Question about Lands Phones
Lg ku990 conflict wth startup wizard(even though its closed) when trying to transfer images to pc.
  • Anonymous Oct 25, 2008
    I got the same problem, it wont let me put music on it?
  • lougem Mar 10, 2009
    i have problems adding music to my phone from computer as it keeps saying there is a conflict with start up wizard..help
SOURCE: LG Viewty pc connection problems
What you need to do is click on the top right corner of your LG Viewty phone which will show all applications running. If you have an 'Unknown' app, click on this.
The problem is that the user guide for the phone is running and you need to click on 'Unknown' and finish the tour or exit.
This will then alow you to connect to your pc;-)
Posted on Feb 14, 2008
  • 3 Answers
SOURCE: My LG Ku990 Viewty phone wont connect properly to my pc
just change the connection too mass storage on usb connections (phone settings) and then scroll to the bottom and click view files :)always works for me
xx
Posted on Jan 30, 2009
  • 50 Answers
SOURCE: My LG KU990 can not see my micro sd card .
when you go into my files on he phone scroll right to the bottom and it should say external memory or memory card.
i hope this was help...
Posted on Feb 14, 2009
SOURCE: TRANSFERRING MUSIC FROM PC TO LG KU990 VIEWTY
Right, this worked for pictures and stuff, so it SHOULD work for music.
1). Before plugging in phone to computer, change the settings from Data whatever to Mass Storage, you can do this by going to phone settings, connectivity and then highlighting Mass Storage.
2). Plug in phone.
3). Wait for your computer to find the drivers and such. And viola!
Now, it probably won't connect through the connection wizard, but you don't need that cos your computer should automatically bring up a list of options and you want to click "View Folders" or something similar. If not, then go to My Computer and you should be able to click onto your phone icon and get into it from there.
That worked for me anyway, after spending nearly four hours fiddling with it.
Posted on Feb 22, 2009
SOURCE: I cant transfer pictures from LG ku990 to pc
Go to Connectivity in your phone settings under the settings submenu.
Select it, and change it to mass storage, if you have an SD card, you can use this to put files onto your computer.
Posted on Apr 12, 2009
Hi same problem here. The "content" menu wouldn' t work, though i' ve uninstalled / reinstalled LG PC Suite many times. Why do they sell a software that doesn't even work correctly, and just let custo
The main LG PC suite screen is flawed and doesnt work for anyone, right click the sys tray icon next to the OS clock and access contents through that method, its the only way to get into it. Otherwise, go to the phone settings>connectivity and change usb mass data transfer to on to use it as a normal removable media device. Data transferred via the USB mass storage will transfer a lot quicker than using the PC suite too.
May 20, 2009 | LG KU990 Viewty
My Lg Ku990 won't connect to the computer
dont no if this helps but worth a try, on ur phone go 2 phone settings > connectivity > USB connection mode > chamge it to mass storage. then re-connect it 2 ur comp and will will show up as a mass storage device where u can do the drag and drop option. only problem is it transfers media from ur phone but dont no how i can get things off memory card without having 2 transfer them 2 phone memory first.
Apr 26, 2009 | LG KU990 Viewty
Hi, I just had the exact same problem..
I tried like FOREVER and I even said, if this try doesnt work; i'm giving up, and then... it finally worked.. haha :) so, this is what I did.
(dont connect your phone yet but set your phone as data service) You open the program LG pc suite, and then click connection wizard > usb > and then here, you connect the both ends of the usb.. one end on your pc and the other on your phone, and then you press next. Hopefully it says something like Com Port Number and Phone Model. You click next and finish. So, now you are connected to the phone to your pc. To get photos to your pc, you click content. images. and copy and paste to where you like (pictures in your pc) and then your done :D this also goes to other files too :D if this doesnt work, then go to your right top corner box, close all applications and go to home screen! :D
I hope this really helped because I just learned it few minutes ago and I was about to scream because I tried so many ways. Hope this helped and Good Luck :D
Feb 16, 2009 | LG KU990 Viewty
My LG Viewty will not connect to my PC
make sure the phone is on data transfer (in phone settings - connectivity - usb connexion) if your using the lg suite.... plug the phone in first (to USB cable) then start the pc suite ,, if nothing... try using the connection wizard thing ,, it will search for connected phones.
Jan 13, 2009 | LG KU990 Viewty
I had the same problem. It was caused by the phone waiting for the date to be entered (even though it was already done). To get over the problem click on the multitask icon on the phone (top right). If anything is running other than "Home Screen" and "Menu" click on the application and close it. PC synchronisation should strat to work now.
Dec 30, 2008 | LG KU990 Viewty
LG Suite
Download this software from this link
http://www.fullandfree.info/mobile/lg-ku990-viewty-pc-suite-official-v20115/
enjoy!!!
Sep 21, 2008 | LG KU990 Viewty
My lg viewty
why doesnt my pictures from my phone transfer onto my computer??
Jul 15, 2008 | LG KU990 Viewty
Lg veiwty
First connect the phone using the USB cable provided.
Open the LG PC Suite software. On the left hand side is a connection wizard select this and then USB.
Don't change any of the port information.
Once it has connected, select contents.
go to your picture folder and then just drag your pictures onto it.
DONE!
May 29, 2008 | LG KU990 Viewty
Lands Phones Logo
348 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
