LG direct drive washing machine is getting increasingly noisy when at the spin stage
    Problem Solver:
  • 5 Answers
Generally when a machine gets noisy in spin cycle it is due to bearings being worn open the door with the machine empty and try lifting the the drum upwards if it moves then it will be the bearings
Posted on Sep 21, 2009
Noisy during spin cycle
Yes that is definitely bearing noise you here.
Jun 21, 2017 | LG Washing Machines
My LG Washing machine is not spinning. It also comes up with OE. Can you help
Check to see if the drain pump or drain pump filter are clogged. Sometimes objects that are put into the washing machine, for example combs, money, hair pins, etc. end up in the filter. Finally, if the drain line is clear and the pump seems to be clear and functioning properly, you may need to replace the drain pump assembly.
The most common problem with spinning on this model machine is the tub bearing. Normally it would be very noisy when it did spin.
Massive job to replace it.
Dec 06, 2014 | LG WD-1070QDP 7 Kg Direct Drive Washer
Fisher & Paykel GW712 washing machine Hi Fixya ,
follow this steps and fix it. God bless you
Level
If it is shaking and not sitting flat ( should have no rock corner to corner) check the leveling legs. Make sure to tighten up the locknut after adjusting.
Timer
Sometimes a Timer will start making noises before they fail. I would highly suggest replacing the timer as soon as the noise develops. This can cause problems with your motor and other components if left alone. This is easy to identify just listen up near the console when running.
Transmission
The transmission does not usually fail but to check this on a direct drive remove the motor and rotate the inner tub and listen for noises it should be quiet. If not the transmission is expensive and you will need to evaluate wether it is worth repairing.
Motor Coupler
On direct drive machines this is a common failure and can be very noisy.
Motor
You will need to disassemble the motor to listen to the motor running. If the motor is noisy it will need replacing. On direct drive models check the motor coupler first.
Suspension Rods
The Suspension Rods support the tub under the cabinet on some models. The washer must be disassembled to access. These usually do not fail. On direct drive types there will be springs instead of suspension rods. Either usually fails but can from being overloaded.
Drain Pump
The drain pump can be the cause of noise. On belt drive types remove the belt and rotate the pump pulley it should spin freely and make no noise. If it is noisy replace. If it does not spin freely remove and inspect for obstructions if none found replace the pump. Check the impeller on the pump it should be tight and spin freely. On direct drive types remove the pump and inspect it
Jul 09, 2013 | Washing Machines
It make a whirling sound on the spin cycle
see the causes, and proceed with common sense, God bless you
Level
Timer
Transmission
Motor Coupler
On direct drive machines this is a common failure and can be very noisy. To check and replace the motor coupler watch the video.
Motor
You will need to disassemble the washer to listen to the motor running. If the motor is noisy it will need replacing. On direct drive models check the motor coupler first.
Suspension Rods
Drain Pump
The drain pump can be the cause of noise. On belt drive types remove the belt and rotate the pump pulley it should spin freely and make no noise. If it is noisy replace. If it does not spin freely remove and inspect for obstructions if none found replace the pump. Check the impeller on the pump it should be tight and spin freely. On direct drive types remove the pump and inspect or replace.
Sep 22, 2012 | LG Washing Machines
Very noisy when on spin. The machine seem to be balanced however the noise on spn is like a jet taking off. it gets louder as the spinning speed increases.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Mar 28, 2010 | Maytag Washing Machines
Very noisy on spin cycle only
Hi, please describe the type of noise you are hearing. If it is a grinding type noise, it is likely to be the drum bearing.
Oct 25, 2009 | LG WM1814CW Front Load Washer
Very Noisy Operation
you will have to access the bottom of the agitator from the back of the machine. Either you have loose bolts or else you agitator bearings are shot
Jan 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
WFT7016PP
I have a LG WF-T 7016PP it does not want to go from wash to rinse to spin. I must manualy take it through all the stages. It works perficly on all stages but just does not want to switch over automaticly.
Oct 14, 2008 | LG WFT1071TP Top Load Washer
Wm noisy
drum bearings, check and investigate, remove drive belt and then rotate, if still noisy then yes its the drum bearings, if the noise stops when the belt removed the motor bearings are faulty costly repair on most models, sorry oh there is also the possibility there is something lodged within the drum cavity between the lining and the drum casing
Sep 25, 2007 | LG WD-16110FD Front Load Washer
Hotpoint ultima wt960 washing machine noisy on spin
Bearings faulty or another fault this model suffers from is the concrete balance weight retaining bolts shake loose, if it is the bolts tighten up as soo as possible. Regards Advisor
Aug 21, 2007 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
787 people viewed this question
Top Washing Machines Experts
