No sound other than from direct stereo or pure direct. Denon AVR 2808
when I was waching TV using Denon AVR-2808 the sound went off.
Decided to to check if the TV was in mute mode. still no sound.
After that i restarted the AVR, now there is no sound or video.
The only way i can have sound is trough direct stereo or pure direct.
Still no video.
have unplugged all input cables and connected only one Video RCA and configured only analog inputs. nothing.
Even the radio can only play pure direct. If i try to select dolby or 7.1 silence. All the visible fuses look ok.
  • dvdmrt Jul 13, 2008
    Thanks tech48,
    I resetet it several times with no avail.
    I Live in Angola. I bought my denon abroad 3 months ago. there is no dealer here.
    I would have to take it abroad my self for repair and then travel again to bring it back. This is almost impossible. Is there another way?
    I allready opened the device, power arrives to the board the problem seems to be as you say the board with the DSP. Is there a way i can by this board?
    Thank you and best regards
  • dvdmrt Jul 25, 2008
    Hi tech48,
    Out of the blue and after 15 days in pure direct, as sudden as the DSP stopped working it started working again. Thank you all.
    President:
  • 624 Answers
You can try this reset precedure below, but it sounds like you may have a DSP board problem. This is a new model of Denon, it should still be under Denon's warranrty, it has a 2 year warranty. If this does not help, you need to take it in to be serviced. If it is not under warranty, you will not like the cost of the repair. A new DSP board usualy cost about $300 and then you must pay for the labor. It is not cheap. This reset procedure has been know to work some minor miracles, lets hope it works one for you.
1. Switch off the unit.
2. Hold the following STANDARD button and DSP SIMULATION
button, and switch on the unit.
3. Check that the entire display is flashing with an interval of
about 1 second, and release your fingers from the 2 buttons
and the microprocessor will be initialized.
Note:��If step 3 does not work, start over from step 1.
�� All user settings will be lost and this factory setting
will be recovered when this initialization mode.
So make sure to memorize your setting for restoring
after the initialization.
Posted on Jul 12, 2008
Reset factory settings of my Denon avr 2800
From Denon support:
To reboot, turn receiver off using the small on/off button, not the big standby button. While off press the night and pure direct button at the same time and keep holding them with your right hand while pressing the small on/off button with your left. You will see your receiver menu flash. When you see it flash let go of the night and pure direct button and the receiver will reset it self to the radio station 87.50. The receiver's microprocessor has now been set back to factory default.
Sep 08, 2013 | Denon AVR-2800 Receiver
Avr 2805 only works on direct mode
You have a problem with your DSP circuit. Unless you are good at reading schematics and using DVM's and soldering, then you need to take it to a servicer.
May 16, 2012 | Denon AVR-2805 Receiver
I must've hit a couple buttons on direct tv remote
That's why they print manuals. What sound went out? TV or Denon speakers? We're not clairvoyant enough to back into the button sequence you MAY have initiated. I'd start with basic test tones.
Sep 20, 2011 | Denon AVR-1911 Receiver
How to connect and set up my DENON AVR-3300 to my LG tv. Waht connections on amp and tv do I use?
  • if you want to listen your TV on your Stereo system thru your receiver, AVR-3300 ** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver ( except Phone ) or "Optic Cable input"
** than just switch to respective mode on
AVR-3300 RECEIVER corresponding your RCA or Optic connection...
There you go..Your TV sound is on the
AVR-3300
Receiver..By this means whatever you watch on the TV (tuner, satellite , Xbox ) ,it's sound will come thru your stereo..
  • Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Mar 28, 2011 | Denon AVR-3300 Receiver
What is night and pure button?
'Night' compresses the audio's dynamic range to make soft sounds more audible and loud sounds less loud for a given volume setting. The assumption being that there are people sleeping while you're listening or there's so much environmental background noise that you won't hear the soft sounds. It sort of defeats the whole reason for having HIGH fidelity sound. Ditto for D.Comp.
'Pure' bypasses all internal analog processing (page 25). Why? Who can say? Other than to diagnose a problem. If the tone controls are contributing to the sound they don't belong in a Denon product to begin with. The implication is that to NOT use Pure or Direct is to inflict audible limitations on the sound. And you may lose control of the sub, too. Oh goody.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Denon-AVR-2807-Receivers-manual/id/363bh826/t/2/
Feb 26, 2011 | Denon AVR-2807 Receiver
Only sound from Direct and Stereo settings on Denon AVR 788
Other listening modes (dolby, dts, neo6) are decoded from digital signals.
Direct will relay your only your discrete analog inputs - so if you want to use your AVR as an amplifier for those channels, you'll need to supply an input signal in a different manner.
Nov 16, 2008 | Audio Players & Recorders
Lost audio for no apparent reason
Try unplugging your HDMI cable from the AVR I would like to see if your AVR is trying to use HDMI out instead of the composite. Next try plugging each device directly into your television, this will isolate the issue and tell us for sure whether or not it's the AVR.
Jul 10, 2008 | Denon AVR 2808Ci Receiver
Sound is working only in mode PURE DIRECT
TRY PUTTING DVD PLAYERINTO ANOTHER DIGITAL IN PUT, ALSO CHECK DVD OUT PUT IS STILL BITSTREAM.
IFF YOU STILL HAVE A PROBLEM CHANGE THE CABLE,AND IFF IT STILL FAILS 2 WORK TAKE AMP 2 YOUR DEALER.
HOPE THIS HELPS.
CABLE GUY.
May 19, 2008 | Denon AVR-4802 Receiver
Getting out of Pure Direct mode
One way to solve that is to use your remote. There are modes i the same area - direct mode is one of them. Chose one of the others next to it.
Mar 09, 2008 | Denon AVR-2807 Receiver
No sound on cable TV for Denon AVR 1905 Receiver
Audio setup on the TV, needs to be swited to Fixed or both, this is usually the same on all T.V.s....
Jan 20, 2008 | Denon AVR-1905 Receiver
865 people viewed this question
 Grubhead
Grubhead
