Question about Video Game Consoles & Games
No cd with to set up axial feedback wheel - Video Game Consoles & Games
I got a new game control
thank you & goob bye
Posted on Jul 13, 2008
What is the torque setting for the front wheel bearing
There isn't a specific torque setting. You tighten the bearing nut while measuring axial play in the bearing. You want .01-.02mm of play in the bearing. A good rule of thumb is to tighten the nut with channel locks. Hold them backward so they don't pull tight on the nut as you turn. Turn not while holding pliers loosely until they slide off. Don't overtighten, you'll quickly trash the new bearings.
Feb 15, 2015 | Mercedes-Benz C-Class Cars & Trucks
Rear passnger tire locks up in 4 wheel drive
it is the powered wheel so transfer gears, rear end, or axial shaft.would need to hear it, to tell. sorry not more help.
Jan 12, 2014 | 1999 Chevrolet Silverado 1500
Abs light flashing
ABS failures are numerous. Depending on the source of the problem can be the abs connector near each wheel axial or a broken stator (a small disk which is part of the sensors at each axial) or its pickup sensor.
Other problems that are associated to this are uneven braking presser due to a frozen caliper or damaged/worn brake pads, shoes on drum brakes.
Some problems are due to problems with electronic assisted brake components. (See your local dealer about recalls, etc.)
Aug 10, 2012 | 2005 Dodge Ram 1500
The steering wheel when turning to the left is loose and lost its spring back action. It remains fine on the right hand side. How can we fix it?
There is really only one of two things that will be causing this.
1. Go into the control panel software that came with your wheel and re-calibrate your wheel and verify the force feedback settings in there as well. Also, go into the software you are using the wheel for and check in the settings for wheel/force feedback settings and try redoing those.
2. Your wheel's hardware itself is damaged and only thing you can do in that case is send in for repair (if under warranty) or buy a new wheel.
Feb 17, 2011 | Guillemot Thrustmaster 4160545 Ferrari...
Is the sidewinder force feedback wheel able to be used with the xbox 360.
no, because it has a 15pin (joystick/MIDI) connector and it would need a USB.
Aug 13, 2010 | Microsoft SideWinder Force Feedback Wheel...
No feedback through wheel
The program you are playing must recognize the wheel properly. The correct driver must be in Windows (See device Manager on my computer -> rightclick, Select Properties).
If the wheel has worked well with this game before, it appears the force feedback drive has failed in the wheel.
Test the wheel on a game you KNOW it works with. Check back with me if the driver is NOT Logitech GT.
Apr 02, 2010 | Logitech GT Force (963264-0403) Wheel And...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You may have to install or update drivers Most of the drivers/software I get are from a web site driverguide.com you need to fill out a free registration then search for the driver you need download it in a format you can use install it and then most times reboot the computer
Jan 25, 2009 | Microsoft SideWinder Force Feedback Wheel...
Ff wont work on new wheel with vista
I'm running 5.02 and have the same problem...
Dec 31, 2007 | Logitech MOMO Force Wheel And Pedals Set
Video Game Consoles & Games Logo
20 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
