Question about Siemens Computers & Internet
CANNOT CONNECT TO MY BELKIN WIRELESS ROUTER (ENABLED) IT HAS EXCELLENT SIGNAL STRENGTH BUT WILL JUS NOT CONNECT
Down load updates for the drivers from 2003 to 2008
Posted on Jul 13, 2008
I have a Belkin wireless router connected to a Virgin modem. Always has worked fine with a Compaq laptop and 2 Dell Inspiron netbooks with excellent signal. Now have tried to connect with an Acer Revo rl...
The router is designed in such a that it is compatible with all the computers. The best way to get rid of this issue is log into the router interface and change the wireless channel to suit your requirement.
1) To begin with.. Open internet explorer on a computer connected to the router and delete everything from the address bar and type http://192.168.2.1 and hit enter. Now you will be in the Belkin Router setup. It will ask for a login password when you click on anything.. Leave the password field blank and click on submit. 2) Towards the left side under wireless click on "Channel and SSID". Now you see wireless channel change it to different channel and click on "OK / Save". Now check the signal strength in your Acer computer. If its still the same try different channel and check.
Hope this helped.
Feb 22, 2011 | Computers & Internet
My icon says I only have 80% signal strength, is
80% is a good signal strength....but if you want to increase the signal strength, then you need to move the wireless router to a very ventilated area, also the router should be placed atleast 5 feet away from other electronic devices like, modem, ups, microwave ovens,refrigerators etc.... also there should be a line of sight between the router and the wi-fi adapter... but in order to connect to a wireless network 25% of signal strength is enough....
Apr 17, 2010 | Belkin Computers & Internet
Can't get online, even though computer says connected
As the router is working and connected to the internet - then its probably and issue with the wireless setup on router or your PC
1) remove any wireless profiles on your PC read here - how to do that http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm then when reconnect it will ask for the key again 2) A firewall maybe blocking your access - disable any firewalls 3) Remove the wireless security if enabled in the router and see if you can connect - if this is the only wireless device connecting - it may interference try also changing the wireless channel in the router - use 1 or 6 or 11
Mar 14, 2010 | D-Link Computers & Internet
Belkin wireless router disconnects from wildblue every 2 min
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the Belkin wireless router away from walls and if possible move the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. changes the default password, setup encryption use WAP2 or WAP, change the default SSID, turn off SSID broadcast, and for added protection, enable MAC address filtering which allows the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, ard welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply) .
4. Check the channels of the wireless routers and access points in your area and and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize the interference with your wireless router from the wireless routers and access points in your area.
Sep 23, 2009 | Belkin (F5D5231-4) Router
Vista wireless connection to belkin-n
It sounds like your linksys is your main connection so therefor it will not always let belkin connect because your pc has registerd your linksys to be your connection.
Sep 20, 2009 | Belkin (F5D5231-4) Router
Samsung NC10 will not connect to any network
If WLAN and Wireless cards are enabled, then you may have to unplug your router for 10 seconds to reset it. They tend to build up a static charge. Unplug wireless router for 10 seconds, plug back in and you should be fine in a minute or two with full connectivity
Aug 20, 2009 | Samsung NC10-14GW Notebook
Have wireless signal but no IP
Starting from the obvious, check that the cables are installed correctly.
You have to have a cable that brings the internet to your place.
Connect that cable into the router's jack labeled Connection to Modem.
Then get another network cable and plug it into any other jack form the back of your wireless router, and the other end into your laptop, just to make sure you are getting connected.
Once you are sure you can surf the net, unplug the wire from your laptop, and you should be able to surf wirelessly.
And if you still can't connect, let me know to perform additional steps.
Please don;t forget to rate this answer if helps.
Jun 28, 2009 | Belkin (F5D7230-4) Router (587009)
Was working ok, now cannot get online using belkin modem-router. Says I am connected to my network, "signal strength excellent" but no wireless connection. Using the Belkin Modem router I am unable to...
please try to reset your router.
on the back of the router there is a little hole where you can insert a pen or a paperclip. hold it pressed in for 30 seconds and then release.
wait 10 minutes and try to connect to internett again (after connecting to the wireless net ofc)
May 28, 2009 | Computers & Internet
I can connect to the internet with cable connection to Belkin Modem with wireless G router but when I unplug and try to connect with wireless G network adapter no joy, get an error message 797 no reply...
Go into control panel-intenet options-connections-lan settings-make sure the only box selected is the top one for automatically detect settings.and make sure you have connected with the wep key that came with your wireless router.
May 12, 2008 | Computers & Internet
Computers & Internet Logo
44 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
