Question about Lexmark Office Equipment & Supplies
My Lexmark X2550 is malfunctioning. a document is stuck in the print queue with the status ''deleting''. I have tried stopping and starting the spooler but this does not solve the problem.
  • 62 Answers
SOURCE: printer document in queue will not delete
1. First, try turning printer off and on.
2. Next, on the computer side, this is how you manually clear the printer queue.
1. Go to Start, Control Panel and Administrative Tools. Double click on Services icon.
2. Scroll down to the Print Spooler service and right click on itand select Stop. In order to do this, you need to be logged in asAdministrator. At this point, no one will be able to print anything onany of the printers that are being hosted on this server.
3. Next you need to go to the following directory: C:WINDOWSSystem32spoolPRINTERS.Delete all the files in this folder. This will clear all print queues(it’s a good idea to first make sure there are no other print jobsbeing processed on any of the other printers on the server becausedoing this step will delete those jobs also)
4. Now you can go back to the Services console and right-click and choose Start for the Print Spooler service!
You can also go to a command prompt and type net stop spooler or net start spooler to start and stop the service.
I hope this helps. If you have more questions, let me know.
Posted on Jan 09, 2009
  • 684 Answers
SOURCE: Document in queue won't print.
In this case what i would request u to do is:
1. Let the Printer be Connected to the Computer......
2. Click on start then Click on Run or If Windows Vista Type Services.msc Under the Run Window if XP,Under Start Search if Vista.......
3. On that Services Local Window u need to find Print Spooler just Double Click on that and Click on Stop..........
4. Now let that Window still be Open now click on that start Menu Click on Run If XP........
Type in "Spool" and Click Ok...........
5. Double Click on Printers and Delete Each and Every File Inside the Printers Folder...........
6. Now Close this Window and now u will be back to the Print Spooler Window now u can click on Start under the Print Spooler....
Now Try to Print Will Work Fine....................
Good Luck :)
Posted on Mar 04, 2009
dagr81
  • 59 Answers
SOURCE: Print queue will not clear after printing
dear sir
this is a typical usb inkjet printer problem
just follow the steps
open notepad
and copy paste
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
and save as delete.bat file on desktop
run this file and reboot the machine
and run this file again
now print queue will get cleared
thanks
Posted on Apr 10, 2009
techbuster
  • 5081 Answers
SOURCE: Document won't delete from printer queue after printed
Have you tried to stop the spooler service in services?
Option 1)
Click on start orb
Type in search window:
services.msc
click ok
Scroll down to Print spooler service and click on it in the right side window.
On the left side click stop the service and wait forthe process to stop .Do not close the window yet. You will have to restart it here later.
next delete the print job in the printer queue then restart the spooler service
Resubmit your new print job.
Option 2)
If that doesn't clear it, the next step would be to stop the spooler
service as stated above
Go into windows explorer
(Print job data is collected and stored in a spool file in the spooler folder.)
It is located in:
C:\WINDOWS\system32\spool\PRINTERS
Your print job will show 2 files there Example below:
00002.SHD
00002.SPL
Delete the files located in there. There may be several of them depending apon how many print jobs you submitted. You will have to resubmit your print jobs all over again.
Next go back to services window and restart the spooler service
That will definitely fix it.
Posted on Aug 19, 2009
SOURCE: document stuck in queue and will not delete or print.
Its a common problem. All you have to do is to restart the Print Spooler service and delete the print queue. To restart the service follow the steps: Open Control Panel > Administrative Tools > Services. Now find service named "Print Spooler" and right click over it and select "Restart" to restart the service.
Now open the "Printers and Faxes" folder and try to delete the print queue. Now you will be able to delete the print queue. If applicable you can follow the steps once again if any print queue refuse to get deleted.
Once the print queue is empty, you can print from your printer smoothly.
Cheers!
Posted on Apr 05, 2010
Status - deleting printing
Sometimes a job will get stuck. If rebooting does not work, right click My Computer > Manage. Go to Services and Applications > Services. Stop the Print Spooler.
This will need to be done by an IT admin if the printer is at work and on a print server. Don't forger to start Spooler.
Jan 24, 2013 | HP psc 1310 series
My Lexmark s605's print queue won't clear, and so the printer has stopped working altogether
Please follow the steps below to clear the print queue and restart the print spooler of your computer.
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
Try to print a document again to verify that the problem is fixed.
Jan 07, 2012 | Lexmark Interact S605 All-in-One Color...
Need to delete document in queou
Try the steps below to clear print jobs stuck in the print queue:
4. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Try to print again to verify that the problem is fixed.
Dec 23, 2011 | Lexmark X2500 All-In-One Printer
Print spool never empties. pages will not delete
Please follow the steps below to clear the print queue from stuck print jobs:
4. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh. Try to print a document again to verify that the problem is fixed.
Sep 24, 2011 | Lexmark X8350 All-In-One InkJet Printer
Printing blocked by a document showing being deleted
Sounds like a stuck document is in the print queue. Try to clear the print queue first before sending another print job otherwise it will just accumulate in the queue. The steps below will help you clear the queue.
Feb 21, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
I cant get a print job to delete from the queue and its holding up all the other jobs
To delete print jobs stuck in the print queue on Windows:
  1. Click Start ? click Control Panel ? click Printers and Faxes.
  2. Right-click on the Lexmark print object and select Cancel All Documents.
  3. If that doesn't clear the queue, restart your computer.
If print job(s) still remain in the queue even after doing the steps above:
Stop the Print Spooler service from the Services console
  1. Click Start ? click Run ? type cmd ? click OK.
  2. Type net stop spooler at the command prompt ? hit Enter on the keyboard.
Clear the SPOOL folder
  1. Click Start ? click Run ? type spool ? click OK.
  2. Open PRINTERS folder ? delete all files in the folder.
Start the Print Spooler service from the Services console
  2. Type net start spooler at the command prompt ? hit Enter on the keyboard.
Try to print again after clearing the print queue.
Nov 24, 2010 | Lexmark Z611 InkJet Photo Printer
Lexmark z31 printer will not stop printing
Disconnect printer cable from PC. Power off printer and unplug power cord from outlet. Wait 15 seconds. Press the power button as if to turn on with unit still unplugged. Plug back into outlet and turn on printer.
Before reconnecting to PC, check the printer's queue status. Start, Control Panel, Printers. Select the printer by double clicking to open queue status. Select any remaining documents and choose cancel from document menu bar.
Bret
1-2-1ComputerServices
Oct 04, 2009 | Lexmark Z31 InkJet Printer
I tried to delete a print job and it is stuck in the queue. Won't print or delete
Thanks for using FixYa!
Try to turn the printer off then restart or reboot your computer. Then pull up the print queue then delete the documents in queue. I hope this helps.
Have a wonderful day.
- HotRatchet
Jul 30, 2009 | Lexmark X2500 All-In-One Printer
Printer stopped working
Turn printer on and off if that doesnt work then ust restart, sometimes things get stuck in the queue.
Apr 24, 2009 | Lexmark X1150 All-In-One InkJet Printer
I can't "delete" a document from the que
Option 1)
Click on start orb
services.msc
click ok
window.
stop
Option 2)
folder.)
It is located in:
00002.SHD
00002.SPL
Apr 10, 2009 | Lexmark International Z611 Printer
47 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
