Try swapping the speakers around if the problem still persists either the speaker is faulty or the speakers plug/outlet is
usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
hope this helps
