Tip & How-To about liftmaster Chamberlain Garage Door Opener Transmitter 300MC
Use the pull cord and disconnect the opener from the garage door.
Operate the opener and let the carrier slide back away from the door.
Is the carrier moving smoothly when disconnected?
Operate the opener into the down position, does it run smoothly?
Next, lift the door by hand from the bottom to the top. Is it moving smoothly?
Run the door down, ensuring that it moves smoothly. If not, lubricate the axles of all the rollers on both sides of the door.
Check the cable pulleys at the top sides of the door channel, lubricate them as well.
Are the two cables in all four of the pulley grooves?
Are the cables hooked properly to the bottom of the door?
Now, connect the opener to the door and try it.
After checking those things, there is an "up force" and a "down force" adjustment on the opener, try increasing the whichever is needed by by turning the adjustment in the direction of MORE force.
Use the pull cord and disconnect the opener from the door. Operate the opener and let the carrier slide back away from the door. Is the carrier moving smoothly when disconnected? Next, lift the door by hand from the bottom to the top. Is it moving smoothly? If not, lubricate the axles of all the rollers on both sides of the door. Check the cable pulleys at the top sides of the door channel, lubricate them as well. Are all cables in all the pulleys, there are 4. After checking those things, there is a "up force" and "down force" adjustment on the opener, try increasing the "up force" by turning the adjustment in the direction of MORE force.
Gary
Gary
I recommend this to everyone with garage door opener problems:
If not, lubricate the hubs of all the rollers on both sides of the door. Check the cable pulleys at the top sides of the door channel, lubricate them as well.
