Question about Kitchen Ranges
I inadvertqantly set the baking time feature on my maytag oven, and now the oven is on and I can't turn it off
  • 254 Answers
Try holding the time baker button for 5 seconds see if ti cancels.
Posted on Jul 12, 2008
Preheats very slowly. Also, steam cleaning option seems to not be effective due to low heat. Is there more than one lower oven heating element?
For the oven their is 2 elements 1 for bake and 1 for broil,are each glowing red hot on the respictive settings of bake and broil? their is no trird hidden element. Plus i know manufactures come out with new features all the time,i attend factory trainging sessions a couple times a year but i am confused as to what the "STEAM CLEAN OPTION" IS??
THE SELF CLEAN cycle utilizes both elements to clean the oven adding steam is a new one on me
Aug 21, 2011 | Maytag MER7775W Electric Range
I turn the oven to 350 degrees and it never gets hot.
First, I guess we need to define hot. If you mean hot enough to bake whatever it is you wanted to bake, then it's possible, if this is a unit that has a "timed bake" feature, that someone neglected to put the control back in manual mode, after having used the "timed bake". If this happened, then the oven will only heat to 160 - 180 degrees, and will maintain that temp. It's called a keep warm setting, which is designed to keep the food that was recently baked, warm, until someone can come get it out and served. Check this feature if you have it and see if it's in manual mode, if not change it and the oven should heat up to 350 and beyond.
If there is NO "timed bake" feature, and there's some heat, just not enough to get to a bake mode, then it's possible that the oven's ceramic glo igniter is cracked and not heating to the point that it allows the oven's safety gas valve to open for gas flow to the burner. If there's no heat at all, the problem could still be the igniter, but it could also be electronic control box feeding the igniter. These things must be checked by a tech with an ohmmeter, and possibly replaced.
Mar 24, 2011 | Ovens
Bake button does not work.
if the buttons are the touch pads then your control has failed and you will have to replace it .mm
Jul 14, 2010 | Maytag 30 in. Electric Single Wall Oven...
My Maytag Performa oven and stove top will not turn on (heat up)
When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean" doesn't work either. The oven will lock, and display shows that it's heating up, but temp. never rises.
However....."broil" feature works just fine.
Please help.
Mar 09, 2010 | Maytag 30" Built-In Single Electric Wall...
Maytag Gemini Electric Oven - Lower is not locked, but will not open.
Usually, starting with a COLD oven, turn the self clean on. Wait 3 minutes, then turn it off [cancel] WAIT 1 minute at least, do not immediately pull on the door. This should reset the lock sync. If you cannot get it open still, you may have a faulty sensor that thinks the oven is overheated, or at this point you could have a bent actuator rod from all the tugging!
May 01, 2017 | Maytag MER6772 Gemini Electric Kitchen...
Frigidaire electri-clean oven Model RSE37BAL*5
make sure that the clock is displaying the current time of day
select timed bake
select the temp of the oven you wish to bake at
set the time you wish the oven to come on with the start knob
set the time you wich the oven to turn off with the stop knob
Apr 11, 2008 | Ovens
Maytag MER5755Q2Q OVEN GREMLINS
Hi TbearFTW,
Try the Sabbath mode feature. It may realease the oven to cook for longer. Press the Clock button for more than 5 seconds. I think that is what you do to get the Sabbath mode canceled or set.
Nov 14, 2007 | Maytag MEW5530D Electric Single Oven
I need to disable my ovens auto shut off
The control is automatically set to turn off the oven after 12 hours baking or 3 hours broiling should you forget and leave the oven on. If you want to remvoe this feature do the following steps: 1. Press and hold, at the same time, the BAKE and BROIL buttons for 3 seconds, until the display shows "SF". 2. Press the DELAY START TIME button. The display shows "12Shdn" for 12 hour shut off. Press the DELAY START TIME button again. The display will show "no Shdn" for no shut off. 3. Press the START button.
May 21, 2007 | Kenmore 33464 / 33465 / 33469 Gas Single...
Kitchen Ranges Logo
74 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
