Question about Umax Astra 1220P Flatbed Scanner
Colour of the scanned copy
When i use the scanner the colour of the output copy is so much green.
and so thet i can't see the copy properlly.
please send me the solution it's urgent.
Clean the mirrors of the scanner, which is located on the moving carriage, That is what worked for me and now it scans like new.
Posted on May 23, 2009
Make colour copy
The Button with the green symbol on it would be the Color copy button!
May 11, 2013 | Ricoh Aficio Mp 4000...
Always have to rotate to 270 is this normal. I have to five copies and thet all have to be rotated
The Canon 5010/5020/9080c/7580C etd are duplex scanner (can scan both sides in one go). If you select simplex i.e., only top side, you will get the image straight, unless you have changed the settings in the scanning software. I am assuming you are using CapturePerfect software. Please switch off the rotate option in Capture perfect and the scanner output will be as you see it.
S. Mohan
Sep 15, 2009 | Canon DR-5010C Scanner
Black and white scanning, as our scanner scans in colour, I would like to know how to scan in Black in white so to have smaller files. Thanks Sonia
You must select TIFF format for B&W. TIFF G4 format is the smallest. JPG offers both grey and Color outputs.
S. Mohan
Aug 26, 2009 | HP Scanjet 8250 Flatbed Scanner
Hp 5400c scans blue images
sounds like a faulty scanning head to me......
when images are scanned they are normally imaged in 3 colours red blue and green these are then combined to give a full colour scan. sounds like you are only getting the blue pass.
not alot that can be done here, if it is in warranty (check with manufacturer for duration of warranty as sometimes this can be more than a year) they should repair or replace this for you
Apr 23, 2009 | HP Scanjet 5400c Flatbed Scanner
Green/yellow colour
Just Clean the both inner mirror with clean cottorn dry cloth and also clean the lamp tube of the scanner.
and u should always clean the scanner regularly. so it will be working fine.
Aug 27, 2008 | HP ScanJet 3200C Flatbed Scanner
DR-9080C BackgrounfColour Dropping Out
Color scanning is a big technology. There are concepts like Hue and intensity, refer to wikipedia for explanation. There is something called source light (your monitor for example) and reflected light (your picture that is being scanned). After scanning properly, say you view on a monitor where the Brightness & Contrast are not proper, you will see the image poorly! To test the scanning scan absolute white and check the output. It should read the values 255,255,255 for RGB (Red, Green & Blue). If the values are 255,255,255 but still the image does not appear white on the monitor, it is monitor setting that is wrong. If the output is not 255,255,255 then CANON service personnel only can help. Any good imaging software will display the RGB values.
CANON uses LED light source and they have fairly long life as compare to scanner bulbs. It is okay if you use a powerful system, but it has limited role as the scanner does all the jobs and it only sends the data to the Comp. May further processing is better withe high performance CPU and large RAM.
Aug 05, 2008 | Canon DR-9080C Path-Through Scanner
The scanner output problem
replace scanner ccd or replace scanner cable
Mar 17, 2008 | HP ScanJet 2400 Flatbed Scanner
DR 2050C
This has something to do the brightness chosen. In the manual mode, if you choose a dark output, the output will have tis area also; if you choose, lighter output, it will omit. In the auto scan mode, the scanner decides what is the best output.
S. Mohan
Dec 19, 2007 | Canon DR-2050C Path-Through Scanner
How do I scan colored paper and still read print? HP Scanjet 8270
First thing to try is just play with all the scan settings to see what gives you the best result - try changing resolutions, type of document, type of output document, contrast, brightness, type of scan. If this doesn't give you any better results, then one of the best ways to do this is to get some plastic sheet of the same or almost the same as the predominant colour on your forms (you can go one step further and make a multi coloured filter if you are feeling creative and your forms are all identical). The text jumps out of the page and most scanners will give you a good scan - just make sure the filter is not too thick/dark. Hope this helps :)
Jun 25, 2007 | HP ScanJet 8270 Flatbed Scanner
Umax Astra 1220P Flatbed Scanner Logo
61 people viewed this question
Top Umax Office Equipment & Supplies Experts
Mohan Sriraman
Mohan Sriraman
Are you an Umax Office Equipment and Supply Expert? Answer questions, earn points and help others
