Question about Onkyo TX-NR801 Receiver
Onkyo TX-NR801 Hello my receiver seems to be on muting. No noise or music on the loudspeakers. The disply shows normal content, I have checked all input selectors and fuses.
  • 3 more comments
  • adrian baer Jul 12, 2008
    no, mute is not displayed
    How can I do that?
    Do you have access to a schematic of unit?
    Thanks, this one I have. I meant technical drawings, to find the pre-amplifier.
    I do not belive that the power amplifier has a problem. I think it is the condtioner/preamplifier.
    Some more information: If I switch on the satellite receiver it is shown correct at the dispay: Digital / PCM goes correctly on. However, I have no output whether on the loudspeaker nor on the earphones.
  • 2,427 Answers
Here are the service manual and schemetics
http://www.nodevice.com/manual/newmans/TXNR801jpsmpdf/get19130.html
Trace back from the OUTPUT I'cs To the Large capaciators, Thats where the filerters are, before the filter (according to the circuit) is the preamplifier, In your case its a 5 pin IC
Posted on Jul 12, 2008
  • 813 Answers
  • 2,071 Answers
If you check the speakers ,and its good ,then the problem is in the power amp. section,there are four transistor there maybe,two of the transistor is busted already, you can check the transistor by using a multitester,open / shorted and to the change value resistor or open and to the shorted or dry up capacitor.This must be change in order be better again ,give me the model number so i can search the schematic the diagram.
    Genius:
  • 1,665 Answers
Here is your instructions manual
    Brigadier General:
  • 6,966 Answers
Most unusual. If there are any forms of error or fault, the system would not even come out of standby or full power on.
1. amp, protection circuitry would be activated and you would know;
2. logic/controller, as initially sated wold not even come out of standby;
3. probably the sound processing circuitry. if will not process selected source, nothing to pass to the pre-amp/amp, hence no sound but all else would appear working.
Incidentally, I believe that there was an update on the firmware of this particular model (among others). Perhaps you may want to consider that possibility. To read more, pls see this link.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Louie  Role
    Louie Role Jul 12, 2008
    Schematics, sorry no. Service manual are available on line for a fee here or here.
  • 190 Answers
Dear customer
Thank u for ur inquiry
try to goto options n try to set the channel to various setting . for eg usualy they l be have 2.1 ch,5.1 ch .. Try to select each option n test whter the sound is cumig or not
thank u
  • Ajith Kumar Jul 12, 2008
    And also
    U cud have different channel select option in ur remote of the speakers..try to select verious other channel..
    thank u
    Genius:
  • 1,847 Answers
Is the mute indicater displated on the screen.
  • Legin Varghese
    Legin Varghese Jul 12, 2008
    Try change the AUX code.
What are the advantages to doing a factory reset? I'am setting up tx in new place and need to start fresh. Does the tx reset?
Hello Arthur, The reset will take all of the settings back to factory default. This includes network settings and speaker settings. Thanks, FJD
Mar 27, 2016 | Onkyo TX-NR801 Receiver
Were do I plug my wireless headphones? Dos this txnr801 have on tv screen capabilities? If so how do I hook it up?
RTFM which is available for free at retrevo.com after you register.
http://www.retrevo.com/support/Onkyo-TX-NR801-Receivers-manual/id/365dj196/t/2/
As far as the unidientified earphones go, well, it has a manual too somewhere
Jun 23, 2011 | Onkyo TX-NR801 Receiver
Onkyo TX-SR705 Muting Problem
if what Dark_Orbit said does not work try doing a master reset by ressing and holding the dvr/vcr button and stand by button simultaneously. This would erase all your assignments so you would need to reassign all your sources hooked up to your onkyo.
Mar 04, 2009 | Onkyo TX-SR705 Receiver
How powerful loudspeakers can my Onkyo TX-SV444 tackle, maintaining good sound?
buy 6ohms or 8 ohms speakers. 4ohms consume too much power and sometimes causes short circuit. (safety first!)
Oct 16, 2008 | Onkyo TX-SV444 Receiver
NO SOUND
hello just check the mute is not on, check your speakers with a baterry they pop out now connect them all raise volume and if still no sound you receiver is burnt...take it to a repair shop......saludos
Jul 17, 2008 | Onkyo TX-NR801 Receiver
TX-NR801 panel connection
Basic handtools should be available, as well as having soldering tools. No, I'm sorry, there are no schematics or drawings that show what and where the parts are due to the same cabinet being used for several different models and power ratings. Go ahead and spring for the tech info from the MFGR. Common sense and some mechanical aptitude would be what you need for a clean R&R.(removal and replacement)...accordianman
Apr 30, 2008 | Onkyo TX-NR801 Receiver
Tx-38/28 quartz synthesized tuner amplifier
hello surely there,s a problem in connection firs do this check your jbl even if they new with a baterry they pop up,now make sure you connect the monster wire into the outputs remember the wire is too thick make sure your getting contact in outputs...saludos
Jan 05, 2008 | Onkyo TX-NR801 Receiver
Onkyo tx-nr801 net tune setup help
Below is the sequence that I made it work
1. download the latest firmware for tx-nr801 and net-tune central software at Onkyo website as shown below:
http://www.intl.onkyo.com/products/net-tune/download/index.html
Click on "User Identification" at the bottom
(You'll need the serial number shown at the back of TX-NR801
to download it)
2. disable firewall in your PC or notebook and start
updating the firmware for tx-nr801
If firewall can't be disable, you probably can't go through this.
This step takes about 30 min.
(There is a document showing how to do this with the download)
3. keep disabling firewall in your PC (notebook) and install net-tune central (there is similar document describing the procedure too)
4. By pressing Net-Audio on remote controller (it can switch between mServer and iRadio fucntions if you keep pressing this button)
Nov 15, 2007 | Onkyo TX-NR801 Receiver
Onkyo TX-NR801
Are you in "sleep" mode. This dims the display...accordianman
Oct 30, 2007 | Onkyo TX-NR801 Receiver
Onkyo TX-NR801 Receiver Logo
195 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
