Question about Panasonic Heating & Cooling
Timer button flashing fan not coming on - Panasonic Heating & Cooling
  • 3 Answers
Posted on Oct 22, 2010
Fujitsu asta24 Lcc timer light flashing all the time even when off no cool air coming thru
A continuous blinking timer light is a "model error" meaning the indoor and outdoor unit is mismatched. If the timer light flashes a number of times, pauses, then repeats, count the number of flashes and then you can work out the error code.
Nov 17, 2016 | Fujitsu Heating & Cooling
Mitsubishi timer light 6 times blinking
Indoor unit indicator
RUN lamp = 6 time flash
TIMER lamp = Comes on
Outdoor unit indicator (LED5) = Stays off
Description of trouble = Indoor fan motor error (2)
Cause = Defective fan motor, Connector poor connection
Conditions of flashing = When air conditioner is operating and indoor fan motor is turned ON, indoor fan motor speed of 400 rpm or under continued for more than 30 seconds. (Air conditioner stops.)
May 29, 2016 | Mitsubishi Heating & Cooling
Samsung HL-T6756 DLP TV Standby/temp light flashing and tv won't come on. I have replaced the lamp and the fan is working. Any suggestions?
Remove lamp and inspect the color wheel to see if missing pieces or shattered---it will also just before failing give a high pitched or fan like sound and if running too slow or not at all instant shutdown happens.
Its also possible if you bought a GENERIC bulb--and used original cartridge the new lamp is bad.
Apr 09, 2012 | Televison & Video
FUJITSU Indoor Inverter ASTA09LCC/ASTA12LCC airconditioning - not cooling
If the operation button is flashing 8 times, the timer light should also flash 4 times in each sequence. This indicates a failure of the PFC circuit in the outdoor unit which basically means a faulty outdoor board and will have to be replaced.
If the operation light is flashing 8 times by itself, the indoor controller board may have a fault. You can normally test this by putting the mode on the remote to 'Fan' and checking that the controls otherwise work normally - louvers work as directed and fan speed changes correctly when selected on the remote.
Most likely the fault lies in the outdoor board but you should contact a tech to diagnose correctly.
Sep 24, 2017 | Fujitsu 18C1 Air Conditioner
Even with new battery, on-off will not click
1) If timer worked before and stopped working, then manual says last step is to reset timer.
If timer will not function after reset, then timer is broken.
2) You posted under battery-operated ST01C timer, that comes with 1 year limited warranty.
Open following page to identify timer, read ez instructions, and download on-line manual
3) How to reset ST01C
Hold down on-off button and press reset button
Release reset button.
Keep holding down on-off button until INIT flashes on screen.
Release on-off and 12:00 will flash
Re-program timer using ez steps shown on link above.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 13, 2011 | Intermatic Inc. ST01C Digital In-Wall...
My a airconditioner has both operation and timer flashing at the same time.there is no fan working on the outside unit there is no cold air coming this something to do with the control
I have one that the operation light flashes 7 times and the timer light flashes 2 times. Error code says Discharge pipe temperature error. Is there an easy fix?Thanks!!
Jan 19, 2011 | Fujitsu Heating & Cooling
Red flashing status light
Press and hold the "Device" and "Menu" for 5 seconds and see what code comes up....... 12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Apr 03, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Flashing timer light, cannot turn on tv
Press and hold "Device" and "Menu" buttons for six seconds and see if you then get a patter of flashes pertaining to the error codes... I would suspect one of the following codes:
12 No Error Detected
22 Recovery From Momentary Reset
32 Lamp Cover Open
33 Air Filter Cover Open
34 Lamp Abnormality
35 Chassis Fan Failure
36 Exhaust (Back Cover) Or Lamp Ballast Fan Failure
37 Engine (Dmd Or Lamp) Fan Failure
39 Excess Dmd Temperature
41 Short Detected
44 Dvi Cable (Between Chassis And Engine) Disconnected
Sep 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Oven won't work!
timer must be set to any time of day for ovens to work, niormally you need to press either 2 or 3 buttons together to set time, if this fails you need to bypass the timer ele ctrically
Jan 08, 2008 | Belling 644 Electric Kitchen Range
Flashing "A"
Press and hold the (-) button with the unit off untill the (A) clears. It's a 30 hour timer to remind you to clean the filter
Mar 11, 2007 | Zephyr Venezia ZVE-E42S Kitchen Hood
Heating & Cooling Logo
2,311 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
