Question about NEC MultiSync LCD1525V (White) 15.1" LCD Monitor
Moniter the screen does not stay on it just blinks the power lights is yellow
Moniter power light blinks purple.
Inspect the power supply and also try it on another PC too.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
May 30, 2010 | Smart Modular SV3170A
Lg Flatron 17" monitor turns on you see the green light then
it's prb.. your video card not the moniter if a moniter goes from green to yellow " standby" it's prb the computer not the moniter
Dec 27, 2009 | LG Flatron L1715S 17" LCD Monitor
Gateway moniter has black screen , power button blinking yellow
have you tried using another computer?if it works with another computer your video card in the computer you are using is bad.
good luck
Sep 09, 2009 | Gateway VX 720 17" CRT Monitor
No picture on screen but power light blinks
May be the problem with your Pc. If you can hear a beep sound when booting the Pc is Ok. Otherwise check memmory for loose connection.
May 03, 2009 | Computers & Internet
Screen goes black, but power light is on (not blinking)
The problem is not with your screen. Its the problem of Video Card of your system which is unable to send Video Signals to the Screen.
Apr 23, 2009 | Daewoo L700C 17" Flat Panel LCD Monitor
No picture. Yellow light stays on. No blue light !!!
the problem with the CPU might be the graphics card is down
u should check the ram connections....
also check if ur moniter works on other CPU's or not
if not then this might be a problem with the moniter
Oct 25, 2008 | Gateway FPD2185W 21 in. LCD Television
Oversize Message
run the system on safte mode and then try to manage your screen resolution to minimum and then restart it normally..
dont forget to rate
Jun 20, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Blinking Screen?
it is monitor problem,it should be EHT problem
Feb 29, 2008 | LG Flatron L1750S 17" LCD Monitor
NEC MultiSync LCD1525V (White) 15.1" LCD Monitor Logo
21 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
