Possibly you are trying to load it from the back with the arm out. This way does not work. With this stapler you must pull the arm out all the way and then drop the staplers in the bottom. Too easy, right? I felt like a dumb a$$ after fighting this one for an hour. By the way, it will take heavy duty staples but you need to match the item codes printed on the side of the stapler with the box at ACE hardware. Hope this helps... Say "yes" to "was this solution helpful?" so I can know that im not the only one who did this wrong :)
Danny Murray said, "At the very bottom of the stapler in the back there should be a square mechanism. Press in and down then just slide the staples in and replace the mechanism the way you took it out." This is correct but I want to clarify -- you don't place the staples onto the sliding mechanism, but instead must lay them directly into the slot formed in the stapler body -- the same slot in which the mechanism slides. You'll see the slot when the mechanism is pulled out. With the bottom of the stapler facing upward and the spring-loaded mechanism pulled out, lay the staples in the slot, pointed sides up. Continue holding the stapler upside down and push the mechanism back into place, sliding it over the staples. Lock the mechanism into position by firmly pushing up and then down on the end-cap.
SOURCE: reloading ace 22084 staple gun
Hello there:
when you purchase staples for this particular gun even though you might get a staple that is says it fits this gun you need to look at the type of staple if you get the one that says heavy duty it will not work it took me 2 times to find out the right ones for this gun it comes in a green box and says standard duty on it not heavy duty this is where most people make their mistake. ok?
best regards michael
SOURCE: staples are stuck inside the stapler and will not come out
Typically you do not open these up.
Makes it difficult to remove stuck or wrong staples.
I have had good luck removing the staple ram rod and rapping firmly on the **** of the stapler against a wooden table. The idea is jolting the stuck staples into reverse out the way they went in. Tedious process but usually works. Removing the jammed staples in the nose at the striker plate requires using needle nose pliers and a sharp awl or small screw driver used on very small screws.
My T50 Arrow stapler is over 20 years old.
Still works great. Sometimes I slide in the wrong size staples by mistake. The process above usually works.
SOURCE: Need help on how to put staples in Ace staple gun 22084
At the very botton of the stapeler in the back there should be a square mechanism press in and down then just slide the staples in and eplace the mechanism the way you took it out
SOURCE: I need staples forthe swingline electric stapler
Go to Lowes or Ace. Take the stapler or an empty box along.
SOURCE: I need instructions on how to refill the Arrow T50
remove the spring loaded magazine from bottom rear of unit by pushing down on piece about two inches below curve section of rear end of handle push down gently and pull to rear staples go in front ofin same slot from which this magazine is removed load normally two clips if your dead empty when you return the spring follower back into place it follows the staples if if doesnt go all the way in you probably have to many remove some good luckd
