Question about DeLonghi Kitchen Ranges
DeLonghi DFS 090 SO DUAL FUEL ELECTRIC COOKER NO LONGER HEATS UP. The grill and fan works but the electric oven no longer works.
I had the same problem,it was something to do with the oven knob switch ,i got an engineer out to fix mine or else just buy a new knob hope this helps
Posted on Mar 25, 2009
I have power but not switching on at Knob no grill or oven no fan
Beko OIF21300B Electric Single Oven not heating - Repair
www.how-to-repair.com/.../beko-oif21300b-electric-single-oven-not-hea...
Jun 11, 2015 - If your Beko OIF21300B Electric Single Oven is not heating or tripping the ... Now the cooker turns on and the display lights come on but the cooker does not seem to work and start heating up. ... The grill element doesn't work
[PDF]Download Manual - Beko
downloads.beko.co.uk/bekoupload/manuals/DVG592.pdf
Congratulations on your choice of a Beko quality cooker which ..... Before you startusing your cooker, clean ... if an appliance burner doesn't light, press again.
Dec 13, 2015 | Beko D533AW Single Fan Oven Electric...
Grill turns on when cooker is turned from the isolater,
I assume you mean if the main electrical isolation is switched to on , the grill/ upper oven heats up even though the grill / upper oven switch is correctly set to off ......if this is the case you require a replacement thermostat for the upper oven I believe these are now obsolete and the alternative comes as a kit part no. 012959401 to modify the wiring replace both upper and lower oven thermostats see instructions attachedcid:eb5fa66b-5b72-4dad-aafc-a1f3a691fb03
Jul 03, 2014 | Stoves 800DFDOm Dual Fuel (Electric and...
Hi there, The cooker trips the fusebox rcd,I have checked for s/c's between l,n,e, but found none. The rcd trips after you set the clock and turn the main controller to any postion,ie oven light only, or...
It is quite possible that it is the oven or grill element that is causing the problem.
You need to test them with a meter, to determine if they are o/k.
If you have no meter, then disconnect each one in turn, and try it again, this should isolate the problem.
Hope this helps you.
Dec 19, 2009 | Tecnik TKC071/3 Electric Single Oven
Electric grill element on delonghi dfs 903.1 proffessional oven stopped working. Oven element works fine. Is the a cut out switch? nigel
check continuity thro the grill element. if ok, then suspect selector switch. there is a overheat cut-out but this would affect the oven element as well
Aug 05, 2008 | DeLonghi Kitchen Ranges
How to use my new cooker
What is the make of the cooker?
Thanks J
Feb 26, 2008 | Kitchen Ranges
Delonghi professional dfs903 cooker
have a Delonghi dual fuel DTC90DF range.
The oven has been temperamental for a whil, working then clicking off so that you had to turn it on again and it would work for a while again. Eventually there was a bit of smoke coming through the hob and it smelt of electrical burning and stopped working all together. It is the main fan oven that is now not working.
Please help
Bev
Jan 03, 2008 | Ovens
The cooker stays warm when mains cooker switch is on.
Either teh grill element or the oven heating element is fault or the thermostat or grill regulator, locate which element is warm, if the grill then it is most likely the regulator, if it is the oven it is the thermostat. Engineer
Jul 20, 2007 | Stoves 800DFDOm Dual Fuel (Electric and...
Problem with main fan oven - electric
there is an overheat stat and this is operating and cutting out the oven. the causes are several but here are the main things to look for: oven stat is faulty causing the oven to overheat. you should check over the range to see if stat is reasonably accurate. overheat stat itself is faulty. there is another stat which turns on the casing fan. (this is the fan which is out of sight - not the fan inside the oven) if this stat is faulty and not turning on the casing fan, then the overheat stat will operate. the casing fan is faulty or jammed. lack of ventilation. see if you can narrow it down a bit and get back to me if you wish
May 06, 2007 | Belling DB3 Dual Fuel (Electric and Gas)...
Kitchen Ranges Logo
878 people viewed this question
Top DeLonghi Kitchen Ranges Experts
JP Services
JP Services
Vitaliy Gins
Vitaliy Gins
Paul Bade
Are you a DeLonghi Kitchen Range Expert? Answer questions, earn points and help others
