Question about HP Pavilion dv6000z Notebook
Dvd drive not responding with dvd but getting responded to a cd.......how can this be rectified..........pls tell me the trouble shooting way
    President:
  • HP Master
  • 1,314 Answers
This is because your optical drive has gone bad. The CD and DVD uses two different lasers to read cds or dvds. The dvd laser has gone bad and the drive will have to be replaced.
Thanks and please take a moment to rate as fixya. Thank you.
Posted on Jul 12, 2008
I have an Acer Aspire1 Netbook and below is the problem. Went to BIOS set defaults but still get the same thing: For Atheros PCIE Ethernet Controller... check cable connection PXE-MOF:exiting intel PXE...
A computer tries to "boot" from many devices:
* 3.5-inch floppy-disk (if available)
* USB memory-stick (if connected)
* internal CD/DVD device
* external CD/DVD device
* internal disk-drive
* over your network-cable, by talking to a "network boot server".
When it tries to boot over the network-cable, and *NO* "boot-server" responds,
you get the "check cable connection" and "exiting from P(re)(e)X(ecution)E(nvironment)" mode.
If it cannot boot from your 'C:' drive, and cannot boot from the network boot-server,
your computer responds "no bootable device" and "insert boot disk" (into CD or floppy-disk),
and "press any key" (to try again to boot).
What this USUALLY means is that your 'C:' disk-drive has stopped working,
meaning that Windows cannot be "booted" from it.
Seek help from a qualified technician to trouble-shoot your disk-drive, and/or to replace it, and/or to reinstall Windows, and/or to "repair" your existing Windows installation.
Dec 28, 2010 | Computers & Internet
My computer not responding when dvd disc inserted
Again Install Windows and then install PowerDvD to fix this problem.
May 31, 2010 | LG SecurDisc 20x External Double-Layer DVD...
My cd drive runs like it's starting then it just stop can't install any programs pls help
You could spend $40 to get a qualified technician to trouble-shoot the drive, or you could spend $40 to buy a brand-new CD/DVD reader/writer.
Apr 16, 2010 | Compaq (120192-B21) CD-ROM Drive
My dvd drive does not open or responds green light
hello, here is the simplest thing to do if your cd/dvd is stacked inside. 1. punch through the hole infront of your burner using a paper clip, that will force the cd door to open, try it..
Nov 25, 2009 | Pioneer DVR-107D DVD±RW Burner
Optiarc DVD RW AD-7563A ATA Device will not play cd's/dvd's I have the same problem. Its not replicable. Sometimes it shows up in "My Computer", when it does it works fine. Other times it will not appear...
Hi Christmans, Its some times happen if any virus has been attacked, so first chek that your computer is virus free, if still you are facing it then right click on the dvd drive icon in my computer and then click on the properties, and select the Hardware option there at the bottom you can see the option "Trouble shoot" by clicking on it you will get a window there by following the instructions you can solve your problem, I think you can do it. If any problem send an email to me.k Bye
May 30, 2009 | Gateway (5500652) (  5500652)...
I have a new sony vaio VGN-FW230J that recently the dvd drive has stopped opening and when i found the button to manualy open several disks will not play at all. I am currently in Afghanistan so it is...
due to dusty environment as in the area u mentioned it happens the lens gets dusty and when it tries to read during that period it doesnt respond to the opening button so the only solution is
open the dvd tray u can see that shiny eye like thing try cleaning th lens gently in round movement with a tissue paper or very soft cloth used to clean lcd screens see if it works , other wise ur DVD drive lens got weak from use now adays service centers are getting tons of them everyday for replacements
next time if u get into trouble try pressing the eject button for like 5-8 sec it will respond otherwise restart immidiately then it will respond to ur press when the sys is restarting take out the disk and try the cleaning process
pls do rate me if i fixed what u wanted
Feb 24, 2009 | Sony VAIO VGN-FW230J/B Notebook
G-drive is not working
Try removing battery and unplugging AC adapter for 5 minutes.
On startup press repeatedly the eject button on CD before system starts loading.
If that does not work , you will need to take the computer to a repair shop, as DVD unit must be disassembled to take disk out.
Feb 02, 2009 | Lenovo 3000 Y410 (59012354) PC Notebook
Laptop trouble
There is a problem with your DVD drive, then. I think it is unable to detect because there is dirt on the delicate little lens or some other problem.
Clean the lens with a cheaply available lens cleaning disc a special anti-static cloth made for these purposes.
Or see if the PC itself detects the drive. If it doesn't, restore the system to the time when it was all okay. Use System Restore.
If nothing works, show it to a doctor, and maybe you have to change it.
Nov 27, 2008 | Acer Aspire 4720 Notebook
Laptop trouble
see it is problem with your dvd drive try with dvd lens cleaner if still it is not working then show it to service personnel. bye
Sep 23, 2007 | Computers & Internet
DVD drive some time works, some time does not
first try uninstalling the dvd drive go to start/control panel/system/hardware/device manager look for dvd/cd-rom drives right click dvd - uninstall reboot afterwards so winxp will re-install drivers if this does not work, go to toshiba.com look for downloads for your dvd/cd drives just make sure you have the right model so the file you download will be exact and correct
Jan 21, 2007 | Toshiba Satellite Satellite 5200 Series 15...
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
