Question about Indesit Washing Machines
Indesit 1200 spin wie127 what does the error code f-08 mean.
    Brigadier General:
  • 6,966 Answers
To my knowledge error F-08 refers to Heater relay can not be initiated/activated. However, this is not a replaceable component but is part of the main control board. The only corrective procedure is to replace the entire board.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 12, 2008
  • 190 Answers
Helo sir
F08 means Wash Heater Relay Stuck (signalled in presence of empty) or pressure switch
stuck on Full (simultaneously empty and full)
• Check the efficiency of J3 connector contact on the card
• Check pressure switch status checking J3 wiring connector pins 2 and 4
ohm continuity (it must only be present with tub empty) and pins 2 and 3
ohm continuity (it must only be present with water in the drum) and pins 2
and 1 ohm continuity (it must only be present with water in the tub above
normal level, at least halfway up door glass).
• Check wiring J3/pressure switch
• Check connection of heating element J3 connector pins 5 and 6.
• Replace pressure switch
• Replace Card
Indesit WIE127 is blinking
it needs resseting have you got the hand book as it will tell you how to if not let me know and i will look though mine and tell you how
Dec 07, 2011 | Indesit Washing Machines
Indesit wixe127 f-08 error
I have the same problem. Check this info (the below link) I found on F - 08 error for someones hotpoint washing machine. It may be the same thing. There could be standard error codes for all washing machines, maybe.
http://www.ukwhitegoods.co.uk/modules.php?name=Forums&file=viewtopic&printertopic=1&t=37910&start=0&postdays=0&postorder=asc&vote=viewresult&popup=1
Feb 07, 2010 | Indesit W 123 Front Load Washer
What does problem F-08 mean.
F08 means the heater relay cannot be activated.
Check all connections to and from the heater the module and the pressure switch.
Hopefully this will cure the problem.
Jan 11, 2010 | Washing Machines
Error codes f1 + f7 on washer
Error code F01 indicates a short circuit motor triac.
Chek all connections on and to the motor, motor plug and control module.
Code F07 indicates heater relay stuck.
Check all connections to and from the heater and control module.
Hope this helps you.
Jan 05, 2010 | Washing Machines
Error code f-08 on indesit wixe127 washer
Error code F08 means that the heaterrrelay cannot be activated.
Check the connections to the Pressure switch, the Module,and the Heater element.
If you can, test the element of the heater to make sure it is o/k.
Hope this helps.
Dec 02, 2009 | Indesit W 123 Front Load Washer
Indesit w127 error code f-08
Error F08 is indicating that the heater relay is stuck or cannot be activated or the contact has welded in the relay.
The only thing u can do yourself, is to check that the heater is o/k, if u can determine that it is , then u have no option other thancalling an engineer.out.
Plz rate my solution.
Thanks.
Dec 30, 2008 | Indesit W 123 Front Load Washer
My indesit wixe 127, wont drain and is stuck on error code f05. what doi do?
i think there is a problem with low water level sensor
My 127 fill up with water and i have f-08 error code which is a high level water sensor faulty
Aug 11, 2008 | Indesit Washing Machines
Indesit WIE127 Washing machine which flashes error code F08 when it goes to spin. Can this be fixed. What do I need to do to mend it?
I HAVE THE FAULT CODES FOR SOME INDESIT MACHINES THEY ARE ONLY SUPPLIED TO THEIR ENGINEERS BUT A MATE OF MINE WORKED FOR INDESIT/HOTPOINT (ONE COMPANY NOW) UP UNTIL A MONTH AGO , HOWEVER ,THEY ARE AT WORK & I WONT BE IN UNTIL FRIDAY IF YOU CAN HANG FIRE UNTIL THEN I MIGHT JUST BE ABLE TO HELP YOU OUT!
Jul 30, 2008 | Indesit Washing Machines
Indesit washer dryer stops halfway through a wash....
depends on what lights are flashing this is your fault code
Mar 28, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
273 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
