Question about Philips Televison & Video
Picture fails About 40 seconds after the TV is switched on a ticking noise starts every 5 seconds together with picture distortion until the picture turns off then a red indicator light at the base of the TV starts flashing.
  • 1 more comment
  • Steven Jul 12, 2008
    See the YouTube link
    <object width="425" height="344"><param name="movie" value="
    I have uploaded a video to YouTube titled;
    TV problem Philips 21PT118A
  • Steven Jul 13, 2008
    Cost of repair v Cost of new TV ?
    • 417 Answers
    sounds like a high voltage issue, it will have to go in, i dont recommend self servicing that. may sound strange but Ive seen several tvs go by way of spouse having a plant above or near the tv, that person watering it and a few hours later mad spouse sitting in front of a busted tv that sounded just like that. also I had a cat that sprayed one and it did that. just a couple ideas for ya.
    J
    Posted on Jul 12, 2008
    • Jude Meredith
      Jude Meredith Jul 14, 2008
      hi,
      call a local tv repair shop and ask them, I would say around 100.00 for service and 100 for parts so 200.00. Take it in or call in for an estimate if your fond of it. My sanyo 35" in crt tv was 577.00 at wal mart a few years ago and has given me no problems, I would go to walmart first and check prices, craigslist for used one or maybe scratch and dent sale at a big tv store or something might save you some bucks .
      J
    Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
    If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
    Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
    Samsung DLP 56" tv,distorted picture
    if you say that your picture gets distorted you mean like it moves to a side? do you see a black middle block?
    if it's a yes?
    so its probably the light engine. you need to change it!
    try this link.. http://www.discount-merchant.com/1069179-HL-N5067W-p/1069179.htm
    the price is more or less depends on your TV model... $279.00
    Feb 02, 2010 | Samsung DLP HL-P5663W 56" TV
    Picture does not stay on when set is turned on
    its a switch fault, you need to get a tecnition but cheaper buying a new tv,hope this help
    Jan 24, 2010 | Philips Magnavox 27MT5405 TV
    LCD TV LA40R81BM/XTL tv tick tick sound 5min then strat
    Hi my name is Roety,
    I can help you with your issue ,
    This is most likely a power supply issue
    I usually replace the swollen capacitors I can see
    A repairman would charge about $300 to replace them for you.
    If I have helped you with your issue
    If you have more questions you can still respond
    I will reply asap
    Thanks
    Dec 15, 2009 | Samsung LA40A450 40 in. LCD TV
    Wavey color lines at bottom of picture. Crackling noises coming from back bad picture
    Howdy;
    The "crackling noises" from the back is causing the picture to distort. 1) Either locate source of "noise" and correct or 2) Call a Service Company and get corrected. I would recommend that you DO NOT USE TV until this corrected. It may cause a fire inside your TV.
    Good Luck, Big Irish.
    Nov 22, 2009 | Televison & Video
    Why is my picture distorted? From the start up it is distorted. Even if nothing is in it.
    make sure all connectors are secure for starters second id try different cables
    Jul 07, 2009 | Sony Playstation 3 (PS3) Console
    Green screen and distorted picture sound is good but no picture
    It must be connected with the color circuit of your tv, a board connected to back end of the tube. Could be dust, cob web or carbon deposit shorting a transistor. Popping noise if loud enough can be attributed to high voltage circuit fault and picture tube.
    Have it service by a qualified person.
    Apr 04, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
    40 samsung lcd picture problem
    first check the power supply board for puffy capacitors. then change the t-con board on lcd panel
    Sep 01, 2008 | Samsung Televison & Video
    Distorted Picture Upon Startup
    You have a bad capacitor in your power supply.
    Dec 22, 2007 | Toshiba 57H81 57" Rear Projection...
    TV will not switch on
    It sounds like you may be on the right track. Also you could have a problem in your Horizontal Deflection circuit. Since you say it flickered, you may have a solder joint that was arcing. Probably in the horizontal circuit. I found a capacitor which was arcing in this circuit. I was a small disk type. NOW since it is chirping, the horizontal output transistor may have shorted placing too much of a load on your power supply. The noise you hear is the power suppply trying to start. Stargazer
    Jan 29, 2007 | Philips 32PW6506 32" TV
    Televison & Video Logo
    90 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
