Question about Gaggia Titanium Espresso Machine
Gaggia Titanium Display frozen on rising cycle. Last time we discovered that it had to go through a rinse cycle filling up as many times until this process stopped. This stime it seems to be stuck. Can't seem t shift it at all. Also how do we remove the interior mechanism where the arrow indicates its does not seem to come out. Any suggestions on this.
  • Anonymous Aug 06, 2008
    I've got the same problem... rising cycle is in a loop It doesn't stop probably I've filled the tank more than 15 times
  • Anonymous Jan 25, 2009
    same problem as described. Had the problem several months ago and support sent instructions on how to resolve it. The resolution involves removing the brew unit, removing a screw in the back, putting something in the sensors to trick the machine to think the tray, brew unit and the door are in place. then it finishes and rotates the main gear. From there you can put it all back together and put the screw back in. However I forge the exact steps and am looking for confirmation.
  • 515 Answers
Do you mean the brewing unit you not can get out?
Posted on Jul 13, 2008
Water will not dispense on my Keurig Vue .Brewing process stops after a couple of seconds
It may be time to descale. Most models will give you a message when it's time to have the mineral deposits cleaned.
HERES HOW TO DO THAT...
Empty water resevoir. Disable auto off. Pour approx 48 oz of undiluted white vinegar into resevoir. PLace large mug on drip plate, run brew cycle, dump contents of mug in sink. DO NOT USE A K-CUP.
Repeat this process until the add water light is indicated.
Let brewer stand for at least 4 hours while still on.
Discard any residual vinegar in the resevoir and rinse thorughly.
AFTER approx 4 hours...fill resevoir with water.
RINSE:
PLace a large mug on the drip plate and water brew cycle. Pour the contents of the mug into the sink.
REPEAT this brew process until the add water light is indicated.
YOU MAY NEED TO REPEAT THIS "RINSE" PROCESS if you notice any residual taste
Sep 29, 2013 | Keurig Vue Brewing System
When I hit brew, it sounds like its going to brew and stops right away.
RINSE:
YOU MAY NEED TO REPEAT THIS "RINSE" PROCESS if you notice any residual taste.
Aug 15, 2013 | Keurig Platinum B70 Coffee Maker
Water just trickle half cup
RINSE:
Mar 01, 2013 | Keurig B31BLACK Mini Brewer Black 1-c
Fisher and Paykel 7.5 washing machine keeps powering off during rinse and spin cycles
The pump has a thermal safety cut out on it.
If the pump gets too hot it cut out.
Just put a new pump in and your all going again.
Aug 05, 2012 | Fisher and Paykel Washing Machines
The wash cycle runs and runs.
Most diswashers have a complete cycle that lasts over an hour. The machine fills with about 1.5-2 quarts of water, rinses the dishes for a few minutes, then empties the water, then fills again with new water and rinses for a few more minutes, then empties. This is to get a good bit of the looser gunk off the dishes, and to soften up any other stuff that has dried on there. Then the machine fills a third time, the soap door pops open, and it washes for a much longer time to hopefully dissolve away pretty much anything left on the dishes. Then it empties, and does a rinse the soap off cycle, and usually a final cycle that rinses again with a little bit of rinse agent to help them dry quickly.
The whole process uses about 2 gallons of water.
Sep 14, 2009 | Dishwashers
Fisher paykel will not complete rinse spin cycle
will sence it will spin once the water is out .that must mean your pump is restricted.unplug go to buttom of washer find pump and clean out
Dec 31, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Rising cycle not stopping
Did the machine stop after a while?
If it stops after a half cup of water then you have to replace the flowmeter.
When the rinsing cycle run you have to let it go to the water tank is empty and the machine **** air in the system, then you fill up with new water. If it not reset then i think there are something with the printed circuit card.
Let me know if you get your machine to run again.
/Mirran
Aug 06, 2008 | Gaggia Titanium Espresso Machine
Descaling light on
Per Pages 9 and 10 of Keurig Model B40 Use and Care Guide,
1) turn off the "Auto Off "feature
2) fill empty water reservoir with 48 ozs of undiluted white vinegar.
3. Place ceramic cup on the drip tray and run a brew cycle. Do not use a K-cup!
4. Press the large mug Button
- let Keurig coffee maker fill mug with vinegar & empty in sink.
5. Repeat brew process until water reservoir of vinegar is empty. (remember to open and close lid between each cycle so large mug Button will flash.
6. Rinse the water reservoir thoroughly and fill with fresh water.
7. FINAL STEP RINSE CYCLE
a) place a ceramic cup on the drip tray
b) run regular brew cycles WITHOUT using a K-cup.
c) pour rinse water into sink each time.
d) repeat brew process until water reservoir is empty.
d) perform additional rinse cycles if you notice any residual vinegar taste.
e) if the red "De-scale" light remains illuminated after completing descale and rinse cycles, repeat the descaling procedure above.
Otherwise - you're good to go!
Apr 16, 2008 | Keurig Elite B40 Coffee Maker
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
360 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
