Question about Acer Aspire 5002WLMi Notebook
Acer aspire 5110
Computer keeps telling me battery is low switch to power mode even when the adaptor is plugged in and it is running on maximum power which is adaptor mode
  • dixiedave Jul 12, 2008
    battery is fully charged and the power adaptor is plugged in but it seems to use the battery up and then tells you to switch to adaptor but it is aready plugged in and the green light is on
Try with baterry and if not then try with different plug
Posted on Jul 12, 2008
Acer aspire notebook will not switch on after battery discharge even with mains adaptor plugged in. Help Noel
1. Remove the battery and the ac adapter from the laptop computer. Press the power button for about 10 seconds. This will discharge thee flea power from the laptop.
2. Connect the battery and the ac adapter. Charge the computer for about 30 mins then try to turn the computer on.
If this does not work, try to turn the computer on with only the AC adapter connected. If this works then it time to replace the battery.
Jun 26, 2011 | Acer Aspire One PC Notebook
My Acer Aspire 9805 battery was replaced. For
It could be an AC adaptor issue.
It should boot when connected directly to the power outlet through the laptop adaptor. If it is not boot, then the adaptor might not be supplying the needed power to boot it up.
If it is possible, try to isolate the issue. Charge your new battery using another laptop. Then plug it in your laptop to see if it works. If it will work, then it is the AC adaptor of your laptop that is defective. If the charged battery still won't make the laptop boot, then there is something wrong with your laptop hardware. If could be a motherboard issue of your laptop.
Feb 23, 2010 | Acer Aspire 9805WKHi Notebook
Laptop randomly shuts off
Since, the Battery is not inserted in the Computer and it turns off automatically even with a slight movement when running on the AC Adaptor, it shows that the issue is with the DC-in jack on the Computer.
Now, to ensure if the issue is with the DC-in jack or internal power circuitry, it's required to diagnose the Computer after running it on the Battery power.
Remove the Battery pack from the Computer and clean the metal contacts on the battery and the compartment then, reinsert the Battery and check if it's charging. If not, try using a replacement battery.
If the Computer keeps turning off even if running on the battery power then the issue is with internal power circuitry.
Bye and take care.
Oct 01, 2009 | Acer Computers & Internet
My acer aspire 3000 laptop goes off automatically. i cant even format because it goes off when i start.
You may have a faulty battery or bad power adaptor chord. Try taking the battery out and starting it just plugged with the power adaptor. If it still goes out, then try with battery and no power adaptor.
Sep 18, 2009 | Acer Aspire 3000 Notebook
Says plugged in not charging
Take out the battery and make sure you can turn on the laptop with just the AC Adaptor hooked up.
If you can then you know the AC Adaptor is good. Try another known good working battery in the laptop, if the battery charges then you know that the old battery is bad.
If the laptop doesn't charge with a know working battery or a new one then you know that the motherboard is bad.
Aug 19, 2009 | Acer ASPIRE 3680-2022 Notebook
Hello sir,my laptop is acer aspire 7520 no charging,no run on main,run on battry only,laptop power adaptor led is damage,
this could be due to the fault in the ac adapter,please try swapping another adapter if it works then you need to replace your adapter.
Jun 20, 2009 | Acer (ACERMOTHERBOARD)
Pc is telling me to plug it in when the battery is at 90%
The battery needs to be conditioned. To condition a battery, plug in the AC adaptor and charge it to 100%. Unplug the AC adaptor and run the battery completely down to 0% or until the computer shuts itself down or goes into a hibernate mode. Once this occurs, plug the AC adaptor back in and fully re-charge the battery to 100% again. You should now be good to go.
Let me know what happens and if this has solved your problem. Thank you, Binary Bob
Dec 07, 2008 | Acer Aspire 3680 Laptop
Possbile battery
It could be a battery fault, have you tried it without the battery?
Sep 07, 2007 | Acer Aspire 3680 Laptop
Acer Aspire 5002WLMi Notebook Logo
106 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
