Bought a Nikkai A52HF digital reciever&recorder from Maplin. Installed 80Gb IDE HDD (tried it formatted in 3 different ways). Whereas it orks fine as reciever without the disc, with the disk it crashes/freezes out. is the formatting to be a particular type?
Format it from the menu on the PVR the default code for the Nakkai is 888888 but the file format for the hard drive is probably UDF or some other format that windows cannot recognise or reproduce.... i think lol
Posted on May 29, 2009
Panasonic troubleshooting
I guess you mean a Set Top Box to convert digital TV transmission to old analog TV. Choose the correct video format for your screen.
Ah... Perhaps Your recording at an old standard & passing it to a modern TV or HD TV with the digital output from 1080 HD to 720 or lower still.
OR
Get a Digital Hard Drive recorder.....
The modern way to Record video is to use a Hard Disk Drive Recorder rather than a VCR. They have a built in tuner and can record 2 stations at once and have a built in Electronic Program Guide. The EPG info is transmitted with the Digital TV transmission from the broadcaster.
I bought one 2 weeks ago for an old 85yo friend so he could record late night stuff and play back later. He still uses the VCR but only for old VHS Tape playback. It was a TEAC HDR9650TS Digital Video Recorder and I picked it up new for Aus$188.
Here are the unit features
Main Features:
DVB-T Twin Digital Turners
DVR Recording: Record three channels while watching a 4th from same network Smart Series Record feature to record a whole series at a touch of a button
2.5" Sata Hard disk: 500GB
Time Shift Function (Pause live TV)
HDMI Digital Output
Digital Audio Output
CVBS/YPbPr/SPDIF connectors
Supports TV formats 4:3 and 16:9
Electronic Program Guide (EPG) up to 7 days in advance
EPG searching and auto download
Recorded program edit
Parental Control
Copy files from internal HDD to external HDD
Built-in WiFi
Network Playback
USB 2.0 Interface
Aug 14, 2014 | Panasonic Televison & Video
Hdd format error. not record image & video
hi,
try to reboot your cam...
if it doesn't work, the drive may be dead or just disconnected by a small chock,...
what ever you will have to open it to change the drive !
cheers
mich
Dec 19, 2013 | Sony Handycam Hdr - Xr 100 80gb Hdd High...
Have just purchased a USB 2.0 to SATA HDD Adaptor made by Nikkai from Maplin. Have connected everything okay with my old HDD but when I go to run the 'Driver & User Manual' disc it just tells me it a...
Most of these adapters don't need windows drivers EXCEPT for use on a '98 system.
Got to the disk management console & see if your USB drive is there. It may simply need to have a drive letter assigned for you to see it in My Computer.
The path to the disk management console is usually: %SystemRoot%\system32\compmgmt.msc /s
Paste that into Start/Run.
Aug 12, 2009 | Televison & Video
Finding Intel 845GVSR & 915GLVG Compatible Motherboard & Proc
you can use intel dg41 mbd , dualcore processor,1 gb ram,160 gb hdd or use intel atom for support contact 91-9645071021
Aug 11, 2009 | Intel D845GVSR Motherboard
HDD not recognized whe installing fresh Windows XP!
Hi...
If your HDD will not recognized during installation you need to check if your HDD is detected. Try to look at your BIOS if it is detected. IF the HDD will not detected you need to replace the cable, try to use the other slot of your SATA or IDE ports.
Regards
ICmanServer
Jul 31, 2009 | Dell Vostro 1400 Intel Core 2 Duo T5270...
Nikkai 8 inch DVB-T - no teletext
Teletext and Ceefax stopped when the UK went digital.
Aug 27, 2017 | Televison & Video
Lost Pin number
I believe the default unlock code is "888888", not "8888" Try that.
here's a very poor copy of the owner's manual:
http://www.techtalkpoint.com/downloads/A52HF-Nikkai-Digital-Receiver-Recorder.pdf
Take care,
Rob
Feb 27, 2009 | Televison & Video
Nikkai a52hf teletext not available?
This unit is not compatible with "extended services" ie "the red button on the remote control" it does not support MHEG5. See the Maplin website for more info.
Aug 02, 2008 | Televison & Video
No hdd found...
Hi.
Most new hard drives are not partitioned nor formatted and therefore are not ready for use when first bought. They have to be initialized/prepared for whatever device they will be attached to. Formatting may be FAT, FAT32, NTFS and others.
This could be done using a PC where the hard drive (HD) could be initially/temporarily installed as a secondary master/slave and use the Operating System to partition and format making it ready for use. Alternately, an external casing with USB interface may be used.
For your purpose, you need to determine in what format will your digital video player/recorder accept the new HD. This may be found in the manual. Alternately, some digital video player/recorder has this feature/option that will allow you to format newly attached to HDs.
Should the above be not sufficient, please post back with the brand and model of your digital video player/recorder.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Feb 05, 2008 | Western Digital Caviar WD400JB Special...
Televison & Video Logo
234 people viewed this question
Top Televison & Video Experts
