Question about Whirlpool Microwave Ovens
Whirlpool RM278BXP Over the range Microwave
When the door is open, the light is on. Close the door and the light goes off. Enter time and hit start -- a relay clicks and the display counts down, but no light / fan / etc. I think the high voltage cap may be toast -- no countdown to 0 and increase to infinity -- just a zero resistance reading. Would this cause the problem I am seeing?
  • 2 more comments
  • kingm73 Jul 12, 2008
    The transformer primary winding, filament and high voltage windings test OK -- .2 ohms, zero resistance (infinite to ground) and 50 ohms (my service sheet says 55 to 61 -- so a bit low). Magentron tests fine -- zero resistance across terminals and infinite to ground. Here's the problem -- I am getting infinite resistance at the high voltage cap, as well as across the rectifier (I'm reversing the leads -- infinite both ways, not the infinite and 75K-200K ohms I'm expecting).
    It seems like my high voltage cap and rectifier are toast. Would this explain the behavior? Is there an explanation why this has occurred -- other than the unit is about 21 years old? I want to make sure that if I am going to spend about $100 on parts, that this isn't going to immediately recur.
    Thanks!
    Hi Reg501,
    Main fuse has continuity. The interlock monitor and light switches have all checked out OK (proper continuity or lack thereof when door opened and closed) -- primary interlock, secondary interlock, monitor, light and door switch. The thermal protector on the magnetron, the aux fan motor thermostat and the thermal fuse (top of cavity) all have continuity. What would you suggest next?
    Thanks!
    Do you think we’re talking about some kind of failure on the control board? There is a component labeled as follows – I am assuming that this is the main relay:
    (part description from top)
    Guardian Electric
    Cont 15A RES 120AC
    1345 S SERIES
    A410-367215-101
    COIL 24V DC
    FSP
    Part No. 81460
    861039
    Japan 5 8 5NA
    This part looks like it has at least 6 outputs. One of these pokes through the PC board – no contact, no solder – assuming it is just for stability and to facilitate proper mounting. However, directly opposite this, there is a contact that looks slightly burned with little to no solder left. I am not sure if this is another “stabilizer”, if it was a factory error (i.e. someone soldered the wrong contact, or if this could actually be the source of my problem? Would you suggest replacing the relay, or just trying to re-solder the connection?
    Thanks!
    While waiting for a response, I went ahead re-soldered the relay connection. Fixed! I do recall reading elsewhere that opening and closing the door while the unit is still running can put undue stress on some components and cause arcing... Could this have been the cause?
    Thanks for your help!
  • 413 Answers
The capacitor and diode will not cause the problem you describe. You will not be able to measure the diode with an ohmmeter, the forward breakdown is about 5-6Vdc. The normal failure mode for the capacitor is a short which will blow the fuse.
If any high voltage components go bad, the microwave will operate normally just not heat.
You should focus on the door interlock switches and safety thermostats, especially the cavity thermostat located somewhere on the top of the cavity.
To make a high voltage diode tester, wire up a 9V battery, LED and a 220 ohm resistor. Hooked up one way the LED will light reverse the connection the LED will not light.
If you need further assistance, let me know
Regards,
reg501
Posted on Jul 12, 2008
  • Richard
    Richard Jul 12, 2008
    Based upon your previous post, I was going to suggest control board failure. Good job for troubleshooting the board. Solder connections that do not have a good mechanical connection will fail over time. This problem has nothing to do with open or closing the door while the unit is running. Again congrats for a job well done!
    Regards,
    reg501
Why won't my interior microwave light turn off and my microwave won't start?
It sounds to me that your door switches aren't working.Your oven is protected by a couple of switches that engage when you open or close the door.They control a couple of safety features and also your interior light.One of them seems defective.
Dec 17, 2014 | KitchenAid Microwave Ovens
INSIDE LIGHT WILL NOT GO OFF
Simple issue here,there is a micro switch that shuts the light off when you close the door ,it may also open a circuit depending on yuor particular switch that lets the microwave think the door is open.Not hard to fix if you are handy,remove the screws to the sheet metal cover ,locate the switch and make sure that the switch is being made when you close the door.Could just be it is loose,could be the pin that hits this switch is missing,broke or out of adjustment.In any event,do this with no power on ,also these devices can still store power so be careful here .If you are not careful you could get seriously hurt so remove plug and or call someone that has some electrical experience this is totally at your own risk.
Apr 19, 2014 | Whirlpool MH3185XP Microwave Oven
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Apr 02, 2013 | Microwave Ovens
Microwave oven will not start after I put in the time. It says open and close door and press start. Still won't start
Probably a bad door switch or mount. The door switch help file is here.
On some models though (you didn't mention yours) the door circuit is very complicated, and may be showing the door error due to a blown fuse or cavity TCO.
Accessing the cavity TCO for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Whirlpool owner's manuals and installation instructions here.
The drawing below shows what to check:
You can find handy exploded views and order parts by model number
here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Dec 04, 2011 | Whirlpool Microwave Ovens
Sometimes when I go to heat something in the microwave it doesn't heat but when I open the door and then close it it sometimes will work?
Sounds like the door switch is going bad this is the switch that "tells" the microwave the door is closed so that way it doesn't run with it open
Apr 26, 2011 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
F6 appears on my Whirlpool Over Oven Microwave, Model GH7145XFB0. It will not let me perform the self-diagnostic test. When the door is closed, the light goes out and the unit begins the "cooking process"....
If it starts cooking as soon as you close the door,try unplugging it for a minute then try again. If it does the same its probably a defective triac or relay which is inside the microwave.
Aug 29, 2009 | Whirlpool MH7140XF Microwave Oven
Microwave not working
HI, this is a faulty control panel. replace asap if possible.
May 29, 2009 | Whirlpool Microwave Ovens
GE microwave won't turn off
Just checked the GE website. Had the same problem with my 5 year old microwave. GE website says to close and open the door quickly three times. First time I did this it didn't work. Second time I closed the door with some significant force and reopened it more quickly. Worked. Unplugged the microwave, plugged it back in, still fine.
Mar 21, 2009 | Microwave Ovens
Microwave Ovens Logo
261 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
sonic boom...
sonic boom...
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
