Changing door gasket on Servis M9813s washer dryer
How do I change door gasket on Servis M9813s washer dryer to clean.Can I clean it well enough without removing. There is a lot black stuff on the rubber seal.
  • 1,462 Answers
You can clean in situ just as good as if you remove it
Posted on Jul 12, 2008
How to get belt back on my servis m20001w dryer
Hi, whenever I get stuck with an appliance problem I check You Tube Videos. Last month I changed belt and tensioner pulley on my Maytag dryer, and the video from a parts supplier was perfect. Sears had the parts.
Jul 27, 2016 | Dryers
Servis washing machine
Just by the sound of it, it sounds like it is the door lock/ sensor
Dec 10, 2013 | Washing Machines
How to change the swing of the door
Unfortunately, these doors aren't manufactured to be reversible. The matching dryers for these washers, however, are able to be swapped from side to side. What I can suggest is swap the actual positions of the washer and dryer. This is of course possible if you have long enough water hoses, power cords, dryer vent, and the drain line will reach.
May 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I want to change my LG front load washer so i will open to the right
Sorry, but the door on the washers are not reversible, only the dryer doors are reversible. I'd suggest using a low profile telescopic style dryer vent to allow you to put the washer on the left side without worrying about the dryer vent location. You can get longer dryer power cords if needed, and water supply extention hoses, or just longer hoses if needed. The drain hose is usually long enough to still reach the drain. I have done this many times.
Sep 28, 2009 | General Electric WCVH6800J Front Load...
Door does not open after a wash cycle
the door lock is you problem. just replace and should be back to normal.
Mar 01, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Hole in door gasket of a Hotpoint 9901w washer dryer.
It is quite involved to change the seal, as requires a partial strip down, if the hole is not very big, then you can do a fairly good repair using a bicycle punture repair kit..
Remove the plastic clip that holds the clamp ring on the front of the washer seal at the top, remove the clamp ring, take note how it is fitted, then pull seal off front of washer, and fit patch on underside of seal, refit seal and clamp,and job done!!!!
Plz rate my solution.
Jan 25, 2009 | Washing Machines
Washing Machine Door seal replacement
Hi, I'm not familiar with your particular model, but there is most likely a very similar type of clamp holding the back end of the seal to the static part of the drum. It is most unlikely that you will need to take off the front cover as on most machines only the back and top are removable. You might need to unfold the rubber to get to see the wire which is holding it on. If it is the type of clamp with a screw-tightening device, it might be rusted up and a new one might be called for.
If the old seal is damaged there is nothing to be lost by cutting away some of it with scissors so you can see better what you are doing.
When you get to the stage of putting the new seal on, try lubricating it with a bit of washing up liquid or soap to allow it to slip properly onto the casing and rum, and try to avoid tightening up with a twist in it - the soap should help. Remember to put the new one on in the reverse order to the way you got the old one off.
Hope this helps you a bit more. D
Jul 18, 2008 | Washing Machines
Inner drum seal wvf2402gb/02
This video will show you how to change a door seal on this Bosch WVF2402GB/02 front loader washing machine
we have all bosch repairs in our channel
You can get seals on eBay
Apr 07, 2008 | Bosch Classixx WVF 2402 Front Load...
Servis washer/dryer
Leaking all the time or just when it is in certain cycles?
Feb 10, 2008 | Washing Machines
Washing Machines Logo
332 people viewed this question
Top Washing Machines Experts
