache but works for me.Hope this helps others with the same problem
JM.
Posted on Jul 14, 2008
Why my external hard disk drive is not working on windows 7 home premium service pack 1?
Hi Suriani
Plug it in to another computer to see if drive is working OK
Might be nothing wrong with your windows.
Sep 08, 2014 | Imation 2.5 Apollo M100 Usb 2.0 External...
Imation 11795 driver WindowsXP
IMATION stopped making the "LS-120" (Laser Servo) drive many years ago, when USB-interface memory-sticks became cheaper & faster. Imation did have parallel-port device-driver software for Windows 95/98/ME, but never updated them for Windows NT/2000/XP.
Instead, disassemble the case, and you will find an IDE-interface Imation LS-120 drive inside. Connect the same "smaller" 4-pin power-connector that used to connect to a 1.44 Mbyte 3.5-inch diskette, set the "master/slave" jumper, and connect an 80-pin IDE ribbon-cable, and connect the other end of the ribbon-cable to an IDE socket on the motherboard.
Jul 06, 2014 | Imation Superdisk Drive 120mb Parallel...
Can I use super disc drive with my mac book pro
If the drive has a USB interface, Mac OS X will support it.
Mar 17, 2014 | Imation Sd-usb-m2 Superdisk Ls120 Floppy...
DRIVER FOR WINDOWS XP
Hello daaber40, Click on, or you may have to "Cut & Paste to Web Browser; this website: http://xpdrivers.com/microsoft/_2_135761.cfm?gclid=CKnEwKW3vaYCFVln5QodgjFgHw Thanks for using FixYa, paul7of9
Jan 15, 2011 | Imation (11762) LS-120 (SuperDisk) Storage...
(11762) LS-120 (SuperDisk) Storage Media: I have an older USB LS120 Drive and need the drive...
Download the software for drivers at
www.driverrobot.com
Use the following activation code :
DACG-KCCJ-AEB2-P52W-TATA
Run a scan with the software and install all the drivers you need.
Enjoy
May 18, 2010 | Imation (11762) LS-120 (SuperDisk) Storage...
I have a very old Imation superdisk drive, 9" by 6" size. And I can't find a driver to download
If it is the "internal" Imation SuperDisk drive, then set the drive's "master/slave" jumper (just like you would set the jumper on a disk-drive or CD/DVD drive), and connect it to one of the IDE ribbon-cable connectors (which usually connect disk/CD/DVD drives to the motherboard).
No additional drivers are required, in the above configuration.
Jan 23, 2010 | IBM SuperDisk (05K9235) Internal LS-120...
Need updated drives for my MAC OS 10.4 for floppy disk drive
Had a power failure now my model #SD-USB -M2 drive for macintosh will not work what do I need
Nov 24, 2008 | Imation (01946) External Floppy Drive
Imation SD-USB-M2 SuperDisk USB(MAC)
Sounds like a dead (or jammed) motor -- the one that spins the media. It's relatively easy to open the case, disconnect the USB-to-IDE interface adapter from the 40-pin IDE connector, and go onto eBay to find any "internal" or "external" LS-120 device, and swap it in, to replace the "not-spinning" device.
Jan 26, 2008 | Imation (01946) External Floppy Drive
Imation (01946) External Floppy Drive Logo
628 people viewed this question
Top Imation Computers & Internet Experts
Raj Patel
Jax Planet
Jax Planet
carey w mason
carey w mason
Are you an Imation Computer and Internet Expert? Answer questions, earn points and help others
