Question about HP DeskJet 845c Printer
Internal test page fine, external prints black in blue
When I print an internal test page directly from my HP Deskjet 845c, it comes out without problems and the black colour is right. When I print a test page from Windows Vista, however, the black has changed to dark blue. This suggests that the problem can be found at the operating system, but HP offers no 845c drivers for Vista. For some reason the printer uses the colour cartridge instead of the black ink one.
  • LasseL Aug 07, 2008
    I had tried what you suggested before, and didn't work... but now it did! Thanks! Obviously you just need to have the patience to go meticulously through all the simple solutions first.
  • Anonymous Mar 16, 2014
    deskjet 845c prints only in red not black
My cartize not working fluntly
Posted on Jan 07, 2009
  • 16 Answers
Before you print, you have to check your options.
For example, if you want to print black and white, when you select PRINT from the menu, you click on PROPERTIES to the right side or bottom side, depending on which windows you use, then select grayscale/black and white, etc in the options that will follow to correctly use your ink, you can always REMOVE the ink from your printer as you only want to print black and white or non color pages.
I hope this helps you.
ManOwar
Posted on Aug 07, 2008
Why does my HP Deskjet F4280 Show an E in the Start/Copy screen??
Regarding your recent inquiry about the HP 60 cartridge error message ("E in display window") and inability to print with your HP Deskjet F4280 printer, this type of error is normally associated to an electrical connection issue between the printer and the cartridge, or more likely, an internal micro-electronic failure inside the cartridge itself (please note that it is very rare for both ink cartridges to electrically fail at the same time). An electronic failure of the cartridge would be unrelated to the ink cartridge refill process; these same failures can (and frequently do) occur with brand new ink cartridges.* To help identify the root cause, please run the 'Tap 41' cartridge's electrical / diagnostic tests below (refer to B. and C), this will identify which ink cartridge is causing the issue:
NOTE: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
As a temporary workaround, or if you are unable to determine which cartridge is causing the issue, remove one of the ink cartridges from the printer....this might place the printer into the 'single cartridge printer mode'....print jobs may then be executed from the computer (only):
An internal electrical failure of a cartridge can be confirmed by performing the following corrective/diagnostic steps:
A.Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B.Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to DIAGNOSTIC TAP 41 video procedure at the following link on how to activate and read the service test:
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
      1.While holding the Power button, press Cancel (X) button 4 times, then press the 'Resume' button once.
        --- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
        ---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
For any additional questions please contact us directly: Inkjet411help@gmail.com
To purchase the lowest cost ink cartridges available in the USA (remanufactured in the USA) please visit: http://www.inkplicity.com/
-Thank you
Aug 14, 2014 | HP DeskJet F4280 All In One Printer InkJet
HP DeskJet 845c Printer - "My deskjet 845c printer not printing after formatting"
You need to install the printer driver.
You can download the HP printer drivers from their support WEB site. Please click on this link and select your model printer to download :- http://welcome.hp.com/country/us/en/support.html
Feb 02, 2013 | HP DeskJet 845c Printer
I have an HP deskject 845c and can't print in windows 7
Access the manufacturer's web-site: http://support.hp.com
Enter '845c' and do the search.
Select "Windows 7".
Select "Download device-drivers".
Download.
Install.
Print a test-page.
Jun 26, 2011 | HP DeskJet 845c Printer
Won't print on Vista operating system
I've seen this before with these printers. They will print a test page ok but nothing from the computer. Reload the driver. In fact go to the HP website and download the newest driver and install it. This should solve your problem. You should find your drivers here http://h10025.www1.hp.com/ewfrf/wc/siteHome?lc=en&dlc=en&cc=us Let me know if you need anything else.
hardrocko
Thanks for using FixYa
Feb 20, 2010 | HP DeskJet 845c Printer
I get a blurry result when printing. almost as if it gets printed twice on the same paper
Hi, this usally is becuase the carttridges are not calibrated/aligned.
To align the cartridges:
(extrated from HP.com)
  1. Open the HP Deskjet Toolbox .
  2. Click Align the Print Cartridges .
  3. Click Align , and the first test page will print.
  4. Examine the test page and follow the onscreen instructions to complete the Align Print Cartridges dialog box.
  5. After completing the Align Print Cartridges dialog box, click Continue . The second test page prints.
  6. Compare the second test page to the onscreen example and follow the onscreen instructions to complete the alignment process.
Cheers,
Ed
Oct 24, 2009 | HP DeskJet 845c Printer
Hp deskjet 845c will print from computer but not from the web
If you can't get a printer friendly page, Drag the mouse over just what you want to print. Go to File, Print. When the printer screen pops up, click on print selection.
Mar 23, 2009 | HP DeskJet 845c Printer
Won't print correct colour
Try printing a test page. If it comes out missing colors, the you color cartridge is bad. HP test pages will print each of the 3 colors by them selves, so you can see if you are getting all colors. If this prints ok, the I would think it is not a printer problem.
Mar 06, 2009 | HP D1560 Deskjet Printer InkJet
Prints one page on many pages
I think the problem is now fixed: I reinstalled the HP printer drivers, and made sure to choose HP DeskJet 845c in the printer setup before I printed a document.
Aug 11, 2008 | HP DeskJet 845c Printer
HP DeskJet 845c Printer Logo
294 people viewed this question
Ben Johnson
